Difference Between Pre-release vs Stable Edkrepo Combinations
Our customer is currently using the Orin NX product with the L4T 35.4.1 BSP.
We are planning to set up a Docker-based UEFI build environment.
While reviewing the NVIDIA Edkrepo Combinations for L4T 35.4.1, we found that the available combinations are listed as shown in the attached image.
Since this will be deployed to a mass production product,
we would like to understand the difference between the pre-release and stable types.
From a production perspective, would you recommend using the latest pre-release type, or is it better to use a stable type?
Based on the provided context, I will provide a comprehensive answer to the question.
The question is related to the NVIDIA Jetson Orin NX product and the L4T 35.41 BSP (Board Support Package). The customer is planning to set up a Docker-based UEFI build environment and is reviewing the NVIDIA Edkrepo Combinations for L4T 35.41.
The customer has found that the available combinations are listed as “prerelease” and “stable” types, and they would like to understand the difference between these two types from a production perspective.
Unfortunately, the provided context does not explicitly explain the difference between “prerelease” and “stable” types. However, based on general software development practices, I can provide a general explanation of the difference between these two types.
Prerelease Type:
A prerelease type typically refers to a software version that is not yet fully tested or validated for production use. It may contain new features, bug fixes, or performance enhancements that are not yet fully verified. Prerelease versions are often used for testing, validation, and feedback purposes before the software is officially released.
Stable Type:
A stable type, on the other hand, refers to a software version that has been fully tested, validated, and verified for production use. It is considered to be a mature and reliable version that has undergone rigorous testing and quality assurance processes. Stable versions are typically recommended for production use because they are less likely to contain bugs or issues that could impact the stability of the system.
Recommendation:
From a production perspective, I would recommend using the stable type for several reasons:
  1. Reliability: Stable versions are more reliable and less likely to contain bugs or issues that could impact the stability of the system.
  2. Compatibility: Stable versions are more likely to be compatible with other software components and hardware platforms.
  3. Support: Stable versions are typically supported by the vendor for a longer period, which means that you can expect to receive updates, patches, and bug fixes for a longer time.
  4. Risk Management: Using a stable version reduces the risk of introducing new bugs or issues into your production environment.
While the latest prerelease type may offer new features or performance enhancements, it is generally not recommended for production use until it has been fully tested and validated.
In summary, while the provided context does not explicitly explain the difference between “prerelease” and “stable” types, based on general software development practices, I would recommend using the stable type for production use due to its reliability, compatibility, support, and risk management benefits.
For mass production, please use the stable version uefi-202210.3. Other versions are pre-release which may include later commits but are not thoroughly validated in SQA.
