After rebooting from the kernel 7.0.0-1019-nvidia update, gdm fails to start. The terminal cursor is visible in the upper left. There are other posts on the forum about other problems from the 7.0.0 update, but the gdm problem was not fixed using their instructions. I was able to restore the spark booting to gdm through the following procedure:
- Press Ctrl + Alt + F3 to get to the terminal.
- Run
sudo journalctl -b and in the logs I noted nvidia-persistenced.service failed to start, and further into the log the underlying reason reported is that libnvidia-cfg.so.1 could not be found.
- The fix required running
sudo ubuntu-drivers autoinstall which updated the nvidia driver to 595.91.07. After rebooting, the newest driver was installed for the kernel 7.0.0-1019-nvidia and gdm correctly started.
An issue with libnvidia-cfg.so.1 typically means an issue with the driver rather than the kernel. Driver 595 is not yet supported on DGX Spark so you may run into unintended behavior. I would recommend downgrading back to 580.178.04 if you do see any performance issues.
When we can expext update for dgx spark?
We need to go higher than 580
.. just fixed mine as well after last update .. had to upgrade to 595.91.07 driver . Seems works just fine . Surprisingly stable and visually sglang now consuming less memory. Will keep it for now =)
vu@atom:~$ uname -a
Linux atom 7.0.0-1019-nvidia #19~24.04.2-Ubuntu SMP PREEMPT_DYNAMIC Sun Sep 6 18:35:11 UTC 2 aarch64 aarch64 aarch64 GNU/Linux
vu@atom:~$ /usr/bin/hostnamectl
Static hostname: atom
Icon name: computer-server
Chassis: server 🖳
Machine ID: 99c4d59e7f734abb8a0613c00717ca3a
Boot ID: 8f2edb3ef8a644eba87ae0a1d491c5dc
Operating System: Ubuntu 24.04.5 LTS
Kernel: Linux 7.0.0-1019-nvidia
Architecture: arm64
Hardware Vendor: GIGABYTE
Hardware Model: AI TOP ATOM
Firmware Version: 5.36_0ACUM08
Firmware Date: Thu 2026-07-02
Firmware Age: 2month 2w 5d
vu@atom:~$ nvidia-smi
Sun Sep 20 18:36:37 2026
| NVIDIA-SMI 595.91.07 Driver Version: 595.91.07 CUDA Version: 13.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GB10 On | 0000000F:01:00.0 Off | N/A |
| N/A 68C P0 42W / N/A | Not Supported | 95% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1996 C python3 1253MiB |
| 0 N/A N/A 2666 C sglang::scheduler 93142MiB |
