Hello, I am writing a device tree for a csi camera for xavier.
I’m writing a device tree for a csi camera for xavier, and I’m trying to adapt it to xavier as I have a device tree for nano. I modified it based on the nano device tree file I have and the imx219-dual device tree for both nano and xavier.
The csi camera was successfully recognized as a device. (/dev/video0)
When I ran v4l2-ctl --stream-mmap
, nothing appeared, and when I checked dmesg
, it gave the following message.
tegra194-vi5 15c10000.vi: no reply from camera processor
[ 143.961117] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 143.961269] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
I think this is caused by the lack of communication between the VI, nvcsi, etc.
I looked up “V4L2 Camera Driver Development for Custom Camera - Device Tree - CSI - Uncomplete data ” as a reference, but I couldn’t find the difference between nano and Xavier.
How may I change the device tree for nano to that for Xavier?
Thanks for the reply.
I did the logging as per this site.
Here are the results.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
->460800000
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
->576000000
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
->314000000
There were no errors.
However, the following debug method produced an error.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
trace_log
# tracer: nop
# entries-in-buffer/entries-written: 432/432 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:3-1901 [000] .... 932.331040: rtos_queue_peek_from_isr_failed: tstamp:29780524324 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 932.498870: rtos_queue_peek_from_isr_failed: tstamp:29785524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 932.666812: rtos_queue_peek_from_isr_failed: tstamp:29790524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 932.782800: rtos_queue_peek_from_isr_failed: tstamp:29795524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 932.950859: rtos_queue_peek_from_isr_failed: tstamp:29800524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 933.118844: rtos_queue_peek_from_isr_failed: tstamp:29805524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 933.290891: rtos_queue_peek_from_isr_failed: tstamp:29810524311 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 933.458764: rtos_queue_peek_from_isr_failed: tstamp:29815524320 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 933.574941: rtos_queue_peek_from_isr_failed: tstamp:29820524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 933.742877: rtos_queue_peek_from_isr_failed: tstamp:29825524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 933.910926: rtos_queue_peek_from_isr_failed: tstamp:29830524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 934.082977: rtos_queue_peek_from_isr_failed: tstamp:29835524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 934.250876: rtos_queue_peek_from_isr_failed: tstamp:29840524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 934.418809: rtos_queue_peek_from_isr_failed: tstamp:29845524314 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 934.590781: rtos_queue_peek_from_isr_failed: tstamp:29850524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 934.702764: rtos_queue_peek_from_isr_failed: tstamp:29855524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 934.874927: rtos_queue_peek_from_isr_failed: tstamp:29860524309 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 935.042909: rtos_queue_peek_from_isr_failed: tstamp:29865524310 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 935.218833: rtos_queue_peek_from_isr_failed: tstamp:29870524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 935.334797: rtos_queue_peek_from_isr_failed: tstamp:29875524316 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 935.502846: rtos_queue_peek_from_isr_failed: tstamp:29880524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 935.670900: rtos_queue_peek_from_isr_failed: tstamp:29885524324 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 935.838883: rtos_queue_peek_from_isr_failed: tstamp:29890524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 936.006887: rtos_queue_peek_from_isr_failed: tstamp:29895524310 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 936.174812: rtos_queue_peek_from_isr_failed: tstamp:29900524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 936.342762: rtos_queue_peek_from_isr_failed: tstamp:29905524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 936.455011: rtos_queue_peek_from_isr_failed: tstamp:29910524314 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 936.622863: rtos_queue_peek_from_isr_failed: tstamp:29915524319 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 936.790848: rtos_queue_peek_from_isr_failed: tstamp:29920524328 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 936.958870: rtos_queue_peek_from_isr_failed: tstamp:29925524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 937.134819: rtos_queue_peek_from_isr_failed: tstamp:29930524318 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 937.302917: rtos_queue_peek_from_isr_failed: tstamp:29935524316 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 937.414928: rtos_queue_peek_from_isr_failed: tstamp:29940524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 937.582859: rtos_queue_peek_from_isr_failed: tstamp:29945524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 937.750844: rtos_queue_peek_from_isr_failed: tstamp:29950524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 937.922799: rtos_queue_peek_from_isr_failed: tstamp:29955524316 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 938.094982: rtos_queue_peek_from_isr_failed: tstamp:29960524320 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 938.266766: rtos_queue_peek_from_isr_failed: tstamp:29965524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 938.378791: rtos_queue_peek_from_isr_failed: tstamp:29970524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 938.546776: rtos_queue_peek_from_isr_failed: tstamp:29975524316 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 938.714785: rtos_queue_peek_from_isr_failed: tstamp:29980524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 938.882769: rtos_queue_peek_from_isr_failed: tstamp:29985524316 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 939.050784: rtos_queue_peek_from_isr_failed: tstamp:29990524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 939.218789: rtos_queue_peek_from_isr_failed: tstamp:29995524131 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 939.387324: rtos_queue_peek_from_isr_failed: tstamp:30000524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 939.498791: rtos_queue_peek_from_isr_failed: tstamp:30005524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 939.670811: rtos_queue_peek_from_isr_failed: tstamp:30010524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 939.838786: rtos_queue_peek_from_isr_failed: tstamp:30015524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 940.006801: rtos_queue_peek_from_isr_failed: tstamp:30020524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 940.174786: rtos_queue_peek_from_isr_failed: tstamp:30025524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 940.342792: rtos_queue_peek_from_isr_failed: tstamp:30030524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 940.454770: rtos_queue_peek_from_isr_failed: tstamp:30035524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 940.622767: rtos_queue_peek_from_isr_failed: