I’m having multiple issues with my DGX Spark. Within 15 minutes of turning on the system and while downloading two AI models in LM Studio with the system using less than 10% of the CPU and RAM, the system will freeze and become extremely hot to the point where it’s unsafe to touch and if the fans running, you can’t hear them. I have to manually shut it off and wait for it to cool down before I can use it again.
During my initial contact with customer support they wanted me to install the NVIDIA DGX Spark Field Diagnostics tool. When following the instructions to set it up I get the following error message:
My case was escalated and I was then instructed by tech support to use the following two commands:
Support: Check which configuration files are currently referencing the NVIDIA CUDA repository: grep -Rni "Index of /compute/cuda/repos/ubuntu2404/sbsa" /etc/apt/sources.list /etc/apt/sources.list.d/ 2>/dev/null
Output:
/etc/apt/sources.list.d/cuda-sbsa-ubuntu2404.list:1:deb [signed-by=/usr/share/keyrings/cuda-archive-keyring.gpg] Index of /compute/cuda/repos/ubuntu2404/sbsa //etc/apt/sources.list.d/cuda-compute-repo.sources:2:URIs: (Same “Index of …” error message as on the line above. I’m limited to four links in a post as a new user of the forums so I can’t put the link.)
Support: Check which NVIDIA CUDA keyrings are currently present: ls -l /usr/share/keyrings/cuda*.gpg
Output:
-rw-r–r-- 1 root root 1134 Aug 14 15:52 /usr/share/keyrings/cuda-archive-keyring.gpg
-rw-r–r-- 1 root root 1134 Feb 24 09:42 /usr/share/keyrings/cuda_debian_prod.gpg
All of the latest updates have been applied.
Tech support recommended I post the issue here while they continue to investigate the issue.
Before we can diagnose the overheating issue, we need Field Diagnostics results — so let’s get that install error sorted first.
The Signed-By conflict is caused by a documentation error in the Field Diagnostics guide. The guide incorrectly instructs DGX Spark users to add the CUDA apt repository, but DGX Spark OS already ships with that repo pre-configured under a different keyring name. To resolve it, remove the duplicate entry that was added:
I ran the two commands and then sudo apt-get install dgx-spark-fieldiag and got:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
dgx-spark-fieldiag : Depends: ofed-scripts but it is not installable
E: Unable to correct problems, you have held broken packages.
Joining this thread as I’m working through what sounds like a similar issue with my OEM DGX Spark.
I have completed the above commands modified with sudo successfully, then run sudo apt-get update. Then, the Field Diagnostic User Guide instructs to run
sudo apt-get -y install doca-ofed
which does not complete. It hangs after moving efficiently through much of what appears to be a normal install log. The system remains responsive on other SSH sessions, but the session in question does retain a lock on the dpkg frontend. There is no load on CPU or GPU and total RAM usage is under 10GB; it appears idling (not compiling). I’m pasting the entire output of the above command.
