Difference between p3701-0000 and p3701-0005 SOM Board
I’m trying to understand the difference between the P3701-0000 and P3701-0005 Jetson AGX Orin SOM variants.
I’m using a Jetson AGX Orin 64GB Developer Kit and have flashed several different JetPack versions using SDK Manager over time, so I’ve lost track of which DTB file was originally shipped with the factory image. On my current installation, the device is using the following DTB:
kernel_tegra234-p3701-0005-p3737-0000.dtb
However, in most documentation, examples, and forum posts I’ve found online, the DTB referenced for the AGX Orin Developer Kit is:
kernel_tegra234-p3701-0000-p3737-0000.dtb
Could someone help me understand:
  1. What is the difference between the P3701-0000 and P3701-0005 SOMs?
  2. Are there any hardware differences that require different DTBs?
  3. Did NVIDIA change the SOM identifier in newer JetPack releases, or would the SDK Manager automatically selecting a DTB based on the installed module revision?
— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
The difference between the P3701-0000 and P3701-0005 SOMs is not explicitly stated in the provided context. However, based on the information available, it appears that both P3701-0000 and P3701-0005 are SOM variants for the Jetson AGX Orin module.
In the context of device tree files, the naming conventions for the Jetson AGX Orin module are mentioned. The device tree files are named as follows:
  • tegra234-p3701-0000-p3737-0000.dts
  • tegra234-p3701-0008-p3737-0000.dts
  • tegra234-p3701-0000-as-pxxxx-p3737-0000.dts
According to the accepted solution in Topic #274673, P3701-0000 is the Orin AGX devkit module, and P3701-0008 is the Orin AGX industrial module.
However, there is no explicit information available in the provided context about the P3701-0005 SOM variant. It is possible that the P3701-0005 SOM variant is a newer or updated version of the P3701-0000 SOM variant, but without further information, it is difficult to determine the exact differences between the two.
Regarding the DTB files, the provided context does not explicitly state why the SDK Manager would select a different DTB file based on the installed module revision. However, it is possible that the SDK Manager selects the DTB file based on the SOM variant and the installed JetPack version.
In summary, while the provided context does not explicitly state the differences between the P3701-0000 and P3701-0005 SOM variants, it appears that both variants are used for the Jetson AGX Orin module, and the SDK Manager may select a different DTB file based on the installed module revision and JetPack version.
It is recommended to consult the official NVIDIA documentation or contact NVIDIA support for further clarification on the differences between the P3701-0000 and P3701-0005 SOM variants and the selection of DTB files by the SDK Manager.
— We support team will also look into your issue to have further suggestions soon. please stay tuned. —
Hi CrazyCatt,
They are SKU0 and SKU5 AGX Orin module.
SKU0 is the module coming with the AGX Orin developer kit.
SKU5 is the commercial module used for the custom carrier board.
You can simply run cat /etc/nv_boot_control.conf to check.
Please refer to https://docs.nvidia.com/jetson/archives/r36.5/DeveloperGuide/index.html#devices-supported-by-this-document for details.
also the sku5 is 64GB DRAM SOM.
Hi KevinFFF,
I’m using JetPack 5.1.2 (L4T R35.4.1):
$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug  1 19:57:35 UTC 2023
My boot control information is:
$ cat /etc/nv_boot_control.conf
TNSPEC 3701-501-0005-G.0-1-1-jetson-agx-orin-devkit-
COMPATIBLE_SPEC 3701--0005--1--jetson-agx-orin-devkit-
TEGRA_LEGACY_UPDATE false
TEGRA_BOOT_STORAGE mmcblk0
TEGRA_EMMC_ONLY false
TEGRA_CHIPID 0x23
TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
The board is a Jetson AGX Orin 64GB Developer Kit. Based on suggestions from an AI tool, I also checked a few additional items:
$ cat /proc/device-tree/compatible
nvidia,p3737-0000+p3701-0005nvidia,p3701-0005nvidia,tegra234nvidia,tegra23x
/* EEPROM contents from I2C address 0x50 */
$ sudo i2cdump -f -y 0 0x50
No size specified (using byte-data access)
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f    0123456789abcdef
00: 02 00 fe 00 00 00 00 00 00 00 00 00 00 00 00 00    ?.?.............
10: 00 00 00 0a 36 39 39 2d 31 33 37 30 31 2d 30 30    ...?699-13701-00
20: 30 35 2d 35 30 31 20 47 2e 30 00 00 00 00 00 00    05-501 G.0......
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
40: 00 00 00 00 30 de b2 e2 3a ac 31 37 39 31 30 32    ....0???:?179102
50: 36 30 34 31 35 31 37 00 00 00 00 00 00 00 00 00    6041517.........
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
90: 00 00 00 00 00 00 4e 56 43 42 00 00 4d 31 00 00    ......NVCB..M1..
a0: 00 00 00 00 00 00 00 00 00 00 00 00 30 de b2 e2    ............0???
b0: 3a ac 0a 00 00 00 00 00 00 00 00 00 00 00 00 00    :??.............
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 b5    ...............?
I also checked with a colleague who has a Jetson AGX Orin 64GB Developer Kit that has never been reflashed using SDK Manager. Comparing the two systems, the main difference appears to be the output of cat /proc/device-tree/compatible:
nvidia,p3737-0000+p3701-0000nvidia,p3701-0000nvidia,tegra234nvidia,tegra23x
40: 00 00 00 00 93 d1 a3 47 bb 4c 31 37 39 34 32 32    ....???G?L179422
50: 35 31 30 36 32 38 39 00 00 00 00 00 00 00 00 00    5106289.........
a0: 00 00 00 00 00 00 00 00 00 00 00 00 93 d1 a3 47    ............???G
b0: bb 4c 0a 00 00 00 00 00 00 00 00 00 00 00 00 00    ?L?.............
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20    ...............
TEGRA_CHIPID 0x23
Based on your previous explanation, my understanding is that since this is a developer kit, it should be using SKU0 rather than SKU5. However, even after reflashing the board multiple times with the JetPack 5.1.2 image for the 64GB Developer Kit through SDK Manager, the system always comes back using the 0005 DTB after reboot.
For flashing, I’m using the SDK Manager Docker image, since I don’t have an Ubuntu 18.04 or 20.04 host available. The Docker container is running on an Ubuntu 24.04 machine. The flashing process completes successfully, and I don’t see any errors during the reflash.
Could you help clarify whether seeing p3701-0005 on a Jetson AGX Orin 64GB Developer Kit is expected, or if there is something unusual about my board identification or flashing process? And how can I flash it back to use the correct configurations?
Hi WayneWWW:
My machine is a Jetson AGX Orin 64GB Developer Kit:
$ free
              total        used        free      shared  buff/cache   available
Mem:       64309792     1219548    62351272       21016      738972    62490380
Swap:      32154880           0    32154880
According to KevinFFF:
  • SKU0 is the module coming with the AGX Orin developer kit.
  • SKU5 is the commercial module used for the custom carrier board.
Should Jetson AGX Orin 64GB Developer Kit be SKU0 or SKU5 or another SKU version?
I remember that the SOM on Orin AGX devkit has been changed to the 64GB SOM for a while.
The EEPROM won’t be wrong.
