I am testing out some scenarios where the function dgetrf
is returned differently when used with cuBLAS/cuSOLVER compared to writing for LAPACK. For example, I am looking at LU factorization of the following matrix:
[2.0 4.0 1.0 -3.0 0.0]
[-1.0 -2.0 2.0 4.0 0.0]
[4.0 2.0 -3.0 5.0 0.0]
[5.0 -4.0 -3.0 1.0 0.0]
[0.0 0.0 0.0 0.0 0.0]
I test out getting the results using dgetrf functions from cuBLAS/cuSOLVER as followed (the code is far from pretty but it should do the job…)
#include <cblas.h>
#include <time.h>
#include <stdio.h>
#include <string.h>
#include <cuda_runtime.h>
#include <cublas_v2.h>
#include <cusolverDn.h>
int main(int argc, char** argv){
const int matrixSize = 5;
int i, j;
double arrA[matrixSize][matrixSize] = {
{2.0, 4.0, 1.0, -3.0, 0.0},
{-1.0, -2.0, 2.0, 4.0, 0.0},
{4.0, 2.0, -3.0, 5.0, 0.0},
{5.0, -4.0, -3.0, 1.0, 0.0},
{0.0, 0.0, 0.0, 0.0, 0.0}
double *arrADev, *workArray;
double **matrixArray;
int *pivotArray;
int *infoArray;
double flat[matrixSize*matrixSize] = {0};
cublasHandle_t cublasHandle;
cublasStatus_t cublasStatus;
cudaError_t error;
cudaError cudaStatus;
cusolverStatus_t cusolverStatus;
cusolverDnHandle_t cusolverHandle;
double *matrices[2];
error = cudaMalloc(&arrADev, sizeof(double) * matrixSize*matrixSize);
if (error != cudaSuccess) fprintf(stderr,"\nError: %s\n",cudaGetErrorString(error));
error = cudaMalloc(&matrixArray, sizeof(double*) * 2);
error = cudaMalloc(&pivotArray, sizeof(int) * matrixSize*matrixSize);
error = cudaMalloc(&infoArray, sizeof(int) * matrixSize*matrixSize);
cublasStatus = cublasCreate(&cublasHandle);
if (cublasStatus != CUBLAS_STATUS_SUCCESS) fprintf(stderr,"error %i\n",cublasStatus);
//maps matrix to flat vector
for(i=0; i<matrixSize; i++){
for(j=0; j<matrixSize; j++){
flat[i+j*matrixSize] = arrA[i][j];
//copy matrix A to device
cublasStatus = cublasSetMatrix(matrixSize, matrixSize, sizeof(double), flat, matrixSize, arrADev, matrixSize);
//save matrix address
matrices[0] = arrADev;
//copy matrices references to device
error = cudaMemcpy(matrixArray, matrices, sizeof(double*)*1, cudaMemcpyHostToDevice);
int Lwork;
// calculate buffer size for cuSOLVER LU factorization
cusolverStatus = cusolverDnDgetrf_bufferSize(cusolverHandle, matrixSize, matrixSize, arrADev, matrixSize, &Lwork);
cudaStatus = cudaMalloc((void**)&workArray, Lwork*sizeof(double));
// cuBLAS LU factorization
cublasStatus = cublasDgetrfBatched(cublasHandle, matrixSize, matrixArray, matrixSize, pivotArray, infoArray, 1);
if (cublasStatus == CUBLAS_STATUS_SUCCESS)
printf("cuBLAS DGETRF SUCCESSFUL! \n");
else
printf("cuBLAS DGETRF UNSUCCESSFUL! \n");
// cuSOLVER LU factorization
cusolverStatus = cusolverDnCreate(&cusolverHandle);
cusolverStatus = cusolverDnDgetrf(cusolverHandle, matrixSize, matrixSize, arrADev, matrixSize, workArray, pivotArray, infoArray);
if (cusolverStatus == CUSOLVER_STATUS_SUCCESS)
printf("cuSOLVER DGETRF SUCCESSFUL! \n");
else
printf("cuSOLVER DGETRF UNSUCCESSFUL! \n");
return 0;
The output from the code above is
Then when I try to do the same with LAPACK:
#include <iostream>
#include <vector>
using namespace std;
extern "C" void dgetrf_(int* dim1, int* dim2, double* a, int* lda, int* ipiv, int* info);
extern "C" void dgetrs_(char *TRANS, int *N, int *NRHS, double *A, int *LDA, int *IPIV, double *B, int *LDB, int *INFO );
int main()
char trans = 'N';
int dim = 5;
int LDA = dim;
int info;
vector<double> a,b;
a.push_back(2.0); a.push_back(4.0); a.push_back(1.0); a.push_back(-3.0); a.push_back(0.0);
a.push_back(-1.0); a.push_back(-2.0); a.push_back(2.0); a.push_back(4.0); a.push_back(0.0);
a.push_back(4.0); a.push_back(2.0); a.push_back(-3.0); a.push_back(5.0); a.push_back(0.0);
a.push_back(5.0); a.push_back(-4.0); a.push_back(-3.0); a.push_back(1.0); a.push_back(0.0);
a.push_back(0.0); a.push_back(0.0); a.push_back(0.0); a.push_back(0.0); a.push_back(0.0);
int ipiv[5];
dgetrf_(&dim, &dim, &*a.begin(), &LDA, ipiv, &info);
if (info == 0)
printf("dgetrf successful\n");
else
printf("dgetrf unsuccessful\n");
return 0;
The output I get is
dgetrf unsuccessful
I understand that they are two different libraries, but is this behaviour expected?
