In a demo environment I have setup a DHCP service (IPv4 only right now) and specified the correct interfaces I want it to run on, I can see in the run command being generated it’s including those, but when I plugin to one of those interfaces I am presented with the following error:
No subnet declaration for swp2 (no IPv4 addresses).
Feb 14 10:15:14 leaf3-1 dhcpd[23323]: ** Ignoring requests on swp2. If this is not what
Feb 14 10:15:14 leaf3-1 dhcpd[23323]: you want, please write a subnet declaration
Feb 14 10:15:14 leaf3-1 dhcpd[23323]: in your dhcpd.conf file for the network segment
Feb 14 10:15:14 leaf3-1 dhcpd[23323]: to which interface swp2 is attached. **
You can see my config here that’s auto generated by NVUE:
# Auto-generated by NVUE!
# Any local modifications will prevent NVUE from re-generating this file.
# md5sum: bb8751748aaffdfb66c2e95293e9478b
authoritative;
option cumulus-provision-url code 239 = text;
subnet 10.1.10.0 netmask 255.255.255.0 {
option domain-name-servers 1.1.1.1;
option domain-name "removed-for.security";
option routers 10.1.10.1;
default-lease-time 200000;
max-lease-time 200000;
ping-check on;
pool {
range 10.1.10.100 10.1.10.199;
# Statics
group {
host server1 {
hardware ethernet 44:38:39:00:01:7e;
fixed-address 10.0.0.2;
I am unsure why DHCPd is asking for interface specific declarations. Based on the docs, by specifying the interfaces via NVUE it would be my hope that NVUE would edit the configs so that those powers have any required declarations needed to work.
