DGX Spark freezes after few minutes
I don’t know if I can describe the problem in detail, but I’ll try. When I turn on my computer, I have a very limited time to log in, meaning enter my account password. Then the desktop loads, along with the image I set as my screensaver, and that’s it. Neither the mouse nor the keyboard show any sign of life. The mouse freezes in one position, making it impossible to open applications or check running processes. If I hesitate and don’t immediately click on the profile to enter the password using the keyboard, the mouse and keyboard also stop working, meaning the system seems to be overloaded with some processes that launch automatically.
Are you able to login remotely with SSH? If so you can try seeing your running processes.
I don’t think this is possible, since I worked directly on it and, accordingly, did not configure SSH keys and so on.
SSH is automatically setup and does not need a key. The Spark also has its own “micro-DNS” to allow communication through its hostname, you can login with a user account i.e. ssh <user>@<spark-hostname>.local or ssh <user>@<spark_ip>
The thing is, I’m an enthusiast and I’m using AI for coding and assistance in my project. If you could write me full step-by-step instructions, I can try them next week when I finish assembling my new computer. I’d also need instructions on whether I should connect the Spark to my PC using any cables and how to do it correctly. Thank you.
You can use the NVIDIA Sync tool to remotely access and manage your Spark from another device. User Guide. You can then use the tool to open the DGX Dashboard and a terminal you can use to check your running processes. If you cannot connect remotely through this process, I would recommend reimaging your system to recover it. System Recovery — DGX Spark User Guide
Hello, if I reinstall the operating system, will the data on my hard drive be lost?
пн, 26 янв. 2026 г., 19:12 Aniculescu <notifications@nvidia.discoursemail.com>:
Yes, reimaging the system will delete all of your data
In that case, this option is not suitable for me, since I have important work data there.
пн, 26 янв. 2026 г., 19:24 Aniculescu <notifications@nvidia.discoursemail.com>:
What are the options for downloading the data so I can reinstall the operating system or, in principle, send you back this useless thing that does not perform its functions after I download my data and reinstall the operating system?
As I said before, you can try to use the NV Sync tool to remotely manage your device NVIDIA Sync — DGX Spark User Guide
You can also look into using Linux tools like Secure File Copy (SCP) to remotely download your files.
Hi Bentleyelis, since you already have work data on Spark, am I correct in assuming this freeze behavior is new? Otherwise, you would not have been able to generate that data.
Can you confirm when the issue started and what changed around that time, such as a new keyboard, mouse, or other peripherals being connected?
Of course, this problem didn’t exist initially. I copied the data from my external hard drive, transferred it to Spark, and continued working using Cursor.ai. Then, when Cursor.ai offered to download deepseek 3.2, I installed it and tried to run it. Then, when I tried to launch Spark the next day (this was back in late December 2025) to continue working, it started freezing right at startup, or, if I managed to enter my password and username, it froze almost immediately after logging in.
пн, 26 янв. 2026 г., 19:44 NVES <notifications@nvidia.discoursemail.com>:
To be clear, Cursor AI does not fully download/run models locally. It’s designed to call models via APIs (OpenAI, Anthropic, Google, etc.) rather than host them on your Spark. Not sure this makes sense.
The quickest way to triage and recover at this stage is to try SSH into your SPark from another computer. No additional setup is needed on your Spark. If that works, then it’s likely a configuration issue that you can either walk back your recent change or save the work data, then reimage.
I’m saying that I used cursor.ai to download and run LLM locally. Cursor only helped me with the commands for downloading and running it, or rather, I gave it access so that it could do it in the terminal on its own.
I have a folder with all the data on my desktop. I can download LLM again, but I need the folder itself and the data that is there. How can I use this procedure to extract it from there by connecting from another computer?
пн, 26 янв. 2026 г., 20:03 NVES <notifications@nvidia.discoursemail.com>:
@bentleyelis Please review the information I gave in comment #11 on how to remotely access your Spark so you can retrieve your data.
I have experienced symptoms similar to this before.
For me, docker was auto-starting with a ‘bad’ configuration that was using too much memory.
I was also worried because I had data there I did not want to lose.
I was able to use a monitor and keyboard to quickly log into the system before the OOM condition happened and kill docker. I then stopped docker auto loading the troublesome container. I had to try quite a few times to get the timing correct.
Since then I have setup backup to an external drive.
Hi, can you please tell me what exactly you were doing and how you stopped docker?
Hello, with great difficulty, I finally managed to overcome the problem, which, as expected, was in the Docker container, causing the entire system to freeze during boot. NVIDIA Sync worked as expected; I managed to connect to it at the right moment during Spark startup and enter the command to disable Docker. After gaining access to the system, I was able to download all the data from the device. However, I’m still not satisfied with the performance of this device, which freezes due to the processes it was actually designed for. Could you please tell me if you have a cable and power supply for this device available? I had an incident with my cat, and I would like to replace the entire power supply system, as one of the cables is soldered into the power supply connector.
I’m glad you were able to solve your issue. We will have better OOM handling in the next major update so you don’t run into this problem again.
For return/replacement requests, please contact Customer Support
