Diff between statically-allocated&dynamically-allocated
in this code
__global  void kernel()
__shared__  int a[64];
when i use CU_FUNC_ATTRIBUTE_SHARED_SIZE_BYTES to get the attribute of
this kenel ,
the result is 0!
i think this a is static shared memory , but the the result is zero .
is there any answer for this ??
Your kernel doesn’t do anything. The compiler may have optimized out the usage of shared memory.
$ cat t2057.cu
#include <cstdio>
#include <iostream>
__global__ void k(int n){
  __shared__ int s[64];
#ifdef DO_SMTH
  for (int i = 0; i < 64; i++) s[i] = 0;
  for (int i = 0; i < n; i++) s[i] = i;
  int v = 0;
  for (int i = 0; i < 64; i++) v += s[i];
  printf("v = %d\n", v);
#endif
int main(){
  cudaFuncAttributes a;
  cudaFuncGetAttributes(&a, k);
  std::cout << a.sharedSizeBytes << std::endl;
$ nvcc -o t2057 t2057.cu
t2057.cu(5): warning: variable "s" was declared but never referenced
$ ./t2057
0
$ nvcc -o t2057 t2057.cu -DDO_SMTH
$ ./t2057
256
“use it or lose it”
i try your code.
the key point is here:
“printf(“v = %d\n”, v);”
if use this line code , sharedSizeBytes will be 256.
if no this line code ,sharedSizeBytes will be 0.
you can try;
before i also use the shared memory like you ,but no printf to print somethings
like
so the shared memory used is 0;
anyway , thanks for your answer!
Thanks for your answer!
