Differences in inlining between PGI5.2 and PGI 5.1?
Hi all,
I enclose at the end of this message a simple example whose compilation was fine in PGI 5.1 when inline directives were used.
PGI 5.2, however, raises the warning message,
PGF90-W-0268-Cannot inline subprogram; common block mismatch
I have found no helpful hints in the product documentation to solve this problem
Is the inlining policy changed in PGI 5.2,
with respect to PGI 5.1 ?
Thanks in advance
module mod_prova
implicit none
integer :: nslaves
integer, dimension(:), allocatable :: Array
end module mod_prova
program prova
use mod_prova
implicit none
integer :: i
nslaves = 7
allocate(Array(2))
i = 5
if (i /= 5) call iinc(‘A’, i)
contains
SUBROUTINE iinc(label, flag)
!!$ use mod_prova
CHARACTER(1), INTENT(IN) :: label
INTEGER , INTENT(IN) :: flag
IF (label == ‘D’) THEN
WRITE(,’(A,I3)’) "deallocate ==> ", flag
ELSE
WRITE(
,’(A,I3)’) "ALLOCATE ==> ", flag
END IF
WRITE(,) nslaves
END SUBROUTINE iinc
end program prova
It appears that when we changed the way we represented pointers to allocatables, pointer arrays, and pointers in the 5.2 pgf90, it inhibited the inlining of this function. Note that the problem should be corrected in the up coming 6.0 release.
Thanks,
Mat
