Issue
Installing the CUDA toolkit on a DGX Spark (Grace + Blackwell, ARM64/SBSA) running Ubuntu 24.04 either failed or produced a broken setup (no nvcc, compile errors, or the installer aborting). nvidia-smi showed GPUs and driver 580.95.05 fine, but local CUDA builds weren’t possible.
On a DGX Spark (Grace + Blackwell, ARM64/SBSA) running Ubuntu 24.04, getting a working CUDA toolkit (with nvcc) turned into a trap maze. The GPUs were visible and healthy (nvidia-smi showed Driver 580.95.05 and CUDA 13.0 runtime), but the toolkit itself wasn’t present—no /usr/local/cuda-*, no compiler, nothing to build against. Multiple “official” paths either failed outright or produced an unusable toolchain:
The Ubuntu 24.04 ARM64 CUDA repo was reachable, but the usual meta-packages (
cuda-toolkit,cuda-toolkit-13-0,cuda-13-0) simply weren’t published at that time, soaptcouldn’t install anything meaningful. -
The NVIDIA download UI often surfaced cross-SBSA (cross-compile) or RHEL RPM flows when selecting ARM64, which are not suitable for native Ubuntu installs; the deb (local) variant for Ubuntu 24.04 ARM64 returned 404.
Installing CUDA 12.2 “worked” in the sense that files landed under
/usr/local, but compilation failed on Ubuntu 24.04 because GCC 13 / newer glibc headers expose types (e.g., SVE intrinsics) that CUDA 12.2’s toolchain can’t parse—even when forcingg++-12or using-allow-unsupported-compiler. -
The CUDA 13.x runfile includes a driver by default; if you miss unchecking it, the installer attempts a driver install and aborts, despite the system already having a newer, compatible driver via DGX/NVIDIA repos.
What this looked like in practice
You could see the GPU and a “CUDA Version: 13.0” in nvidia-smi, which implied CUDA was “there,” but that value reflects the driver’s runtime capability, not the presence of the toolkit. Without nvcc and the headers/libraries, any local CUDA build failed immediately. Attempts to “do it the right way” via Ubuntu packages or older toolkits led to dead ends (missing apt packages, 404 installers, or compiler/runtime mismatches). The reliable, architecture-correct path turned out to be the universal ARM64 SBSA runfile for CUDA 13.0, installed toolkit-only (leaving Driver 580 in place) under /usr/local/cuda-13.0, followed by a clean environment setup. Once installed this way, deviceQuery, vectorAdd, and custom kernels built and ran as expected.
System
Platform: NVIDIA DGX Spark (Grace + Blackwell), ARM64/SBSA (
aarch64) -
OS: Ubuntu 24.04.3 LTS
Driver: 580.95.05
Goal: Working CUDA toolkit + compiler (
nvcc) for native builds
Symptoms
nvidia-smishowed CUDA Version: 13.0 (driver runtime), but nonvcc. -
/usr/local/had nocuda-*dirs. -
CUDA 12.2 installed but failed to compile on Ubuntu 24.04 (GCC/glibc headers errors).
Ubuntu 24.04 apt repo did not expose expected toolkit metas (
cuda-toolkit,cuda-toolkit-13-0,cuda-13-0) at that time. -
CUDA 13.0 runfile tried to install a driver if not explicitly unchecked, then bailed.
Root Cause(s)
Download picker traps: surfacing cross-sbsa (cross-compile) or RPM/RHEL packages instead of native ARM64 Ubuntu runfile.
CUDA 12.2 vs Ubuntu 24.04 toolchain: GCC 13 / newer glibc headers (SVE types) break 12.2 builds even with
g++-12. -
Repo lag: Ubuntu 24.04 ARM64 CUDA repo reachable but toolkit metas not present.
Installer defaults: runfile bundles a driver; must uncheck it on systems that already have the correct driver.
Dead Ends Encountered
Ubuntu 24.04 ARM64 “deb (local)”: 404 (not published).
apt-get install cuda-toolkit*: packages not available for this channel. -
CUDA 12.2 on Ubuntu 24.04: compile errors (
_Float64,__Float32x4_t…) even with-allow-unsupported-compiler+-ccbin g++-12.
Final Solution (Works)
Install CUDA 13.0.2 toolkit via the universal ARM64 SBSA runfile, toolkit only, keep the existing 580.95.05 driver.