This has been hung at the below point for over 2 hours at time of posting:
The following packages were automatically installed and are no longer required:
libibnetdisc5t64 libwoff1 linux-headers-6.17.0-1014-nvidia linux-headers-6.17.0-1018-nvidia linux-image-6.17.0-1014-nvidia linux-image-6.17.0-1018-nvidia linux-modules-6.17.0-1014-nvidia linux-modules-6.17.0-1018-nvidia linux-modules-nvidia-fs-6.11.0-1014-nvidia linux-modules-nvidia-fs-6.14.0-1015-nvidia
linux-modules-nvidia-fs-6.17.0-1014-nvidia linux-modules-nvidia-fs-6.17.0-1018-nvidia linux-nvidia-6.11-tools-6.11.0-1014 linux-nvidia-6.14-tools-6.14.0-1015 linux-nvidia-6.17-headers-6.17.0-1014 linux-nvidia-6.17-headers-6.17.0-1018 linux-nvidia-6.17-tools-6.17.0-1014 linux-nvidia-6.17-tools-6.17.0-1018
linux-tools-6.11.0-1014-nvidia linux-tools-6.14.0-1015-nvidia linux-tools-6.17.0-1014-nvidia linux-tools-6.17.0-1018-nvidia nvidia-firmware-580-580.126.09 nvidia-firmware-580-580.142 nvidia-firmware-580-580.159.03 nvidia-firmware-580-580.95.05
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
dkms doca-sosreport dpcp fakeroot ibacm ibarr ibdump ibsim ibsim-doc ibutils2 ibverbs-providers ibverbs-utils infiniband-diags iser-dkms isert-dkms kernel-mft-dkms libfakeroot libfuse2t64 libibmad-dev libibmad5 libibnetdisc5 libibumad-dev libibumad3 libibverbs-dev libibverbs1 libopensm libopensm-devel
librdmacm-dev librdmacm1 mft mft-mlx5 mft-nvredfish mlnx-ethtool mlnx-iproute2 mlnx-ofed-kernel-dkms mlnx-ofed-kernel-utils mlnx-tools ofed-scripts openmpi opensm opensm-doc pahole perftest rdma-core rdmacm-utils rshim srp-dkms srptools ucx xpmem xpmem-dkms
Suggested packages:
menu
The following packages will be REMOVED:
libucx0 nvidia-mlnx-tools sosreport ucx-utils
The following NEW packages will be installed:
dkms doca-ofed doca-sosreport dpcp fakeroot ibacm ibarr ibdump ibsim ibsim-doc ibutils2 iser-dkms isert-dkms kernel-mft-dkms libfakeroot libfuse2t64 libibmad-dev libibnetdisc5 libibumad-dev libopensm libopensm-devel librdmacm1 mft mft-mlx5 mft-nvredfish mlnx-ethtool mlnx-iproute2 mlnx-ofed-kernel-dkms
mlnx-ofed-kernel-utils mlnx-tools ofed-scripts openmpi opensm opensm-doc pahole rshim srp-dkms ucx xpmem xpmem-dkms
The following packages will be upgraded:
ibverbs-providers ibverbs-utils infiniband-diags libibmad5 libibumad3 libibverbs-dev libibverbs1 librdmacm-dev perftest rdma-core rdmacm-utils srptools
12 upgraded, 40 newly installed, 4 to remove and 10 not upgraded.
Need to get 76.4 MB of archives.
After this operation, 328 MB of additional disk space will be used.
Get:1 http://ports.ubuntu.com/ubuntu-ports noble/universe arm64 pahole arm64 1.25-0ubuntu3 [275 kB]
Get:2 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ ucx 1.20.0-1.20260211.d9a4f352d.2601100 [1,738 kB]
Get:3 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2404/sbsa dkms 1:3.4.1-1ubuntu1 [57.0 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports noble/universe arm64 libfuse2t64 arm64 2.9.9-8.1build1 [89.9 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports noble/main arm64 libfakeroot arm64 1.33-1 [32.5 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports noble/main arm64 fakeroot arm64 1.33-1 [66.9 kB]
Get:7 https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2404/sbsa mft 4.35.0.159-1 [36.4 MB]
Get:8 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ doca-sosreport 4.9.0-4 [374 kB]
Get:9 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ libibumad3 2601.0.7-1 [28.0 kB]
Get:10 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ libibverbs-dev 2601.0.7-1 [542 kB]
Get:11 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ ibverbs-providers 2601.0.7-1 [239 kB]
Get:12 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ libibverbs1 2601.0.7-1 [66.5 kB]
Get:13 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ ibarr 2601.0.0-1 [17.3 kB]
Get:14 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ libibmad5 2601.0.7-1 [44.1 kB]
Get:15 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ libibnetdisc5 2601.0.7-1 [32.0 kB]
Get:16 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ librdmacm1 2601.0.7-1 [72.5 kB]
Get:17 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ rdma-core 2601.0.7-1 [43.0 kB]
Get:18 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ infiniband-diags 2601.0.7-1 [239 kB]
Get:19 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ dpcp 1.1.59 [1,966 kB]
