DGX Spark not installing CUDA, Nemotron, vllm, etc
Hi, I just got my new DGX Spark, but I’m constantly running into issues when downloading things I need for my project.
For example, when I tried to use AI Workbench and JupyterLab, it said CUDA wasn’t working, and that my GPU was not connected somehow, and there was no CUDA kernel. Then, when I went to the terminal and tried installing different versions of CUDA, it worked once and then proceeded to fail. I also tried installing Nemotron models, but it kept saying “Unable to correct problem, you have held broken packages”. I’ve been working on fixing this for hours but I’ve gotten nowhere.
Is it because I’m new to Linux or is it just not working? Can someone please help me? I would be really grateful.
And also, I’m trying to run Nemotron 3 Nano 30B locally on the Spark, but it just doesn’t work. Error logs say that it’s trying to get 90% of GPU memory, but that’s not enough for some reason because the Spark doesn’t have enough memory left?? It’s new though I didn’t even run much on it yet. Weird.
We should address your CUDA issue first. Do you get proper output when you run commands like nvidia-smi and nvcc --version?
I got CUDA 12.0 for nvcc —version, and for some reason my GB10 chip is GPU 0 when I run nvidia-smi.
Your CUDA package is definitely not the one that comes preinstalled on your device. What is your driver version? You can check with nvidia-smi, it should be 580.95.05. I would recommend reimaging your system to make sure you have all of the right packages.
Example output
nvidia@spark-ba5cf7:~$ nvidia-smi
Fri Jan 30 17:16:53 2026
| NVIDIA-SMI  580.95.05            Driver Version:  580.95.05     CUDA Version: 13.0     |
|   0  NVIDIA GB10                    On  |   0000000F:01:00.0 Off |                  N/A |
| N/A   44C    P0             11W /  N/A  | Not Supported          |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI              PID   Type   Process name                        GPU Memory |
|        ID   ID                                                               Usage      |
|    0   N/A  N/A          104192      C   ./bin/llama-server                    38800MiB |
|    0   N/A  N/A          206596      G   /usr/lib/xorg/Xorg                       63MiB |
|    0   N/A  N/A          206744      G   /usr/bin/gnome-shell                     60MiB |
nvidia@spark-ba5cf7:~$ nvcc --version
Copyright (c) 2005-2025 NVIDIA Corporation
Built on Wed_Aug_20_01:57:39_PM_PDT_2025
Cuda compilation tools, release 13.0, V13.0.88
Build cuda_13.0.r13.0/compiler.36424714_0
Hi, I successfully rebooted my entire DGX Spark system, and now everything works. Thank you very much for your help!
