DGX Spark keeps freezing mid inference and training and when I ran the fieldtest it keeps failing at GPUStress, PowerStress or ThremalStress with mostly the following message: Acceptable temperature limits exceeded or the thermal sensor is broken or miscalibrated UNIT:
NVIDIA DGX Spark
BIOS: 5.36_0ACUM018
OS: Linux spark-ed30 7.0.0-1019-nvidia #19~24.04.2-Ubuntu SMP PREEMPT_DYNAMIC
LOGS: Starting OneDiag…
Version r9.257.8
Python /opt/nvidia/dgx-spark-fieldiag/dgx/python/python-3.10.7-glibc-2.17-aarch64/bin/python3
Build Date Wed, 10 Jun 2026
Start time Thu, 15 Oct 2026 04:34:17
Est. Completion time Thu, 15 Oct 2026 08:06:47
Logs /opt/nvidia/dgx-spark-fieldiag/dgx/logs-20261015-043359
Inforom logs /opt/nvidia/dgx-spark-fieldiag/dgx/logs-20261015-043359/inforom
Product NVIDIA_DGX_Spark
Product Version A.7
Family DGX Spark
SKU 0000
Serial Number 1983925012210
Testing GpuStress OK [ 3:17s ]
Testing C2CStress OK [ 0:06s ]
Testing CpuStress1 OK [ 0:08s ]
Testing CpuStress2 OK [ 10:01s ]
Testing PowerStress OK [ 8:12s ]
Testing ThermalStress /FAILED [ 0:42s ]
Exit Code | Virtual Id | Test | Subtest | Component | Component Id | Notes
MODS-000000000000 | GpuStress | custommods | | GPU | | OK
MODS-000000000000 | C2CStress | custommods | | C2C | | OK
MODS-000000000000 | CpuStress1 | custommods | | CPU | | OK
DGX-000000000000 | CpuStress2 | cpustress | | CPU | | OK
MODS-000000000000 | PowerStress | custommods | | Power | | OK
MODS-020000281445 | ThermalStress | custommods | | Thermal | | Thermal resistance is too high
Final Result: FAIL
End time: Thu, 15 Oct 2026 04:56:45 [ 22:28s elapsed ]
Reproducible: Multiple runs sometime fails at PowerStress, ThermalStress or GPUStress with error of temp limit exceeded.
Real-world symptom: the unit hard-powers-off / freezes under sustained high-power GPU inference & Training, recoverable only by a cold power cycle — no kernel panic, no OOM.
let me try this out and re-run the fieldiag, but from the internal sensor readings I have mostly seen the temp issues near cpu area rather than gpu, in cpu the temps revolve around 93C+ and gpu it goes upto 82C max.
and as my llm can best describe:
We have a DGX Spark running long local LLM workloads with llama.cpp. On several occasions, the machine became unreachable during or around a long-running workload and did not recover until someone manually restarted it. We’re trying to determine whether this is related to the platform, firmware, power, temperature, or workload.
What we observed
The failures have occurred during periods of extended LLM use, though we cannot establish that the workload caused them.
At least one outage lasted roughly two hours before the next boot. The system had no recorded clean shutdown.
In some incidents, the last available kernel ACPI thermal readings were around 95–96°C. Another incident ended with readings around 94–95°C, with earlier samples peaking around 97°C. The ACPI zones are not clearly identified as CPU or another specific component, so we do not know what hardware they represent.
GPU temperature was around 77–78°C in the available samples.
In one incident, the LLM workload was still running just before telemetry stopped. The last available memory readings did not indicate ordinary RAM exhaustion.
The NVMe SMART report showed no media errors or critical warnings. It did report 43 unsafe shutdowns, consistent with unclean power-offs but not identifying their cause.
We found no kernel panic, OOM kill, thermal-trip record, PCIe/AER error, or GPU Xid that explains the shutdown. In the incidents reviewed, the logs end abruptly before the next boot.
Diagnostics collected
We set up persistent system telemetry and incident logging, including thermal readings and GPU data, so that the last readings before a future failure can be reviewed. A field-diagnostics script was also created, but we have not established that its results identify the cause.
Same signature here. My Founders Edition (SBIOS 5.36_0ACUM018, A.7) failed
ThermalStress in 42 seconds (MODS-020000281281, “Temperature above specified
limit”) with every other test passing, including PowerStress.
In normal use it lost power instantly under sustained vLLM load, three times and on
two kernels (6.17.0-1032 and 7.0.0-1019). No panic, nothing in pstore, and kdump was
armed but captured nothing, which is what you’d expect from a power cut rather than a
crash. A 2-second sampler caught the last reading before one of them: 74.8 W, 79 °C,
96% util. It had already survived 87.6 W earlier in the same run, so for me it wasn’t
a simple power or temperature ceiling. I also told NVIDIA that unified memory was at
~105 GB of 119.6 GiB at the time, since memory over-commit can produce the same
log-less signature.
A clock cap (nvidia-smi -lgc 300,2200) held through a short test that hit the same
conditions, with acpitz up to 89 °C, but that was only about 1.5 busy hours, not
enough to call it a fix before the unit went back.
Suggestions from going through it:
NVIDIA asked me for a full Field Diagnostics run as the RMA pre-check, so attach
the logs zip from your failing run to a support case.
A sampler logging power, clocks, utilisation and the thermal zones every few seconds
records the readings right up to a crash, which a log-less power-off otherwise
doesn’t give you.
If your warranty is close to expiring: the replacement keeps the original expiry
date, so ask for expedited shipping as soon as the RMA is approved.
That’s frustrating. What worked for me was not the chat at all:
I opened a case through the support portal’s web form instead
(https://nvidia.custhelp.com/app/ask, signed in with my NVIDIA account). It shows
on the case as channel “CSS Web”, and a person picked it up directly; I never went
through the AI agent. I opened it 1 Oct, support asked for a full Field Diagnostics
run as the RMA pre-check, I ran it 3 Oct, and the RMA was approved 5 Oct.
What helped it move: I wrote the case like a bug report rather than a complaint —
product, driver and serial at the top; the symptom in one paragraph; the system
details; the evidence (telemetry around the crashes, the empty kdump/pstore); a list
of what was attached; and one explicit ask at the end (“please advise whether this
unit should be replaced”). Your logs-20261015-043359 zip already does most of that
work, so attach it rather than describing the fault.
One trap: I could only run fieldiag 1.0.9-1. 2.0.4 wouldn’t install on DGX OS 7
because of an OFED dependency, and support told me not to install OFED.
@aniculescu if you could provide any help here, would be really helpful,
sending you Case number, Serial Number, Fieldiag Logs and summary of issue via DM
If you have a failing fieldiag, then you are eligible for RMA. If you own an FE unit, please open a ticket with customer support NVIDIA DGX Spark Support
