DGX Spark Playbooks: Agentic RAG: Chat UI errors out
I’m trying out the “RAG Application in AI Workbench“ RAG chat UI playbook. I could start the container and view the GUI:
However, when I send a user input, I get the following 403 error:
File “/home/workbench/.local/lib/python3.10/site-packages/langchain_core/language_models/chat_models.py”, line 842, in generate
self.\_generate_with_cache(
File “/home/workbench/.local/lib/python3.10/site-packages/langchain_core/language_models/chat_models.py”, line 1091, in _generate_with_cache
result = self.\_generate(
File “/home/workbench/.local/lib/python3.10/site-packages/langchain_nvidia_ai_endpoints/chat_models.py”, line 382, in _generate
response = self.\_client.get_req(payload=payload, extra_headers=extra_headers)
File “/home/workbench/.local/lib/python3.10/site-packages/langchain_nvidia_ai_endpoints/_common.py”, line 473, in get_req
response, session = self.\_post(
File “/home/workbench/.local/lib/python3.10/site-packages/langchain_nvidia_ai_endpoints/_common.py”, line 369, in _post
self.\_try_raise(response)
File “/home/workbench/.local/lib/python3.10/site-packages/langchain_nvidia_ai_endpoints/_common.py”, line 462, in _try_raise
raise Exception(f"{header}\\n{body}") from None
Exception: [403] Forbidden
Authorization failed
-–ROUTE QUESTION—
Hi
I got the NVIDIA personal key with the following authorizations:
Appreciate your help in debugging this issue. Thanks in advance!
According to the playbook, your API key needs Public API Endpoints permissions
Thank you for getting back. I got the key from the NGC platform and I didn’t see an option to check the key’s visibility. Could you please share how to confirm whether the key is public or private.
In the key permissions you have “Secrets Manager” and “NGC Catalog”. You can edit these permissions to add “Public API Endpoints” as a permission which will allow you to access the right resources to run the playbook.
