DGX Spark Software Updates - June 2026 Release
DGX Spark software updates began rolling out today, as a part of GTC Taipei/Computex releases. Partner GB10 Grace Blackwell Superchip systems may lag slightly behind.
What’s New:
  • Out-of-Box-Experience (OOBE) Enhancements: Updates to OOBE to enable faster initial device setup time and easier navigation to discover/install local AI agents.
    • Over-the-air (OTA) updates are not installed by default during initial setup, allowing users to start using their system sooner. Users can download and install OTA updates after initial system setup.
    • After initial system boot, users will be taken to the DGX Spark playbook site, where the NemoClaw playbook is prominently displayed for streamlined setup of a sandboxed local agent.
  • New Application and Library Features (available outside of OTA update)
    • NVIDIA Sync Cluster Assistant: The Cluster Assistant is now available on the Settings page in the NVIDIA Sync application. Cluster Assistant helps users connect up to 3 devices without a network switch, and up to 4 devices using a switch.
    • NVIDIA Collective Communications Library (NCCL): NCCL (Version 2.30u1) has updated support for connecting 3 DGX Spark systems in a ring topology.
For instructions on how to update your DGX Spark, see: OS and Component Update Guide — DGX Spark User Guide
Thank you for being an active member of this community. Please continue to share what you build with DGX Spark
