This may be a newbie question, but the output from the code below isn’t quite what I expected it to be. I am trying to do quick Mandelbrot set area calculation. I’d have expected the results to be identical in each case (host/accel) but they differ.
I’m using PGI v 11.3.
Any help appreciated.
-Nick.
Code:
#include <stdio>
#include <stdlib>
#include <math>
#include <time>
#include <sys>
#include <omp>
#ifdef ACCELERATOR_PGI
#include <accel>
#endif
/* Algorithm parameters */
//# define NPOINTS 100352
#define NPOINTS 10000
#define MAXITER 10000
/* Cut off at which an iteration is ruled outside of set */
#define CEILING 4.0
/* Bounding box in which Mandelbrot set is know to lie */
#define RMIN -2.0
#define RMAX 0.5
#define IMIN 0.0
#define IMAX 1.125
/* Prototypes */
int min(int a,int b);
float getTime(void);
int main(int argc, char *argv[])
double csetre[NPOINTS];
double csetim[NPOINTS];
double numarray[NPOINTS];
int numInside;
int i;
int j;
double area;
double error;
float start_time;
float end_time;
double cre;
double cim;
double zre;
double zim;
double ztemp;
numInside = 0;
ztemp = 0.0;
/* Generate a set of nPoints random points in complex plane. */
srand(12345);
for(i=0; i<NPOINTS; i++){
csetre[i] = RMIN +
(RMAX - RMIN)*((double) rand() / (double) RAND_MAX);
csetim[i] = IMIN +
(IMAX - IMIN)*((double) rand() / (double) RAND_MAX);
numarray[i] = 0.0;
start_time = getTime();
/* Kernel that iterates over set of points, counting up those that are
inside Mandelbrot set */
for (j=0; j<NPOINTS; j++){
zre = csetre[j];
cre = csetre[j];
zim = csetim[j];
cim = csetim[j];
for(i=0; i<MAXITER; i++){
/* z_{i+1} = z_i^2 + c */
ztemp = (zre*zre - zim*zim) + cre;
zim = 2.0*zre*zim + cim;
zre = ztemp;
/* Having completed iteration, check if point is inside set */
if((zre*zre + zim*zim) < CEILING){
numInside++;
/* Calculate area and error and output the Results */
area = 2.0*(RMAX-RMIN)*(IMAX-IMIN) * (double) numInside / (double) NPOINTS;
error = area / sqrt((double) NPOINTS);
end_time = getTime();
printf("NPOINTS : %d\n", NPOINTS);
printf("MAXITER : %d\n", MAXITER);
printf("NumInside : %d\n", numInside);
printf("Area : %16.12f +/- %16.12f (host)\n", area, error);
printf("Time : %16.12f secs (host)\n", end_time-start_time);
area = 0.0;
error = 0.0;
zre = cre = zim = cim = 0.0;
// Only do this if we are accelerated using PGI compiler
#pragma acc region
zre = csetre[j];
cre = csetre[j];
zim = csetim[j];
cim = csetim[j];
zre = ztemp;
/* Having completed iteration, store results (whatever it is) in a big array */
numarray[j] = (zre*zre + zim*zim);
/* Back on the host, do the analysis */
numInside = 0;
if (numarray[j] < CEILING){
numInside++;
printf("Area : %16.12f +/- %16.12f (accel)\n", area, error);
printf("Time : %16.12f secs (accel)\n", end_time-start_time);
#endif
return(0);
/* Simple function to compute minimum of two integers */
int min(int a, int b)
if (a < b)
return a;
else
return b;
float getTime(void){
return (float) clock() / (float) CLOCKS_PER_SEC;
I compile the job using:
pgcc -o vtspg3 -ta=nvidia -Minfo=all,accel -DACCELERATOR_PGI area-comparison.c
And get the output as:
NPOINTS : 10000
MAXITER : 10000
NumInside : 2671
Area : 1.502437500000 +/- 0.015024375000 (host)
Time : 0.649999976158 secs (host)
NPOINTS : 10000
MAXITER : 10000
NumInside : 3115
Area : 1.752187500000 +/- 0.017521875000 (accel)
Time : 0.580000042915 secs (accel)
