Is there functional differences between different Jetson TX2 board revisions?
I encountered some anomaly when using Jetpack 3.3.3 , 4.4 and 4.4.1 versions on B02 and D02 module revisions. D00 is working presumably as same as B02 (not 100 % sure what memory is in D00)
B02 is using Samsung 8Gb per die memories while D02 is using Micron 16Gb per die memory.
However when checking from U-boot and from Linux available memory is not the same with B02 and D02 revision modules.
U-boot reports roughly 7.8 gigabytes available memory on B02 revision board with Jetpacks 3.3.3 ,4.4 and 4.4.1. However D02 reports only 7.7 gigabytes of available memory.
See details below:
U-boot bdinfo from B02 and Jetpack 4.4.1
arch_number = 0x00000000
boot_params = 0x00000000
DRAM bank = 0x00000000
-> start = 0x80000000
-> size = 0x70000000
DRAM bank = 0x00000001
-> start = 0xF0200000
-> size = 0x185600000
DRAM bank = 0x00000002
-> start = 0x275E00000
-> size = 0x00200000
DRAM bank = 0x00000004
-> start = 0x277000000
< removed most of empty banks due size restriction in post>
DRAM bank = 0x00000400
-> start = 0x00000000
-> size = 0x00000000
DRAM bank = 0x00000401
baudrate = 115200 bps
TLB addr = 0xFFFF0000
relocaddr = 0xFFF37000
reloc off = 0x7FEB7000
irq_sp = 0xFFB2E210
sp start = 0xFFB2E210
U-boot bdinfo from D02 and Jetpack 4.4.1
-> size = 0x179E00000
-> start = 0x26A600000
DRAM bank = 0x00000003
-> start = 0x26AE00000
irq_sp = 0xFFB2E210
Also sheer amount of DRAM banks in both cases is overwhelming. However main issue is that with B02 DRAM Bank 1 has settings like:
However with D02 this not the same:
Difference is around 184 megabytes, which is bit odd from my point of view as there should not be size difference.
Rest of the valid DRAM banks are the same in both revisions (however, why there is so many empty DRAM banks defined is beyond me).
Any ideas what is causing this?
