I got a Jetson Nano earlier this week and have been starting to transfer some code at work over as a test case, but almost as soon as I turn it on I start getting Warning messages appear that the system is being throttled (which for convenience I have disabled for the moment!)
I’m slightly surprised at this as it is currently supplied power through the barrel jack adapter powered from a bench power supply with the full 4A available to it, I checked at the connector end with a multimeter at the connector end, and there is a ~.1V drop but I wouldn’t expect that to be causing issues. The the max I have ever seen it draw is 1.1A from the supply, even when running some of the demos.
There is also a fan attached, but I’m not sure that temperature is really the issue here as the heatsink is cool to the touch and tegrastats suggest 25C temps while still warning of throttling!
I’m currently set to the MAXN power mode, but I received the same warnings on 5W, is there something I’m missing or is the warning just overzealous and I shouldn’t worry about it?
Thanks all.
