DGX Spark GB10 2 node cluster- one dead port?
Hello All-
Having a bit of trouble setting up the SSH network layers for my DGX Spark 2 node cluster. I have never seen something like this, but maybe someone here has? Basically I run the playbook scripts after I added in my IP address reservations and such, but it seems to be having issues setting up SSH, even when it says it completed successfully. What’s really strange, is that it is always one port that doesn’t want to configure, for some odd reason. I’ve run out of ideas, so I ‘ll post here what I’ve done so far and what I have tried, unsuccessfully, I might add.
HARDWARE: DGX Spark GB10 4 TB 128 MEMORY (BRAND NEW)
ConnectX-7 NIC CABLE (BRAND NEW)
1. Have already updated BOTH nodes to the latest firmware, updates, etc.
2. The Network Interface Controllers:
ConnectX-7 NIC @ 200 Gbps Connection shows connected on both nodes
10 Gbps Ethernet is NOT connected right now, but I will connect to a 2.5Gps switch
3. I have deleted the NIC profiles a few times now and ran the below playbook scripts to setup my netplan, which appears to have worked just fine.
4. ibdev2netdev command shows all ports both UP & DOWN on both nodes (as it should)
5. I’m running commands at the admin level
6. Have switched the ConnectX-7 cable to the other set of mirrored ports on both nodes, same result.
6. Have rebooted, and rebuilt this several times now, with no joy.
Anyone ever run into a rogue port problem? Would REALLY like to get this 2 node cluster up and functional, esp watching the prices of said hardware climbing to the moon, by the week, it seems.
Any help greatly appreciated, so I can stop pulling my hair out. There has to be a simple explanation, but I’m sure not seeing it!
SCRIPTS I RAN FROM THE PLAYBOOK WITH MY SETTINGS ADDED IN:
Manual IP Assignment with the netplan configure file
On node 1:
## Create the netplan configuration file
sudo tee /etc/netplan/40-cx7.yaml > /dev/null <<EOF
network:
  version: 2
  ethernets:
    enp1s0f1np1:
      addresses:
        - 192.168.50.149/24
      dhcp4: no
    enP2p1s0f1np1:
      addresses:
        - 192.168.51.149/24
      dhcp4: no
EOF
## Set appropriate permissions
sudo chmod 600 /etc/netplan/40-cx7.yaml
## Apply the configuration
sudo netplan apply
On node 2:
network:
  version: 2
  ethernets:
    enp1s0f1np1:
      addresses:
        - 192.168.50.150/24
      dhcp4: no
    enP2p1s0f1np1:
      addresses:
        - 192.168.51.150/24
      dhcp4: no
EOF
sudo netplan apply
bash discover-sparks.sh
Found: 192.168.50.150 (spark-95d3.local)
Found: 192.168.50.149 (spark-95d3.local)
Setting up shared SSH access across all nodes…
You may be prompted for your password on each node.
Configuring 192.168.50.149…
✓ Successfully configured 192.168.50.149 with shared key
Configuring 192.168.50.150…
✗ Failed to configure 192.168.50.150
Shared SSH setup complete!
All nodes can now SSH to each other using the shared key (id_ed25519_shared).
(myuser)@spark-95d3:~$ ibdev2netdev
OF NOTE: Script DID NOT FIND the other node
rocep1s0f0 port 1 ==> enp1s0f0np0 (Up)
rocep1s0f1 port 1 ==> enp1s0f1np1 (Down)
roceP2p1s0f0 port 1 ==> enP2p1s0f0np0 (Up)
roceP2p1s0f1 port 1 ==> enP2p1s0f1np1 (Down)
Hi Ralph,
There’s a useful clue in your output: the interfaces configured in Netplan don’t match the interfaces showing an active link.
Your configuration assigns addresses to enp1s0f1np1 and enP2p1s0f1np1, but your ibdev2netdev output shows those interfaces as Down. The Up interfaces are enp1s0f0np0 and enP2p1s0f0np0.
Each physical QSFP port on the Spark exposes two Linux Ethernet interfaces. With one cable connected, seeing two interfaces up and the other two down is expected. NVIDIA explains the mapping in its ConnectX-7 networking guide.
I would first check ibdev2netdev on both machines with the cable in its current position. If both show the f0 pair as up, change the two interface names in each Netplan file:
enp1s0f1np1   → enp1s0f0np0
enP2p1s0f1np1 → enP2p1s0f0np0
Keep your existing addresses under the corresponding entries. After applying the configuration, test both paths from node 1:
ping -I enp1s0f0np0 -c 3 192.168.50.150
ping -I enP2p1s0f0np0 -c 3 192.168.51.150
Once those work, test SSH directly, replacing myuser with your actual username:
ssh -vvv myuser@192.168.50.150
There’s also a misleading message in the shared-key discovery script: it prints the final completion message even when a node’s setup fails. The script suppresses the file-copy error output, so the direct SSH test should help reveal whether the remaining problem is authentication, the SSH service, or connectivity. It’s also worth checking that the remote user’s ~/.ssh directory exists.
Finally, both discovered addresses are shown as spark-95d3.local. I’d verify the hostname and assigned addresses locally on each machine to confirm which address belongs to which node. ibdev2netdev only reports the local machine’s interfaces; it doesn’t discover the other Spark.
Based on what you’ve posted, I’d investigate the interface assignment first. The active pair is encouraging, and this output alone wouldn’t lead me to conclude that a port has failed.
Hi Christopher_owen-
That makes more sense, thanks for the excellent reply!
This is what happens when you try to setup new hardware without the proper amount of sleep and caffeine beforehand! I’ll use your advice as it makes a lot more sense now. I KNEW it was something right in front of me and also the script output saying all was hunky-dory was a tip off that it just wasn’t!
I’ll post back with my findings, thanks again!