Get:20 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ xpmem 2601.0.9-1 [1,786 B]
Get:21 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ ibsim-doc 0.12.1-4 [2,134 B]
Get:22 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ mlnx-tools 2601.0.2-1 [72.3 kB]
Get:23 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ mlnx-ofed-kernel-utils 26.01.OFED.26.01.1.0.0.1-1 [29.1 kB]
Get:24 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ mlnx-ofed-kernel-dkms 26.01.OFED.26.01.1.0.0.1-1 [2,751 kB]
Get:25 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ mft-mlx5 4.35.0-159 [1,138 kB]
Get:26 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ rshim 2.6.6-0.g0ff6d20.2601100 [106 kB]
Get:27 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ librdmacm-dev 2601.0.7-1 [136 kB]
Get:28 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ xpmem-dkms 2601.0.9-1 [33.5 kB]
Get:29 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ ibacm 2601.0.7-1 [87.1 kB]
Get:30 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ libopensm 5.26.1-202601271032.8c07ef43.2601100 [893 kB]
Get:31 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ isert-dkms 26.01.OFED.26.01.1.0.0.1-1 [22.4 kB]
Get:32 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ mlnx-iproute2 2601.0.6-1 [1,088 kB]
Get:33 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ opensm-doc 5.26.1-202601271032.8c07ef43.2601100 [855 kB]
Get:34 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ libibmad-dev 2601.0.7-1 [57.9 kB]
Get:35 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ ibutils2 2.1.1-0.22400.MLNX202601152019.ge04c0b67f [3,655 kB]
Get:36 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ kernel-mft-dkms 4.35.0.159-1 [38.4 kB]
Get:37 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ srptools 2601.0.7-1 [41.6 kB]
Get:38 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ iser-dkms 26.01.OFED.26.01.1.0.0.1-1 [29.4 kB]
Get:39 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ ofed-scripts 26.01.OFED.26.01.1.0.0-1 [54.9 kB]
Get:40 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ libopensm-devel 5.26.1-202601271032.8c07ef43.2601100 [1,108 kB]
Get:41 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ libibumad-dev 2601.0.7-1 [58.0 kB]
Get:42 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ openmpi 4.1.9a1-1.20260211.81d402c97a.2601100 [16.9 MB]
Get:43 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ srp-dkms 26.01.OFED.26.01.1.0.0.1-1 [42.7 kB]
Get:44 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ mlnx-ethtool 2601.0.2-1 [290 kB]
Get:45 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ ibsim 0.12.1-4 [56.7 kB]
Get:46 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ perftest 26.01.5-1 [375 kB]
Get:47 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ ibdump 6.0.0-2 [224 kB]
Get:48 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ mft-nvredfish 4.35.0-159 [1,824 kB]
Get:49 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ ibverbs-utils 2601.0.7-1 [57.8 kB]
Get:50 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ opensm 5.26.1-202601271032.8c07ef43.2601100 [1,946 kB]
Get:51 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ rdmacm-utils 2601.0.7-1 [82.8 kB]
Get:52 https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa ./ doca-ofed 3.3.0-088000 [1,970 B]
Fetched 76.4 MB in 33s (2,284 kB/s)
Extracting templates from packages: 100%
(Reading database ... 491145 files and directories currently installed.)
Removing ucx-utils (1.16.0+ds-5ubuntu1) ...
dpkg: libucx0:arm64: dependency problems, but removing anyway as you requested:
libopenmpi3t64:arm64 depends on libucx0 (>= 1.16.0+ds).
Removing libucx0:arm64 (1.16.0+ds-5ubuntu1) ...
Selecting previously unselected package ucx.
(Reading database ... 491115 files and directories currently installed.)
Preparing to unpack .../ucx_1.20.0-1.20260211.d9a4f352d.2601100_arm64.deb ...
Unpacking ucx (1.20.0-1.20260211.d9a4f352d.2601100) ...
(Reading database ... 491316 files and directories currently installed.)
Removing nvidia-mlnx-tools (23.04) ...
dpkg: sosreport: dependency problems, but removing anyway as you requested:
ubuntu-server depends on sosreport.
nvidia-system-extra depends on sosreport.
Removing sosreport (4.10.2-0ubuntu0~24.04.1) ...
Selecting previously unselected package doca-sosreport.
(Reading database ... 490748 files and directories currently installed.)
Preparing to unpack .../00-doca-sosreport_4.9.0-4_arm64.deb ...
