Can someone explain what the difference is between the ‘normal’ .dtb file and the one with ‘maxn’ in the suffix?
Which one should we use as a starting point for a custom dtb for a custom carrier?
I have used ‘dtc’ to create a dts file for both of those files, my assumption is that the other files in the dtb folder are for other SoM and carrier combos (tegra186-quill for example)
Edit: I did look at these in a text compare, and I see there are a lot of differences, I just dont know the root reason - is one for the SoM periperhals only?
Thanks,
Dan
