and I needed further clarity on the difference between the three.
Also do the rect_params.top,rect_params.left,rect_params.width,rect_params.height
Represent the four corners of the detection rectangle, if so which corners specifically.
Hi, detector_bbox_info is the output of nvinfer plugin with the model, and tracker_bbox_info is the output of nvtracker plugin. In previous release there is only rect_params which is the output of last component. In latest release the output result is kept so that you can access all data per your use-case.