Unpacking doca-sosreport (4.9.0-4) ...
Selecting previously unselected package pahole.
Preparing to unpack .../01-pahole_1.25-0ubuntu3_arm64.deb ...
Unpacking pahole (1.25-0ubuntu3) ...
Selecting previously unselected package dkms.
Preparing to unpack .../02-dkms_1%3a3.4.1-1ubuntu1_all.deb ...
Unpacking dkms (1:3.4.1-1ubuntu1) ...
Preparing to unpack .../03-libibumad3_2601.0.7-1_arm64.deb ...
Unpacking libibumad3:arm64 (2601.0.7-1) over (50.0-2ubuntu0.2) ...
Preparing to unpack .../04-libibverbs-dev_2601.0.7-1_arm64.deb ...
Unpacking libibverbs-dev:arm64 (2601.0.7-1) over (50.0-2ubuntu0.2) ...
Preparing to unpack .../05-ibverbs-providers_2601.0.7-1_arm64.deb ...
Unpacking ibverbs-providers:arm64 (2601.0.7-1) over (50.0-2ubuntu0.2) ...
Preparing to unpack .../06-libibverbs1_2601.0.7-1_arm64.deb ...
Unpacking libibverbs1:arm64 (2601.0.7-1) over (50.0-2ubuntu0.2) ...
Selecting previously unselected package ibarr:arm64.
Preparing to unpack .../07-ibarr_2601.0.0-1_arm64.deb ...
Unpacking ibarr:arm64 (2601.0.0-1) ...
Preparing to unpack .../08-libibmad5_2601.0.7-1_arm64.deb ...
Unpacking libibmad5:arm64 (2601.0.7-1) over (50.0-2ubuntu0.2) ...
Selecting previously unselected package libibnetdisc5:arm64.
Preparing to unpack .../09-libibnetdisc5_2601.0.7-1_arm64.deb ...
Unpacking libibnetdisc5:arm64 (2601.0.7-1) ...
Replaced by files in installed package libibnetdisc5t64:arm64 (50.0-2ubuntu0.2) ...
Selecting previously unselected package librdmacm1:arm64.
Preparing to unpack .../10-librdmacm1_2601.0.7-1_arm64.deb ...
Unpacking librdmacm1:arm64 (2601.0.7-1) ...
Replaced by files in installed package librdmacm1t64:arm64 (50.0-2ubuntu0.2) ...
Preparing to unpack .../11-rdma-core_2601.0.7-1_arm64.deb ...
Unpacking rdma-core (2601.0.7-1) over (50.0-2ubuntu0.2) ...
Preparing to unpack .../12-infiniband-diags_2601.0.7-1_arm64.deb ...
Unpacking infiniband-diags (2601.0.7-1) over (50.0-2ubuntu0.2) ...
Selecting previously unselected package dpcp.
Preparing to unpack .../13-dpcp_1.1.59_arm64.deb ...
Unpacking dpcp (1.1.59) ...
Selecting previously unselected package xpmem.
Preparing to unpack .../14-xpmem_2601.0.9-1_all.deb ...
Unpacking xpmem (2601.0.9-1) ...
Selecting previously unselected package ibsim-doc.
Preparing to unpack .../15-ibsim-doc_0.12.1-4_all.deb ...
Unpacking ibsim-doc (0.12.1-4) ...
Selecting previously unselected package mlnx-tools.
Preparing to unpack .../16-mlnx-tools_2601.0.2-1_arm64.deb ...
Unpacking mlnx-tools (2601.0.2-1) ...
Selecting previously unselected package mlnx-ofed-kernel-utils.
Preparing to unpack .../17-mlnx-ofed-kernel-utils_26.01.OFED.26.01.1.0.0.1-1_arm64.deb ...
Unpacking mlnx-ofed-kernel-utils (26.01.OFED.26.01.1.0.0.1-1) ...
Selecting previously unselected package mlnx-ofed-kernel-dkms.
Preparing to unpack .../18-mlnx-ofed-kernel-dkms_26.01.OFED.26.01.1.0.0.1-1_all.deb ...
Unpacking mlnx-ofed-kernel-dkms (26.01.OFED.26.01.1.0.0.1-1) ...
