I have been reading the shutdown threads here and wanted to share what happened after I went through the diagnostic and support process.
I am based in Singapore and bought my NVIDIA DGX Spark new through a third-party seller on Amazon. It started powering off completely during AI workloads, not just crashing the model or stopping a request.
The NVIDIA FieldDiag PowerStress test failed with MODS-020000600139, the same code I have seen other owners report here. The machine stayed on during the test and returned a failure. After reviewing the results, NVIDIA support confirmed a hardware fault and told me that replacement was required.
But manufacturer warranty support was declined because the seller was not an authorised reseller. That is the part I wanted to add to the discussion. Getting the fault confirmed did not mean I could get a warranty replacement through NVIDIA.
The Spark is already supporting services for a caregiver community, so taking it out of service is not a simple matter. For now, I have capped the GPU at 2200 MHz and limited inference to four concurrent sequences. This is keeping the services running, but the hardware fault is still unresolved. This is my own workaround, not a repair recommended by NVIDIA, and I do not know how it will hold up long term.
Honestly, this is not where I expected to be with a machine I bought new. I would much rather have a working unit that does not need this compromise.
Has anyone else been in a similar situation? I would be interested to hear how you handled it. Thanks in advance!
