DGX Spark not detecting ethernet during initial setup
I’m trying to set up a DGX Spark on a secure work network with ethernet connected. I’ve confirmed that the network works but requires manual configuration and I cannot figure out how to do that during initial setup.
Any hints would be appreciated.
There is a adhoc secure SSID . Using your laptop, connects to the SSID. Details including preshared key will be in one of the small paper guide somewhere in the box. It will automatically redirect you to a simple web page to complete the setup. Just follows the instructions on the web page. You can also go through the local KVM if you have them.
I’ve tried that but it still asks me to connect to WiFi.
Yes, you need to connect to the Wifi until the setup is completed. Once that is done, depending on how your management IP is setup, you will be able to connect to the Spark.
That’s not an option. I need to configure it to use the Ethernet for setup.