Selecting previously unselected package mft.
Preparing to unpack .../19-mft_4.35.0.159-1_arm64.deb ...
Unpacking mft (4.35.0.159-1) ...
Selecting previously unselected package mft-mlx5.
Preparing to unpack .../20-mft-mlx5_4.35.0-159_arm64.deb ...
Unpacking mft-mlx5 (4.35.0-159) ...
Selecting previously unselected package libfuse2t64:arm64.
Preparing to unpack .../21-libfuse2t64_2.9.9-8.1build1_arm64.deb ...
Unpacking libfuse2t64:arm64 (2.9.9-8.1build1) ...
Selecting previously unselected package rshim.
Preparing to unpack .../22-rshim_2.6.6-0.g0ff6d20.2601100_arm64.deb ...
Unpacking rshim (2.6.6-0.g0ff6d20.2601100) ...
Preparing to unpack .../23-librdmacm-dev_2601.0.7-1_arm64.deb ...
Unpacking librdmacm-dev:arm64 (2601.0.7-1) over (50.0-2ubuntu0.2) ...
Selecting previously unselected package xpmem-dkms.
Preparing to unpack .../24-xpmem-dkms_2601.0.9-1_all.deb ...
Unpacking xpmem-dkms (2601.0.9-1) ...
Selecting previously unselected package ibacm.
Preparing to unpack .../25-ibacm_2601.0.7-1_arm64.deb ...
Unpacking ibacm (2601.0.7-1) ...
Selecting previously unselected package libopensm.
Preparing to unpack .../26-libopensm_5.26.1-202601271032.8c07ef43.2601100_arm64.deb ...
Unpacking libopensm (5.26.1-202601271032.8c07ef43.2601100) ...
Selecting previously unselected package isert-dkms.
Preparing to unpack .../27-isert-dkms_26.01.OFED.26.01.1.0.0.1-1_all.deb ...
Unpacking isert-dkms (26.01.OFED.26.01.1.0.0.1-1) ...
Selecting previously unselected package mlnx-iproute2.
Preparing to unpack .../28-mlnx-iproute2_2601.0.6-1_arm64.deb ...
Unpacking mlnx-iproute2 (2601.0.6-1) ...
Selecting previously unselected package opensm-doc.
Preparing to unpack .../29-opensm-doc_5.26.1-202601271032.8c07ef43.2601100_arm64.deb ...
Unpacking opensm-doc (5.26.1-202601271032.8c07ef43.2601100) ...
Selecting previously unselected package libibmad-dev:arm64.
Preparing to unpack .../30-libibmad-dev_2601.0.7-1_arm64.deb ...
Unpacking libibmad-dev:arm64 (2601.0.7-1) ...
Selecting previously unselected package ibutils2.
Preparing to unpack .../31-ibutils2_2.1.1-0.22400.MLNX202601152019.ge04c0b67f_arm64.deb ...
Unpacking ibutils2 (2.1.1-0.22400.MLNX202601152019.ge04c0b67f) ...
Selecting previously unselected package kernel-mft-dkms.
Preparing to unpack .../32-kernel-mft-dkms_4.35.0.159-1_all.deb ...
Unpacking kernel-mft-dkms (4.35.0.159-1) ...
Preparing to unpack .../33-srptools_2601.0.7-1_arm64.deb ...
Unpacking srptools (2601.0.7-1) over (50.0-2ubuntu0.2) ...
Selecting previously unselected package iser-dkms.
Preparing to unpack .../34-iser-dkms_26.01.OFED.26.01.1.0.0.1-1_all.deb ...
Unpacking iser-dkms (26.01.OFED.26.01.1.0.0.1-1) ...
Selecting previously unselected package ofed-scripts.
Preparing to unpack .../35-ofed-scripts_26.01.OFED.26.01.1.0.0-1_arm64.deb ...
Unpacking ofed-scripts (26.01.OFED.26.01.1.0.0-1) ...
Selecting previously unselected package libopensm-devel.
Preparing to unpack .../36-libopensm-devel_5.26.1-202601271032.8c07ef43.2601100_arm64.deb ...