CUDA Toolkit Archive with Latest Release
https://developer.nvidia.com/cuda-toolkit-archive
Steps
1) Download runfile (from the CUDA 13.0 archive/picker):
Platform: Linux → arm64-sbsa → Native → Ubuntu 24.04 → runfile (local)
Example file:
cuda_13.0.2_580.95.05_linux_sbsa.run -
Save to:
~/installers/cuda-13.0/
2) Install (interactive; UNCHECK driver)
cd ~/installers/cuda-13.0
chmod +x cuda_13.0.2_580.95.05_linux_sbsa.run
sudo sh ./cuda_13.0.2_580.95.05_linux_sbsa.run
# In the TUI:
# - Accept EULA
# - UNCHECK "Driver"
# - KEEP "CUDA Toolkit" checked
# - Install path: /usr/local/cuda-13.0
3) Environment (system-wide)
sudo tee /etc/profile.d/cuda.sh >/dev/null <<'EOF'
export PATH=/usr/local/cuda-13.0/bin:$PATH
export LD_LIBRARY_PATH=/usr/local/cuda-13.0/lib64:${LD_LIBRARY_PATH}
EOF
sudo ln -sfn /usr/local/cuda-13.0 /usr/local/cuda
source /etc/profile.d/cuda.sh
4) Verify
which nvcc && nvcc --version
nvidia-smi
Expected: nvcc shows 13.0 (V13.0.88); nvidia-smi shows Driver 580.95.05, CUDA Version 13.0.
5) Samples (CMake route)
sudo apt-get -y install git cmake build-essential
cd ~
git clone --depth=1 -b v13.0 https://github.com/NVIDIA/cuda-samples.git
cmake -S cuda-samples -B cuda-samples/build \
-DCMAKE_BUILD_TYPE=Release \
-DCMAKE_CUDA_COMPILER=/usr/local/cuda-13.0/bin/nvcc
cmake --build cuda-samples/build --target deviceQuery -j"$(nproc)"
~/cuda-samples/build/Samples/1_Utilities/deviceQuery/deviceQuery | head -n 40
You should see device info; other samples like vectorAdd report Test PASSED.
Cleanup (do this to avoid future conflicts)
Remove old toolkits and stale loader entries, and strip user env overrides.
# Ensure loader points only to 13.0
echo "/usr/local/cuda-13.0/targets/sbsa-linux/lib" | sudo tee /etc/ld.so.conf.d/cuda-13-0.conf
sudo rm -f /etc/ld.so.conf.d/cuda-12-2.conf
sudo ldconfig
# Remove older toolkits (example)
sudo rm -rf /usr/local/cuda-12.2
# Comment out any 12.x PATH/LD_LIBRARY_PATH in ~/.bashrc
sed -i.bak -e '/CUDA Toolkit 12\./,+2 s/^/#/' ~/.bashrc
# New login (or source) to pick up /etc/profile.d/cuda.sh
Notes & Gotchas
nvidia-smi“CUDA Version” = driver runtime capability, not the installed toolkit. -
On ARM64, the
linux_sbsarunfile is distro-agnostic; if Ubuntu’s tab doesn’t show it, pick RHEL to reveal the same runfile. -
CUDA 12.x + Ubuntu 24.04 often requires a container (22.04 base) due to GCC/glibc changes. If you must stay on 12.x, build in a container.
Minimal Command Summary
# Install CUDA 13.0 toolkit (ARM64/SBSA), toolkit-only
sudo sh ./cuda_13.0.2_580.95.05_linux_sbsa.run # UNCHECK driver; path=/usr/local/cuda-13.0
# Env
EOF
# Verify
nvidia-smi
# Samples
cmake -S cuda-samples -B cuda-samples/build -DCMAKE_CUDA_COMPILER=/usr/local/cuda-13.0/bin/nvcc
# Cleanup of old toolkits
sudo ldconfig
House Keeping
Exact artifact name:
Where you stored it:
~/installers/cuda-13.0/ -
Driver present:
580.95.05(kept) -
OS / arch: Ubuntu 24.04.3 LTS,
aarch64(ARM64/SBSA) -
Install path:
/usr/local/cuda-13.0 -
Symlink:
/usr/local/cuda -> /usr/local/cuda-13.0 -
Env file:
/etc/profile.d/cuda.sh(PATH + LD_LIBRARY_PATH) -
Cleanup performed: removed
/usr/local/cuda-12.2, dropped/etc/ld.so.conf.d/cuda-12-2.conf, commented user-level 12.4 exports in~/.bashrc.
Integrity Checks
After download:
sha256sum ~/installers/cuda-13.0/cuda_13.0.2_580.95.05_linux_sbsa.run
# record the hash in the post
One-shot “apply the fix” snippet (forum-friendly)
# 1) Run installer (toolkit-only)
sudo sh ./cuda_13.0.2_580.95.05_linux_sbsa.run # UNCHECK "Driver", path=/usr/local/cuda-13.0
# 2) Env + symlink
EOF
# 3) Clean old entries (if present)
sudo ldconfig
Quick verification block
which nvcc && nvcc --version # should show 13.0
nvidia-smi # should show driver 580.95.05, CUDA Version: 13.0
Optional: sample build line to prove it works
~/cuda-samples/build/Samples/1_Utilities/deviceQuery/deviceQuery | head -n 20
