§1 Environment
- Hardware: NVIDIA DGX Spark (GB10 Superchip), aarch64, 119 GB unified memory
- OS: Ubuntu 24.04
- Kernel: 6.17.0-1008-nvidia (Ubuntu 6.17.0-1008.8-nvidia 6.17.9, PREEMPT_DYNAMIC, build 2026-01-21)
- BIOS: GX10DGX.0103.2026.0129.1152
- Kernel taint:
/proc/sys/kernel/tainted=4097= bit 0 (P, Proprietary) + bit 12 (O, Out-of-tree). Per-module taint attribution measured directly (see §2b) - Watchdog:
sbsa-gwdt(blacklisted by default/etc/modprobe.d/blacklist-watchdog.conf, re-enabled via a systemd unit for defense-in-depth)
§2 Symptom
- Freeze event: hard freeze lasting approximately 2h 16min under sustained mixed workload (GPU inference + host processes)
- Kernel log pattern (before freeze): RCU stall detected on CPU 11. NMI backtraces were captured to pstore (ARM64 does not emit per-CPU NMI backtrace to journalctl by design, so pstore is the primary evidence channel)
- State snapshot (RCU stall watchdog thread inspection):
->state=0x402(kthread sleeping) in 84 of 86 sampled events;0x0(RCU_GP_DOING_FQS brief wakeup with CPU 11→19 transition) in 2 of 86 - IRQ 401: nvidia GPU MSI-X
effective_affinity_list=11(single CPU pinned per GIC-ITS arm64 default policy, direct correlate to RCU stall concentrating on CPU 11) - watchdog0:
timeleftshows an anomalously large value (approximately 1.27 billion seconds) — appears to be a display bug; petting was confirmed working after enablingsbsa-gwdt
§2b Tainted per-module attribution (measured, not inferred)
$ cat /proc/sys/kernel/tainted
4097
$ for m in /sys/module/*/taint; do t=$(cat "$m" 2>/dev/null); [ -n "$t" ] && echo "$m => $t"; done
/sys/module/mstflint_access/taint => O
/sys/module/nvidia/taint => PO
/sys/module/nvidia_drm/taint => PO
/sys/module/nvidia_modeset/taint => PO
/sys/module/nvidia_uvm/taint => PO
Decode: 4097 = 4096 + 1 = bit 12 (4096 = [O] Externally-built out-of-tree module) + bit 0 (1 = [P] Proprietary module).
Per-module attribution (measured directly, not inferred from bitfield):
- [P] Proprietary contributors:
nvidia,nvidia_drm,nvidia_modeset,nvidia_uvm(NVIDIA GPU driver stack, 4 modules) - [O] Out-of-tree contributors: same 4 NVIDIA modules (all flagged PO), plus
mstflint_access(Mellanox firmware access utility) - Not taint contributors: the
mlx5_*/ib_*/rdma_*Mellanox InfiniBand + Ethernet driver stack loads without setting any taint flag on this system
§3 Investigation Summary
Investigation was conducted over approximately 2 days through a sequence of controlled experiments and forensic reviews:
- Read-only probes: identified
sbsa_gwdtblacklist, IRQ 401 CPU 11 pinning, and kernel version audit - Auto-reboot containment via
kernel.panic_on_rcu_stall=1+kernel.panic=30, plus a systemd unit pettingsbsa-gwdt(RuntimeWatchdogSec=60) for defense-in-depth - kdump dry-run test:
echo c > /proc/sysrq-triggertriggered auto-reboot in approximately 3 minutes, but/var/crash/contained novmcore-*file. kdump-based forensic capture failed - Root cause probe of the kdump failure:
KDUMP_SKIP_VMCORE=1was found in/etc/default/kdump-tools, but investigation confirmed this is a phantom variable (not read bykdump-toolsin this version, no-op). The real issue was a conflict between the hostsbsa_gwdtblacklist and the crash-kernel initrdoptions action=1 - Canonical kdump fix attempt: placed an
OPTION=KDUMP-gated hook in/etc/initramfs-tools/hooks/that force-loadssbsa_gwdtinside the crash kernel initrd only (zero blast radius on normal boot) - Discrimination experiment: watchdog set to 1800 s +