Unpacking libopensm-devel (5.26.1-202601271032.8c07ef43.2601100) ...
Selecting previously unselected package libibumad-dev:arm64.
Preparing to unpack .../37-libibumad-dev_2601.0.7-1_arm64.deb ...
Unpacking libibumad-dev:arm64 (2601.0.7-1) ...
Selecting previously unselected package openmpi.
Preparing to unpack .../38-openmpi_4.1.9a1-1.20260211.81d402c97a.2601100_all.deb ...
Unpacking openmpi (4.1.9a1-1.20260211.81d402c97a.2601100) ...
Selecting previously unselected package srp-dkms.
Preparing to unpack .../39-srp-dkms_26.01.OFED.26.01.1.0.0.1-1_all.deb ...
Unpacking srp-dkms (26.01.OFED.26.01.1.0.0.1-1) ...
Selecting previously unselected package mlnx-ethtool.
Preparing to unpack .../40-mlnx-ethtool_2601.0.2-1_arm64.deb ...
Unpacking mlnx-ethtool (2601.0.2-1) ...
Selecting previously unselected package ibsim.
Preparing to unpack .../41-ibsim_0.12.1-4_arm64.deb ...
Unpacking ibsim (0.12.1-4) ...
Preparing to unpack .../42-perftest_26.01.5-1_arm64.deb ...
Unpacking perftest (26.01.5-1) over (24.01.0+0.38-1build2) ...
Selecting previously unselected package ibdump.
Preparing to unpack .../43-ibdump_6.0.0-2_arm64.deb ...
Unpacking ibdump (6.0.0-2) ...
Selecting previously unselected package mft-nvredfish.
Preparing to unpack .../44-mft-nvredfish_4.35.0-159_arm64.deb ...
Unpacking mft-nvredfish (4.35.0-159) ...
Preparing to unpack .../45-ibverbs-utils_2601.0.7-1_arm64.deb ...
Unpacking ibverbs-utils (2601.0.7-1) over (50.0-2ubuntu0.2) ...
Selecting previously unselected package opensm.
Preparing to unpack .../46-opensm_5.26.1-202601271032.8c07ef43.2601100_arm64.deb ...
Unpacking opensm (5.26.1-202601271032.8c07ef43.2601100) ...
Preparing to unpack .../47-rdmacm-utils_2601.0.7-1_arm64.deb ...
Unpacking rdmacm-utils (2601.0.7-1) over (50.0-2ubuntu0.2) ...
Selecting previously unselected package doca-ofed.
Preparing to unpack .../48-doca-ofed_3.3.0-088000_arm64.deb ...
Unpacking doca-ofed (3.3.0-088000) ...
Selecting previously unselected package libfakeroot:arm64.
Preparing to unpack .../49-libfakeroot_1.33-1_arm64.deb ...
Unpacking libfakeroot:arm64 (1.33-1) ...
Selecting previously unselected package fakeroot.
Preparing to unpack .../50-fakeroot_1.33-1_arm64.deb ...
Unpacking fakeroot (1.33-1) ...
Setting up libibverbs1:arm64 (2601.0.7-1) ...
Setting up ibverbs-providers:arm64 (2601.0.7-1) ...
Removing obsolete conffile /etc/libibverbs.d/bnxt_re.driver ...
Removing obsolete conffile /etc/libibverbs.d/cxgb4.driver ...
Removing obsolete conffile /etc/libibverbs.d/efa.driver ...
Removing obsolete conffile /etc/libibverbs.d/erdma.driver ...
Removing obsolete conffile /etc/libibverbs.d/hfi1verbs.driver ...
Removing obsolete conffile /etc/libibverbs.d/hns.driver ...
Removing obsolete conffile /etc/libibverbs.d/ipathverbs.driver ...
Removing obsolete conffile /etc/libibverbs.d/irdma.driver ...
Removing obsolete conffile /etc/libibverbs.d/mana.driver ...
Removing obsolete conffile /etc/libibverbs.d/mlx4.driver ...
Removing obsolete conffile /etc/libibverbs.d/mthca.driver ...
Removing obsolete conffile /etc/libibverbs.d/ocrdma.driver ...
