DGX Spark kernel 7.0.0-1024-nvidia: summary of reported issues
I am collecting several recent reports related to 7.0.0-1024-nvidia.
The reported symptoms are not identical, so it is not yet clear whether they share a single root cause. However, several users reported that systems became stable again after rolling back to an older kernel.
Reported symptoms include:
- unexpected reboots while idle,
- repeated reboot loops,
- hard resets involving the hardware watchdog,
- GPU lockups with
Xid 13,Xid 154, andXid 109, - kernel Oops /
list_del corruption/ NULL pointer dereferences, - complete system freezes requiring a power cycle.
Several reports show the following pattern:
7.0.0-1024-nvidia -> unstable
7.0.0-1019-nvidia -> stable
6.17.0-1032-nvidia -> stable in some reports
There was also a reproducible HDMI/TMDS-triggered reset issue on 7.0.0-1024-nvidia.
For this issue, NVIDIA has released nvidia-spark-initcall-bl 1.0-2, which adds:
initcall_blacklist=power_wrap_init
Users have reported that this resolves the HDMI/display-related reset issue, so that specific problem appears to have a workaround/fix available now.
However, it is not yet clear whether the same update also addresses the other reported 7.0.0-1024-nvidia failures, such as GPU Xid errors, kernel Oops, memory corruption, or headless hard resets.
NVIDIA staff have acknowledged some of these reports and stated that they are investigating the issue.
At this point, 7.0.0-1024-nvidia still appears to have possible regressions beyond the display-related issue, although more than one independent bug may be involved.
It would be helpful if NVIDIA could clarify:
- whether the remaining reboot/Xid/kernel Oops reports are related,
- whether
nvidia-spark-initcall-bl 1.0-2is expected to address only the display/reboot-loop issue or a broader class of failures, - and whether another kernel update is planned.
If anyone is aware of other reproducible issues or related reports involving 7.0.0-1024-nvidia, please share them here as well. It would be useful to collect them in one place.
Related reports
Idle reboot after update to
7.0.0-1024
DGX Spark resetting at idle after latest DGX Dashboard update (kernel 7.0.0-1024) -
Repeated rebooting after recent update
DGX Spark repeatedly rebooting after most recent update -
HDMI/TMDS hard reset on
7.0.0-1024
Includes reports thatinitcall_blacklist=power_wrap_initfixes the issue, followed by NVIDIA’snvidia-spark-initcall-bl 1.0-2update.
Any use of the HDMI (TMDS) output causes a hard reset on kernel 7.0.0-1024-nvidia -
Xid 13/Xid 154/ kernel Oops / hard resets
DGX Spark: GPU lockup (Xid 13 FECS UCODE Fatal → Xid 154 Reset Required) and kernel Oops / hard resets on kernel 7.0.0-1024-nvidia — stable on 7.0.0-1 -
Intermittent system freezes
System gets frozen from time to time
