DGX Spark system hardware crashes at around 75W (system reboots) repeatedly (wattage cap workaround found)
This is what I found as the resolution (apply 2100 MHz cap):
sudo nvidia-smi -lgc 300,2100
You can reset this using this command (release cap back to 3003 MHz):
sudo nvidia-smi -rgc
The issue appears to be that it aborts at around 75W and the above was the solution that I could keep things stable using.
Have now been running without repeated reboots, but would be nice to have a better built-in setup to avoid this issue altogether.
I value any input on this subject.
