DGX Spark Observed Behaviour – Power Draw / Performance Discrepancy
cCuld you clarify what’s going on with the DGX Spark power and performance behavior that @ID_AA_Carmack pointed out here:
https://x.com/id_aa_carmack/status/1982831774850748825
He mentioned it’s only drawing around 100 W (less than half of the rated 240 W) and delivering roughly half the expected performance.
I’m trying to understand if this is:
  • firmware or driver power cap
  • thermal constraint / power mode issue
  • or simply expected behavior depending on FP4 vs FP8 workloads.
Is the 1 PFLOP FP4 figure on the DGX Spark spec sheet theoretical (peak) or achievable in practice under specific conditions (sparsity, FP4+INT, etc.)?
I’m also noting some interesting … power discrepancies here. I really love the Spark so far but the experience has been pretty rough and a fair bit slower than envisioned/advertised. I’d love an answer before deciding if keeping it long term is for me. :/
DGX Spark’s peak total system power is 240W. The TDP of the GB10 SOC which includes the GPU and the CPU is 140W. The rest of the system which includes the ConnectX-7, SSD and provisions for USB-C devices is 100W.
If you are measuring power with NVIDIA SMI then you are only measuring GPU power.
Hard to say. Running Furmark 2, I’m getting ~RTX 5070 Laptop performance. The 5070 laptop has more memory bandwidth but fewer cores. So at least using those sorts of benchmarks, the GB10 seems OK. The magic of the DGX Spark over something like the RTX5070 is obviously RAM and DGX OS.
I’m having the same behavior. Pretty slow on inference, and I never rise above 100W.
I think the inference is to be expected due to the memory bandwidth, but the power draw is still in the works that need to be tested.
How are you using yours? Any Training?
