my DGX Spark (P4242, DGX OS, used as a 24/7 home server) resets itself hard and unpredictably, mostly while idle. The desktop session is lost every time. I found a workaround that points to the cause, and I would like to ask NVIDIA for confirmation and a proper fix.
Symptoms
- The system goes down without any warning. The journal of the previous boot ends mid-operation, with no shutdown sequence and no thermal / MCE / OOM / Xid message before it.
- It comes back by itself about 2 minutes later (a reset, not a power loss).
- The pstore dumps show every time:
Kernel panic - not syncing: SBSA Generic Watchdog timeout. The call trace is identical in all dumps I read:sbsa_gwdt_interrupt→panic, raised on CPU 0 while it is idle (do_idle/cpu_idle_poll), followed bySMP: failed to stop secondary CPUs. - CPU 6 is listed in the last five dumps (10-06: 2,4,6-7,12-13,17-19 | 10-07: 6 | 10-08: 1,6,10,12 | 10-09 02:18: 6 | 10-09 14:21: 6). So at least one core stops answering IPIs, apparently while idle.
- At boot I get
BERT: Error records from previous bootwith severity “corrected, requires no further action”.
Reset times (CEST)
2026-08-20, 08-23, 09-16, 09-18, 10-05 03:54, 10-06 15:08, 10-07 22:04, 10-08 10:38, 10-09 02:18, 10-09 ~13:31, 10-09 ~14:20, 10-21 ~05:26.
The rate increased in October: 4 resets within 3 days (10-07 to 10-09), the last two only 46 minutes apart.
Workaround test (important)
After the reset on 10-09 I disabled all deep cpuidle states (LPI-1, LPI-2, LPI-3, only WFI remains) on all cores:
echo 1 | sudo tee /sys/devices/system/cpu/cpu*/cpuidle/state{1,2,3}/disable
- Result: 10 days and 1 hour without any reset (10-09 14:22 until a manual reboot on 10-19 15:29).
- The setting is lost on reboot. With the deep states enabled again, the next hard reset came 38 hours later (10-21 ~05:26), with exactly the same signature.
- This is not proof (single runs were up to 35 hours before the workaround), but together with CPU 6 appearing in every dump it strongly points to a hang when cores enter or leave the deep idle states. On this machine the cores spend about 79 % of their time in LPI-3 (CoreIdle-OFF + PlatIdle-DSUOFF + …), so that is where idle time is mostly spent. cpuidle driver is
acpi_idle.
Conditions
- Mostly idle: CPU load about 3-10 %, GPU about 6 W / 36-38 C, no model under load, many Docker containers running. sysstat shows no load spike before the resets.
- Suspend is disabled. The Spark is connected to a normal 3600 W power strip, no other device has problems there.
- The NVIDIA bug report log shows no Xid errors, no MCE/state “Safe”.
Versions
- Kernel 7.0.0-1019-nvidia (before 10-08: 6.17.0-1029-nvidia, same resets on both)
dgx-release7.6.0,dgx-spark-ota-update-meta26.09- NVIDIA driver 580.178.04
- DMI BIOS string:
5.36_0ACUM018 08/06/2025(did not choughfwupdmgrshows the Embedded Controller 0x03000508 and the UEFI device firmware as “Update State: Success”)
Questions
- Is this a known issue with deep CPU idle states (LPI-d is a firmware or kernel fix planned?
- Is there a newer BIOS/UEFI than
5.36_0ACUM018? Which string should I see after a successful firmware update? - Is it safe to keep the deep idle states disabled permsystemd unit) until a fix exists? Do you expect anoticeable idle power increase?
- Is there anything else I should collect for a support report, pstore dumps)? I can provide
nvidia-bug-report.log.gz, all pstore dumps and the journals.