echo c > /proc/sysrq-trigger→ observed 39 min hang, watchdog did NOT fire, required physical hard reset, no vmcore captured. This confirmed CPU 11 hardware-level lockup blocks the watchdog IRQ pathway — notably, thread 366026 (a prior boot-time failure analysis) observed the opposite (SBSA Generic Watchdog fires as the panic trigger there), which itself is useful comparative evidence - pstore-only pivot:
crashkernelreservation removed,crash_kexec_post_notifiers=1+pstore.kmsg_bytes=65536added,kdump-toolsmasked. Panic test with the new configuration captured 78 pstore chunks (20 + 58) via efi-pstore end-to-end, confirming the pstore-only forensic pathway as viable
§4 Root Cause Hypothesis (current state)
Positioning note (related to but distinct from prior forum discussions): this report focuses on CPU 11 hardware-level lockup during RCU stall under sustained runtime load as the failure axis, which is distinct from thread 366026 (“Root Cause Analysis: DGX Spark driver failure — kernel 6.17.0-1008-nvidia aarch64 panics cause DOE mailbox failure”) which addresses a boot-time DOE mailbox failure with different CPU (7) and different failing subsystems (nbcon / FPAC-PSCI-NMI race / qspinlock IOVA hash). The pstore forensic mechanism is common ground, but the failure axis, timing, and CPU pinning differ.
- Primary (confirmed for the CPU 11 lockup axis; hypothesized for the crash-kernel behavior): CPU 11 hardware-level lockup during RCU stall → watchdog IRQ pathway blocked → kdump
kexecpresumably fires but the crash kernel also depends on CPU 11 code paths and either hangs or fails to boot (no vmcore captured to confirm the crash-kernel mechanism directly). efi-pstore (routed through the kernel panic notifier chain, which does not depend on CPU 11 and can write from a different CPU) is currently the only viable forensic pathway confirmed by end-to-end panic testing - Secondary (candidate, seeking community feedback): The Tainted [P] + [O] combination may be a contributing axis. Per-module attribution shows [P] comes from the NVIDIA driver stack (nvidia + nvidia_drm + nvidia_modeset + nvidia_uvm) and [O] comes from the same NVIDIA modules (all PO) plus
mstflint_access. No direct evidence of a proprietary/out-of-tree kernel-module interaction causing the freeze has been captured. Note: in thread 366026’s analyzed boot-failure panics, tainted modules did not appear in any call trace (the analysis there concluded these were kernel-level bugs, not driver bugs). Whether the same holds for the sustained-load freeze axis reported here is unknown — that is precisely the feedback being sought
§5 Workaround (pstore-only forensic pathway recipe, reproducible)
# 1. Rollback crashkernel reservation (adjust file name to match your setup)
sudo mv /etc/default/grub.d/90-crashkernel.cfg{,.bak}
sudo systemctl mask kdump-tools.service
sudo apt-mark hold kdump-tools
# 2. Add pstore-only kernel cmdline drop-in
echo 'GRUB_CMDLINE_LINUX_DEFAULT="$GRUB_CMDLINE_LINUX_DEFAULT crash_kexec_post_notifiers=1 pstore.kmsg_bytes=65536"' | sudo tee /etc/default/grub.d/91-pstore.cfg
sudo update-grub
# 3. Panic-on-RCU-stall + auto-reboot containment
printf 'kernel.panic_on_rcu_stall = 1\nkernel.panic = 30\n' | sudo tee /etc/sysctl.d/90-rcu-panic.conf
sudo sysctl --system
# 4. Reboot to apply
sudo reboot
# 5. Post-reboot verify
grep -oE 'pstore\.kmsg_bytes=[^ ]*' /proc/cmdline # expected: pstore.kmsg_bytes=65536
cat /sys/module/pstore/parameters/backend # expected: efi
systemctl status systemd-pstore.service # expected: active (exited)
# 6. Panic test (arrival-side observation)
sudo sysctl kernel.panic_on_rcu_stall=1 && sudo sysctl kernel.panic=30 && echo c | sudo tee /proc/sysrq-trigger
