Dear NVIDIA Support,
I am writing about my DGX Spark. I purchased / am using it for a fully local creative desk (image, video, voice, and music) controlled from a Mac Mini over the LAN. Over the past days an assistant (Grok Bot / in Cursor) helped install and run open models on the Spark. The experience so far has not produced a single solid, keepable creative result, and I need clarity on whether this is a supported path on Spark, a configuration/software issue, or something covered under warranty / RMA.
Goal: Run a stable local creative workflow on DGX Spark (stills + short video +
optional TTS/audio), managed from a Mac on the LAN.
WHAT I NEED FROM NVIDIA
- Supported first-boot / Sync / local-login recovery that does not require
a full factory wipe when possible. - Documented limits and recommended flags for Wan-class (or NVIDIA-blessed)
local video on GB10 (~128 GB unified memory). - Pointer to the current playbook/container pins for local image + video
on Spark (Comfy or NGC path). - Confirmation which failures below are expected software limits vs items
that need support diagnostics / logs from me.
CONTEXT A — BRING-UP (2026-06-25)
During initial setup we hit:
• Long-running first update progress with little visible movement
• NVIDIA Sync “no configured devices,” then SSH authentication failure
• Difficulty reaching a usable Spark Terminal from documented host steps
• Local login lockout (passwords rejected; no reset from Mac)
• Needed wired keyboard/mouse + HDMI for reliable control
Resolution used: NVIDIA recovery USB → START RECOVERY (full erase), then a
new local account; Wi-Fi and Dashboard came up afterward.
Ask: Is there a non-destructive unlock/repair path for Sync/SSH/login
lockout so future units (or re-setup) can avoid full erase? Any checklist
you want followed on next bring-up?
CONTEXT B — LOCAL VIDEO STACK (2026-09-04)
Post-recovery health (approx.): SSH OK, GB10 listed, most of ~4 TB free,
RAM largely free when idle.
Observed when running common open video/still tooling (ComfyUI, Wan 2.1 14B,
Wan 2.2 5B, SDXL-class stills, TTS/audio packages):
• Wan 2.1 14B: diffusion steps completed, then process killed (apparent OOM
at VAE/save) — no usable output after a long run; short fallback ~1s
• Related models: startup failures (incomplete tokenizer files / missing
Python tokenizer dependency)
• Wan 2.2 image-to-video: multi-second clip with little useful motion after
a long wait
• apt update left hung for hours (likely interactive sudo/password)
Ask: For GB10, what resolution / frame count / offload settings are
validated for Wan 2.1 14B and Wan 2.2 5B? Which NGC or Dashboard playbook
should we follow instead of ad-hoc installs?
NEXT STEP
Happy to provide nvidia-smi, logs, and serial privately.
Looking for the recommended recovery + creative path so we can proceed
cleanly on this hardware.
Thank you,
S K
