DGX Spark FE: SoC/PD ESRT 0x1 with nonzero PD banks - supported 7.5 to 7.6 upgrade path?
NVIDIA Customer Care reviewed our private diagnostic report and asked us to request platform firmware review in this forum. We need help interpreting an affected DGX Spark Founders Edition / P4242 firmware baseline and establishing a supported upgrade path before scheduling maintenance. We have not established a hardware fault or an RMA requirement.
These are existing read-only captures from 2026-10-29 and 2026-10-31, not fresh measurements today. No additional host tests, package installs, firmware staging, Secure Boot changes or reboots have been performed for this inquiry. The existing production service has been left unchanged.
Software baseline in those captures:
  • DGX OS OTA: 7.5.0. The original image-build field still says 7.2.3; this is distinct from the current OTA field.
  • Kernel: 6.17.0-1031-nvidia; NVIDIA driver: 580.173.02.
  • BIOS: 5.36_0ACUM018; fwupd: 2.0.20-1ubuntu2~24.04.2.
  • Secure Boot enabled, SetupMode=0, independently confirmed by mokutil and selected EFI-variable reads.
Privileged ESRT capture:
Component Firmware class GUID Reported current Lowest supported Last attempt version Last attempt status
SoC b488217b-3895-4fc0-b1bf-ab7005a2d45a 0x00000001 0x02007300 0 0
USB-C PD dd1a238a-5f8e-46bd-9401-a88da99c5a96 0x00000001 0x00000400 0 0
EC 3d13c989-e6a8-4ead-95ee-921f09868f65 0x03000508 0x02003400 0x03000508 0
Selected SMBIOS Type 45 values:
  • FLASH: SBP:R:2.117.42.
  • UEFI and STMM: R:1.87.27.
  • EC firmware: 3.5.8.0.
  • PD0: FW1=4.10, FW2=4.10; PD1: FW1=4.10, FW2=4.10.
  • dmidecode 3.5 warns that SMBIOS 3.7 is not fully supported. Both captures exited 0 and were not truncated; we have not installed another decoder.
Other observations:
  • fwupd reports SoC/PD VersionRaw=1 and UpdateState=2.
  • Retained fwupd history has only an EC entry from 2026-08-06 targeting 0x03000508. SoC/PD get-results each exit 2 with FwupdError code 9 and no matching device in the history database.
  • The single retained Capsule0000 targets the EC GUID and reports CapsuleStatus=0. Its EFI_TIME timezone is unspecified, so we do not label that time UTC.
  • UpdateCapsule exists and is empty; OsIndications=0; BootNext is absent.
  • We do not treat a success status as proof of target-version activation. Missing retained records also do not prove that an update was never attempted. Our PD banks are nonzero and Secure Boot is already enabled; we have not copied fixes from other units with different symptoms.
Device-matched LVFS candidates recorded on 2026-10-31 were SoC 0x02009e0f (release 152274), EC 0x03000d07 (152272), and PD 0x00000519 (149899). The intended software target follows the DGX Spark-specific October release notes: DGX OS 7.6.0, kernel 7.0.0-1019-nvidia and driver 580.178.04. Candidate discovery is not being treated as direct-upgrade clearance. We have not changed package sources or pinned a kernel.
Questions for the platform firmware team:
  1. What is the official mapping between these Type 45 / PD-bank strings and ESRT current version 1? Is this a known factory/reporting state? What supported, non-disruptive read-only check can clarify it?
  2. Is a direct update from this exact baseline to the listed OS/firmware set supported? If intermediate releases are required, please identify their exact versions and prerequisites.
  3. What is the supported OS/APT, NIC firmware, SoC/UEFI, EC and PD update sequence? Which components may be staged together, which require separate reboots or power cycles, and what actual-version / capsule checks confirm each step? Please account for any firmware action that stock package scripts or vendor services might trigger automatically.
  4. What onsite recovery facilities and preferably non-wiping recovery path are required? If further diagnostics are needed, please first distinguish checks that preserve the running service from work requiring a maintenance window.
The firmware fields and error summaries above are from the dated captures. Serial numbers, private contact details, hostnames, management addresses, unit-specific device IDs and production configuration are omitted. Full private evidence remains available to NVIDIA Customer Care through the existing case. No public attachment is included in this enquiry. Please advise a supported path; we are preserving the service while seeking guidance.
References:
A FW version of 0x00000001 is not expected and may indicate a bad update occurred. Does nvfwupd report an update is available for these components?
Can you also report the FW versions seen in the UEFI menu?
