DGX Spark PXE Recovery fails with Recovery Images 1.145.33 and 1.135.29
We are experiencing a PXE Recovery issue with a DGX Spark Founders Edition.
Environment
  • DGX Spark Founders Edition
  • PXE Server OS: Oracle Linux 9.3
  • Services: DHCP, TFTP, HTTP
  • Direct Ethernet connection between the PXE server and DGX Spark
PXE Recovery Progress
The following steps complete successfully:
  • DHCP address assignment
  • grubnetaa64.efi.signed download
  • grub.cfg download
  • vmlinuz download
  • initrd download
  • HTTP access to usb.customer.tar.gz
  • Recovery environment startup
Observed Behavior
The recovery process reaches the screen:
“DGX Spark System Recovery Completed”
However, the recovery output contains the following errors:
/init_restore: line 26: can’t open /mnt/usb/efi.tar.xz
cat: can’t open ‘/mnt/usb/fastos.part*’
xz: (stdin): File format not recognized
0 bytes copied
can’t create /mnt/disk/efi/EFI/ubuntu/grub.cfg
After reboot, DGX OS does not boot successfully.
Testing Performed
We tested both Recovery Images:
  • 1.145.33
  • 1.135.29
The same issue occurs with both versions.
For Recovery Image 1.135.29 we verified:
VERSION=“1.135.29”
and confirmed that the archive contains:
  • usbimg.customer/usb/efi.tar.xz
  • usbimg.customer/usb/fastos.partaa
  • usbimg.customer/usb/fastos.partab
Therefore, the required files exist inside the recovery archive.
Questions
  1. Is this a known issue with DGX Spark PXE Recovery?
  2. Why are efi.tar.xz and fastos.part* unavailable under /mnt/usb during recovery although they exist in the archive?
  3. Are there any additional PXE Recovery requirements or kernel parameters that are not described in the DGX Spark User Guide?
  4. What additional logs would you recommend collecting?
Please note that USB storage devices are not permitted in our environment due to company security policy, therefore PXE Recovery is the only available recovery method.
Can you take a look in PXE Boot Setup — DGX Spark User Guide to see if there is any gap?
Thank you for the reference.
We reviewed the PXE Server Configuration for Recovery Media section and our environment follows the documented procedure.
Specifically:
  • grubnetaa64.efi.signed is successfully downloaded
  • grub.cfg is successfully downloaded
  • vmlinuz is successfully downloaded
  • initrd is successfully downloaded
  • Recovery Environment starts successfully
  • usb.customer.tar.gz is served via HTTP
  • Recovery Image 1.135.29 was prepared according to the documented procedure
We also verified that the recovery archive contains:
However, during recovery we still observe:
can’t open /mnt/usb/fastos.part*
The same issue is reproducible with both Recovery Image 1.145.33 and Recovery Image 1.135.29.
Could you please clarify which specific step in the PXE Recovery Media procedure you believe may be missing or incorrectly configured?
If possible, please provide the exact verification steps or additional diagnostic commands you recommend.
@chika.sasaki looking at instructions this caught my eyes:
Before enabling PXE Boot, you need to disable the secure boot feature in the UEFI menu or enroll the grubnetaa64.efi.signed in the UEFI menu.
If SB is enabled have you enrolled grubnetaa64.efi.signed already? Does it fail with SB disabled also?
Is it possible for you to provide the full pxe boot log?
Thank you for the suggestion.
I have not yet checked the Secure Boot settings.
I will verify whether Secure Boot is enabled, disable it, re-run the PXE Recovery, and let you know the results.
Regarding the PXE boot logs, please let me know exactly which logs you require.
We can provide the following:
・DHCP server logs
・TFTP server logs
・HTTP access logs
・grub.cfg
・Recovery Image version verification results
・SHA256 verification results
・Console output displayed on the screen during recovery
If you require the complete PXE boot sequence—from power-on to the launch of the Recovery Environment—please advise us on the recommended capture method and format.
Console output displayed on the screen during recovery Is ok.
Grub.cfg will be good also
I will get the log next week. Please wait for a while.
We think it is most likely that your GRUB kernel command line is missing the standalone noui parameter.
    menuentry "Install DGX Spark FastOS" {
       linux /fastos/vmlinuz nouveau.modeset=0 console=tty0 console=ttyS0,921600 sbsa_gwdt.action=1 noui pxeinstall=true fastos_usbimg_url=http://<Server IP>/fastos/usb.customer.tar.gz ip=dhcp static_ip=<static ip>:<SUBNET>[:<gateway ip>:<INTERFACE>]
       initrd /fastos/initrd
Thank you for pointing this out.
The `grub.cfg` file currently in use did not include the `noui` parameter specified in the DGX Spark PXE Recovery documentation.
I will test with `noui` parameter added and leaving all other conditions unchanged and share the results.
sorry for the delay in getting back to you. After adding the following ip setting in grub.cfg, the issue solved. Thank you.
static_ip=::
eg: static_ip=10.128.100.122:255.255.0.0:10.128.100.120