Removing obsolete conffile /etc/libibverbs.d/qedr.driver ...
Removing obsolete conffile /etc/libibverbs.d/rxe.driver ...
Removing obsolete conffile /etc/libibverbs.d/siw.driver ...
Removing obsolete conffile /etc/libibverbs.d/vmw_pvrdma.driver ...
Setting up mlnx-iproute2 (2601.0.6-1) ...
Setting up libibumad3:arm64 (2601.0.7-1) ...
Setting up libopensm (5.26.1-202601271032.8c07ef43.2601100) ...
Setting up mlnx-ethtool (2601.0.2-1) ...
Setting up ibsim-doc (0.12.1-4) ...
Setting up libibmad5:arm64 (2601.0.7-1) ...
Setting up mlnx-tools (2601.0.2-1) ...
Setting up libibverbs-dev:arm64 (2601.0.7-1) ...
Setting up xpmem (2601.0.9-1) ...
Setting up libfakeroot:arm64 (1.33-1) ...
Setting up ibsim (0.12.1-4) ...
Setting up fakeroot (1.33-1) ...
update-alternatives: using /usr/bin/fakeroot-sysv to provide /usr/bin/fakeroot (fakeroot) in auto mode
Setting up libibumad-dev:arm64 (2601.0.7-1) ...
Setting up ibverbs-utils (2601.0.7-1) ...
Setting up dpcp (1.1.59) ...
Setting up ofed-scripts (26.01.OFED.26.01.1.0.0-1) ...
Setting up opensm (5.26.1-202601271032.8c07ef43.2601100) ...
Setting up libibnetdisc5:arm64 (2601.0.7-1) ...
Setting up pahole (1.25-0ubuntu3) ...
Setting up libibmad-dev:arm64 (2601.0.7-1) ...
Setting up mlnx-ofed-kernel-utils (26.01.OFED.26.01.1.0.0.1-1) ...
Configured /etc/security/limits.conf
Setting up ucx (1.20.0-1.20260211.d9a4f352d.2601100) ...
Setting up opensm-doc (5.26.1-202601271032.8c07ef43.2601100) ...
Setting up doca-sosreport (4.9.0-4) ...
Installing new version of config file /etc/sos/sos.conf ...
Setting up rdma-core (2601.0.7-1) ...
Setting up libfuse2t64:arm64 (2.9.9-8.1build1) ...
Setting up ibdump (6.0.0-2) ...
Setting up ibutils2 (2.1.1-0.22400.MLNX202601152019.ge04c0b67f) ...
Setting up mft (4.35.0.159-1) ...
Setting up rdmacm-utils (2601.0.7-1) ...
Setting up librdmacm1:arm64 (2601.0.7-1) ...
Setting up libopensm-devel (5.26.1-202601271032.8c07ef43.2601100) ...
Setting up mft-mlx5 (4.35.0-159) ...
Setting up infiniband-diags (2601.0.7-1) ...
Setting up ibarr:arm64 (2601.0.0-1) ...
Setting up perftest (26.01.5-1) ...
Setting up openmpi (4.1.9a1-1.20260211.81d402c97a.2601100) ...
Setting up dkms (1:3.4.1-1ubuntu1) ...
Setting up srptools (2601.0.7-1) ...
Installing new version of config file /etc/default/srptools ...
Setting up kernel-mft-dkms (4.35.0.159-1) ...
Loading new kernel-mft-dkms-4.35.0.159 DKMS files...
Deprecated feature: CLEAN (/usr/src/kernel-mft-dkms-4.35.0.159/dkms.conf)
First Installation: checking all kernels...
Building only for 6.17.0-1031-nvidia
Building for architecture aarch64
Building initial module for 6.17.0-1031-nvidia
Deprecated feature: CLEAN (/var/lib/dkms/kernel-mft-dkms/4.35.0.159/source/dkms.conf)
Leaving this alone for another few hours. I really do not like terminating apt-get midstream, but it feels like it’s hung - advice appreciated.
Edit: This session remains hung 10 hours after the command was run.
Hmm, weird. Can you get the end of the dpkg log? tail -30 /var/log/dpkg.log
It records the real last configure line, unbuffered. systemctl list-jobs will show a stuck job immediately if that’s it.