# After auto-reboot, dmesg-efi_pstore-* files (no extension, underscore separator) should appear under /var/lib/systemd/pstore/*/001/
# Note: file naming may vary by systemd version; use catch-all `dmesg-*` pattern for portability
§6 Evidence Pack
Public evidence uploaded as a Github Gist: DGX Spark GB10 kernel freeze evidence pack (2026-08-28) · GitHub
01-README.md(summary + link back to this thread)02-dmesg-Panic1-Part20.txt(32 KB, systemd boot section)03-dmesg-Panic1-Part78.txt(95 KB, kernel boot header + crash context)04-proc-cmdline.txt(/proc/cmdlineverbatim)05-proc-tainted-per-module.txt(/proc/sys/kernel/tainted=4097+ per-module attribution output +lsmodMellanox mlx5 stack, informational)06-bios-kernel-version.txt(BIOS + kernel +uname -a)
§7 Questions to Community + NVIDIA Staff
Tainted [P] + [O] correlation (per-module attribution measured, see §2b): Has anyone else observed hard freeze on DGX Spark / GB10 aarch64 with the same taint contributor set (NVIDIA GPU driver stack +
mstflint_access, withmlx5_*NOT contributing) under sustained load? Is a proprietary/out-of-tree module interaction a plausible contributing axis for the RCU-stall-on-CPU-11 pattern? -
Kernel refresh roadmap: Kernel 6.17.0-1008-nvidia has documented aarch64 panic issues in prior community analysis (thread 366026). Is there a public roadmap for a kernel refresh on DGX Spark, or a recommended stable rollback target?
sbsa_gwdtblacklist intent: The watchdog blacklist is Ubuntu’s generic kmod policy (all watchdog drivers blacklisted, explicit opt-in expected). Given that, is NVIDIA’s shippedoptions sbsa_gwdt action=1intended to be paired with an explicit load mechanism on DGX Spark, or is it currently dead configuration? -
crashkerneldefault1G-:0M: The NVIDIA defaultcrashkernelreservation is1G-:0M(effectively disabled). Was this intentional (kdump unsupported on GB10) or a config carried over from another platform? -
CPU 11 MSI-X pinning + IRQ affinity mitigation: RCU stalls concentrate on CPU 11, which is the effective affinity of the nvidia GPU MSI-X (IRQ 401) under the GIC-ITS single-CPU default. During the lockup the watchdog IRQ path did not fire. Is single-CPU MSI-X pinning the expected configuration on GB10, and is spreading IRQ affinity a supported mitigation worth testing?
§8 Related Threads (cross-reference)
Prior root-cause analysis (comparative, different failure axis):
- Root Cause Analysis: DGX Spark driver failure — kernel 6.17.0-1008-nvidia aarch64 panics cause DOE mailbox failure (pstore evidence) — boot-time DOE failure, CPU 7, different failing subsystems; comparative evidence on watchdog behavior
Active threads with symptom overlap (potential direct beneficiaries of the recipe in §5):
- Spark hangs - requires a hard-reset (physically unplugging) — closest symptom match, active as of 2026-08-27, 14 replies
- DGX Spark reproducibly hard powers-off under GPU load — zero crash capture — direct beneficiary of pstore-only capture recipe
- DGX Spark stability thread — general stability, 44 replies
Additional context:
- DGX Spark stability thread — general stability hub, 44 replies (highest engagement)
- Gemma 4 on DGX Spark (GB10): System Freeze at >80% Utilization & sm_121 Kernel
Issues — freeze under sustained GPU utilization,
adjacent to the CPU 11 MSI-X pinning axis - DGX Spark hard-freezes under sustained few minutes inference; PowerStress thermal
failure —
sustained-inference freeze, complements this thread’s runtime freeze axis
§9 Update Log
- 2026-08-28: Github Gist evidence pack uploaded
