DGPU struck on P0 state,even with PRIME offload enabled
cat /sys/bus/pci/devices/0000:01:00.0/power_state
D3hot
echo $__GL_ExperimentalPerfStrategy
1
nvidia-smi
def-matcher: command not found
Sun Jan 16 18:44:17 2022
| NVIDIA-SMI 495.44       Driver Version: 495.44       CUDA Version: 11.5     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   49C    P0    N/A /  N/A |      1MiB / 16125MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
At the moment I’m not able to upload nvidia-bug-report.log file
Here a link to the nvidia-bug-report.log file
Please see this:
https://forums.developer.nvidia.com/t/nvidia-smi-keeps-gpu-awake-with-on-demand-prime-profile/200641/2?u=generix
@generix I just wonder if my memory is playing tricks with me regarding nvidia-settings not waking up the gpu, or if something changed in the driver/nvidia-settings lately?
IDK, this was new to me, but also never checked before. I’m always only looking at the sysfs nodes.
D3hot
Also powertop reports a 19 W power usage from my “ethernet controller”, even when the ethernet cable is disconnected.
I suspect it is really the nvidia GPU as it align with the power usage as indicated by nvtop