To recover, try killing the process, then sudo dpkg --configure -a to resume the job.
2026-08-26 11:17:43 configure ibarr:arm64 2601.0.0-1 <none>
2026-08-26 11:17:43 status unpacked ibarr:arm64 2601.0.0-1
2026-08-26 11:17:44 status half-configured ibarr:arm64 2601.0.0-1
2026-08-26 11:17:44 status installed ibarr:arm64 2601.0.0-1
2026-08-26 11:17:44 configure perftest:arm64 26.01.5-1 <none>
2026-08-26 11:17:44 status unpacked perftest:arm64 26.01.5-1
2026-08-26 11:17:44 status half-configured perftest:arm64 26.01.5-1
2026-08-26 11:17:44 status installed perftest:arm64 26.01.5-1
2026-08-26 11:17:44 configure openmpi:all 4.1.9a1-1.20260211.81d402c97a.2601100 <none>
2026-08-26 11:17:44 status unpacked openmpi:all 4.1.9a1-1.20260211.81d402c97a.2601100
2026-08-26 11:17:44 status half-configured openmpi:all 4.1.9a1-1.20260211.81d402c97a.2601100
2026-08-26 11:17:44 status installed openmpi:all 4.1.9a1-1.20260211.81d402c97a.2601100
2026-08-26 11:17:44 configure dkms:all 1:3.4.1-1ubuntu1 <none>
2026-08-26 11:17:44 status unpacked dkms:all 1:3.4.1-1ubuntu1
2026-08-26 11:17:44 status half-configured dkms:all 1:3.4.1-1ubuntu1
2026-08-26 11:17:44 status installed dkms:all 1:3.4.1-1ubuntu1
2026-08-26 11:17:44 configure srptools:arm64 2601.0.7-1 <none>
2026-08-26 11:17:44 status unpacked srptools:arm64 2601.0.7-1
2026-08-26 11:17:44 status half-configured srptools:arm64 2601.0.7-1
2026-08-26 11:17:44 status installed srptools:arm64 2601.0.7-1
2026-08-26 11:17:44 configure kernel-mft-dkms:all 4.35.0.159-1 <none>
2026-08-26 11:17:44 status unpacked kernel-mft-dkms:all 4.35.0.159-1
2026-08-26 11:17:44 status half-configured kernel-mft-dkms:all 4.35.0.159-1
No job is listed as stuck - but I’m not familiar with the one listed as running. This unit is completely idle.
JOB UNIT TYPE STATE
159 plymouth-quit-wait.service start running
1 graphical.target start waiting
80 setvtrgb.service start waiting
243 serial-getty@ttyS0.service start waiting
254 systemd-update-utmp-runlevel.service start waiting
249 system-getty.slice start waiting
2 multi-user.target start waiting
241 getty.target start waiting
8 jobs listed.
I killed the session (which was still frozen ~36 hours later) and sudo dpkg --configure -a errors with the message
dpkg: error: dpkg frontend lock was locked by another process with pid 41861
Note: removing the lock file is always wrong, can damage the locked area
and the entire system. See <https://wiki.debian.org/Teams/Dpkg/FAQ#db-lock>.
I then had to specifically run sudo kill 41861 to clear the lock and allow sudo dpkg --configure -a to resume.
After resuming it seemed to finish successfully. Thanks for the guidance!
Please check the contents of this file /etc/apt/sources.list.d/doca.list and make sure it is in a proper format. Should just be one line (unless you added something else, of course) deb [signed-by=/etc/apt/trusted.gpg.d/GPG-KEY-Mellanox.pub] https://linux.mellanox.com/public/repo/doca/3.3.0/ubuntu24.04/arm64-sbsa/ ./
My file only had deb [signed-by=/etc/apt/trusted.gpg.d/GPG-KEY-Mellanox.pub] ./ I changed it to what you listed and I was able to do the update. I went through the rest of the Field Diagnostics and the ibstress test failed.
Glad to see it is running now. Unfortunately, a failing FD usually means there is a hardware issue. Please share the FD logs with me, and open a ticket with customer support to request RMA NVIDIA DGX Spark Support
