I have developed a camera application for the TX1, which utilises a USB 3.0 GenICam camera capitalising on Aravis Open source libraries and a standard OpenCV installation
This all works fine on the rev 100 module, but constantly locks up on the rev 400 module
What are the major differences in module revisions, as I do not seem to be able to find any documentation which tells me this
They were running on a Connect Tech Elroy carrier board (Rev E). This showed constant reconnection of the SuperSpeed USB port, so we suspect a problem with this carrier in conjunction with the Rev 4 TX1 module - The Rev 1 module works correctly on these carrier boards
I have tested the Rev 4 modules on an Nvidia TX1 carrier board and the USB port behaves correctly
We have just tried the combination of the Rev4 module with a Rev E Connect Tech Elroy carrier (that previously had the disconnection issue) and this did indeed resolve the disconnection - however it is an impractical solution.
There appears a subtle interaction of the TX1 module revision and the Connect Tech Elroy revision, as we do have 1 Rev E Elroy (with an early serial number) that works with both revision TX1 modules
The later serial number Elroy carriers do not work with the Rev 4 Tx1 modules, but do work with the Rev 1 modules
Hi martin,
1 Rev E Elroy with earlier serial number works on TX1 Rev1 and Rev4 modules.
1 Rev E Elroy with later serial number works on TX1 Rev1 module but does not work on TX1 Rev4 module.
Can you share schematic layout of both Rev E Elroy with earlier serial number and with later serial number?
