What is the difference between pretrain_model_file VS pretrain_model_path in the spec files?
Which network did you talk about?
hdf5 detectnet and also .tlt custom. I have observed that _path works with .tlt but not _file.
Do you talk about TLT detectnet_v2 network? If not, is it Faster_rcnn , SSD , or others?
In detectnet_v2 network, please see https://docs.nvidia.com/tlt/tlt-user-guide/text/object_detection/detectnet_v2.html#model-config
there is only “pretrained_model_file”.
Usually you can set similar to below.
model_config {
pretrained_model_file: “/workspace/tlt-experiments/detectnet_v2/pretrained_resnet18/tlt_pretrained_detectnet_v2_vresnet18/resnet18.hdf5”
You can download jupyter notebook for reference. There are spec files in each network.
