DGX Spark + WNC ORU: PUSCH CRC FAIL
Hi NVIDIA Aerial team,
We are testing an Aerial setup based on DGX Spark and a WNC O-RU, and we’re facing an msg3 PUSCH decoding issue.
The UE we used in this test is Samsung S23, which works good in other non-Aerial setup. But with this Aerial setup, the case is as below:
  • the msg1 preamble is decoded correctly by phy,
  • msg2 PDCCH/PDSCH are decoded by UE as well.
  • msg3 PUSCH is always decoded as CRC FAIL by phy
Our setup:
  • Platform: DGX Spark
  • Aerial version: ACAR 26-1
  • O-RU: WNC O-RU, 4T4R
  • Band: n79
  • Bandwidth: 100 MHz
  • SCS: 30 kHz
  • O-RAN split: 7.2x
  • Compression: BFP, 9 bits
  • PTP: synchronized
  • Fronthaul NIC: CX7
The cuphycontroller yaml and ORU config are as attached. Could you help to check if any mismatches in our configuration?
aerial-cuda-accelerated-ran.zip (5.4 KB)
Hi @nevill.zhou ,
Welcome to the forum!
Here are my suggestions.
  1. Capture the FAPI log and see if the CRC error is caused due to an RF issue using Wireshark with the NVIDIA FAPI dissector.
    Particularly, take a look at:
    • MCS in UL_TTI.request
    • UL_CQI in RX_Data/CRC.indiation
    • Timing advance in RX_Data/CRC/RACH.indication
    • RSSI in RX_Data/CRC.indication
  2. Check if the O-RU is in the PA-protect mode with:
    ru# show radio pa-protect
        Peak     Avg        Pavg        Ppar     Perravg
      normal   error  -8.778dBFS    -7.298dB  -8.778dBFS  --> Radio 1 is in the PA-protect mode.
      normal  normal -48.165dBFS    -0.000dB   0.000dBFS
      normal  normal -45.154dBFS    -0.000dB   0.000dBFS
    OK
    Clear the mode if that’s the case.
    ru# clear radio pa-protect
    OK
  3. If you see the PA-protect mode, try the following parameters.
    In RU:
      transmit-power-scale -7.0 --> 0
      digital-power-scaling legacy --> o-ran
    In the cuphycontroller yaml:
          fs_offset_dl: 7 --> 0
          fs_offset_ul: -5 --> 0
Thank you,
Nori
Hi @nhashimoto
Thank you for your helpful suggestions. After configuring the power scaling parameters as you mentioned above, the msg3 PUSCH now is CRC OK.
But the timing advance of msg3 PUSCH seems not good, about 22 ~ 23. Our setup is in lab and the UE is located 1 meter away from the ORU. So the radio condition should be good enough and the timing advance is expected to be around 31.
Below is the fapi capture logs of CRC.indication and related UL_TTI.request. (Full log is attached)
Could you give us some suggestions for next step?
Nevill
nvipc.zip (637.8 KB)
Hi Nevill,
  • Since msg3 is the initial PUSCH transmission, can you check if the TA value is converged to these values after a few minutes?
  • The initial TA value, i.e., msg3, should be based on the TA value in RACH.indication. Can you check it as well?
  • If the TA value in RACH.indication is far from the TA value for msg3, I guess your L2 isn’t working based on the TA feedback or the TA control feature isn’t working. Can you confirm them on your L2?
Thank you,
Nori
Thank you Nori. Now the msg3 TA is correct after I modify L2 TAC.
I still have a small question. I found that the timing advance reported by phy in msg1 is consistently about 9 or 10 (see below picture). But the test setup is quite simple, UE is located very close to the RU (less than 1 meter) and RU is directly connected to Spark (no switch between them). So I expected the msg1 TA should be close to ZERO.
My question is, is it normal with cudaPhy? Or should I configure some other parameters which can make the msg1 TA lower?
BRs
Nevill
I checked some logs captured in a wired setup, but the TA values are ZERO when a preamble is detected. Did the RACH.indication messages in your screenshot report that a preamble was detected?
YES, preamble is detected by phy and the preambleID is correctly matched with UE side. Below is a capture of FAPI. In this case, L2 needs to add an additional TA_offset value of 10, to make msg3 arrive at the expected uplink timing.
Can you try to change this parameter?
prach_ta_offset_usec: 2.5 --> 0
Yes, I changed prach_ta_offset_usec from 2.5 to 0.0 but the msg1 TA is 19.
I tried to change this para and find some trend, the larger the prach_ta_offset is, the lower the TA is.
Below table is the numbers I tested in my setup. The only variant for different rows is the prach offset value.
Do you have some suggested value?
If prach_ta_offset_usec of 0 changes the TA output and the TA value is non-zero with such a short distance, there is a fixed offset with this O-RU or this setup.
Can you look at the phy.log and find the following log?
raw TA {} us indicates the fixed offset. prach_ta_offset_usec should be set to this raw TA value.
Please note that this log is an INFO-level log. Please set nvlog.shm_log_level or shm_level for tag 333: SCF.PHY to 5 (INFO).
The following line shows how the TA output value is calculated using prach_ta_offset_usec.
I added some prints in ul_ind_ta.
The output is as below:
05:50:51.820418 INF UlPhyDriver05 0 [SCF.PHY] ul_ind_ta: rawTA 4.947917 ta_offset_usec_ 2.5 TA_BASE_SCALE 1.92 mu 1 ta_base_offset 0
05:50:51.820441 INF UlPhyDriver05 0 [SCF.PHY] send_rach_indication: RACH_INDICATION: pdu idx [0] prmb_idx [0] preambleIndex=0, PreamblePwr=71965, TA=9 raw TA 4.947917 us peak=11.600813 preamblePower=10.644884
To make msg1 TA=0, should I set ta_offset_usec_ to 4.94? Does this parameter support such big value?
Yes, if you set prach_ta_offset_usec to 4.94 (us), the TA value will be zero. As far as I can tell from reviewing the code, there are no limits on the configuration range.
