DGX Spark does not automatically reconnect to saved Wi-Fi network
It has been observed that the DGX Spark system does not attempt to reconnect to a previously saved Wi-Fi network once it gets disconnected.
For example, assume the DGX Spark is connected to a Wi-Fi network named “ABC”. If, for any reason, the “ABC” network gets disconnected and then becomes available again after some time, the DGX Spark system does not automatically try to reconnect to that Wi-Fi network.
Issue summary:
  • Wi-Fi network is saved and previously connected
  • Network gets disconnected temporarily
  • Network comes back online
  • DGX Spark does not attempt to reconnect automatically
Has anyone encountered this issue or found a configuration or workaround to enable automatic reconnection?
Any help or insights would be appreciated. Thanks!
Hi, Ankit,
This is a DGX spark relate question, I think you need open a topic on following page.
Thanks,
Suo
Ok
Thanks zhangsuo
