Difference between deep stream close-source and open-source?
Hi all,
1- What’s exactly difference between deep stream close-source and open-source?
2- Deep stream only used TLT trained models?
3- For run TLT trained model with deep stream, I need to have all of deep stream codes? Is it possible to have simple python code for running of TLT models?
1- What’s exactly difference between deep stream close-source and open-source ?
what does “close-source” mean?
can support all models TRT support, such as caffe, onnx from TF or pythorch models, and UFF model from TF model
With DS5.0, can also support TF & pytorch model directly with Triton.
yes, you can. many ds code are samples.
https://github.com/NVIDIA-AI-IOT/deepstream_tlt_apps is the sample to run TLT modes with some DS libs