tstamp:30040524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 940.790780: rtos_queue_peek_from_isr_failed: tstamp:30045524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 940.958790: rtos_queue_peek_from_isr_failed: tstamp:30050524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 941.126809: rtos_queue_peek_from_isr_failed: tstamp:30055524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 941.294809: rtos_queue_peek_from_isr_failed: tstamp:30060524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 941.462947: rtos_queue_peek_from_isr_failed: tstamp:30065524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 941.575011: rtos_queue_peek_from_isr_failed: tstamp:30070524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 941.746768: rtos_queue_peek_from_isr_failed: tstamp:30075524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 941.914917: rtos_queue_peek_from_isr_failed: tstamp:30080524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 942.082930: rtos_queue_peek_from_isr_failed: tstamp:30085524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 942.250918: rtos_queue_peek_from_isr_failed: tstamp:30090524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 942.418906: rtos_queue_peek_from_isr_failed: tstamp:30095524314 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 942.534856: rtos_queue_peek_from_isr_failed: tstamp:30100524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 942.702970: rtos_queue_peek_from_isr_failed: tstamp:30105524314 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 942.870861: rtos_queue_peek_from_isr_failed: tstamp:30110524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 943.038798: rtos_queue_peek_from_isr_failed: tstamp:30115524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 943.206832: rtos_queue_peek_from_isr_failed: tstamp:30120524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 943.374816: rtos_queue_peek_from_isr_failed: tstamp:30125524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 943.542800: rtos_queue_peek_from_isr_failed: tstamp:30130524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 943.654794: rtos_queue_peek_from_isr_failed: tstamp:30135524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 943.823443: rtos_queue_peek_from_isr_failed: tstamp:30140524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 943.994834: rtos_queue_peek_from_isr_failed: tstamp:30145524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 944.162794: rtos_queue_peek_from_isr_failed: tstamp:30150524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 944.330804: rtos_queue_peek_from_isr_failed: tstamp:30155524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 944.498878: rtos_queue_peek_from_isr_failed: tstamp:30160524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 944.666810: rtos_queue_peek_from_isr_failed: tstamp:30165524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 944.778839: rtos_queue_peek_from_isr_failed: tstamp:30170524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 944.946815: rtos_queue_peek_from_isr_failed: tstamp:30175524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 945.118783: rtos_queue_peek_from_isr_failed: tstamp:30180524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 945.290795: rtos_queue_peek_from_isr_failed: tstamp:30185524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 945.466787: rtos_queue_peek_from_isr_failed: tstamp:30190524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 945.578808: rtos_queue_peek_from_isr_failed: tstamp:30195524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 945.746792: rtos_queue_peek_from_isr_failed: tstamp:30200524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 945.914816: rtos_queue_peek_from_isr_failed: tstamp:30205524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 946.082798: rtos_queue_peek_from_isr_failed: tstamp:30210524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 946.254809: rtos_queue_peek_from_isr_failed: tstamp:30215524137 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 946.422798: rtos_queue_peek_from_isr_failed: tstamp:30220524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 946.534804: rtos_queue_peek_from_isr_failed: tstamp:30225524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 946.706788: rtos_queue_peek_from_isr_failed: tstamp:30230524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 946.874783: rtos_queue_peek_from_isr_failed: tstamp:30235524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 947.042789: rtos_queue_peek_from_isr_failed: tstamp:30240524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 947.210805: rtos_queue_peek_from_isr_failed: tstamp:30245524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 947.378837: rtos_queue_peek_from_isr_failed: tstamp:30250524139 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 947.546806: rtos_queue_peek_from_isr_failed: tstamp:30255524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 947.658830: rtos_queue_peek_from_isr_failed: tstamp:30260524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 947.826846: rtos_queue_peek_from_isr_failed: tstamp:30265524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 947.994826: rtos_queue_peek_from_isr_failed: tstamp:30270524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 948.162805: rtos_queue_peek_from_isr_failed: tstamp:30275524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 948.330829: rtos_queue_peek_from_isr_failed: tstamp:30280524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 948.498798: rtos_queue_peek_from_isr_failed: tstamp:30285524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 948.614880: rtos_queue_peek_from_isr_failed: tstamp:30290524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 948.782814: rtos_queue_peek_from_isr_failed: tstamp:30295524131 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 948.950812: rtos_queue_peek_from_isr_failed: tstamp:30300524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 949.122884: rtos_queue_peek_from_isr_failed: tstamp:30305524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 949.290833: rtos_queue_peek_from_isr_failed: tstamp:30310524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 949.458805: rtos_queue_peek_from_isr_failed: tstamp:30315524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 949.626792: rtos_queue_peek_from_isr_failed: tstamp:30320524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 949.738809: rtos_queue_peek_from_isr_failed: tstamp:30325524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 949.906829: rtos_queue_peek_from_isr_failed: tstamp:30330524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 950.074823: rtos_queue_peek_from_isr_failed: tstamp:30335524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 950.242824: rtos_queue_peek_from_isr_failed: tstamp:30340524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 950.410799: rtos_queue_peek_from_isr_failed: tstamp:30345524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 950.578821: rtos_queue_peek_from_isr_failed: tstamp:30350524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 950.746833: rtos_queue_peek_from_isr_failed: tstamp:30355524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 950.858815: rtos_queue_peek_from_isr_failed: tstamp:30360524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 951.026831: rtos_queue_peek_from_isr_failed: tstamp:30365524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 951.194821: rtos_queue_peek_from_isr_failed: tstamp:30370524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 951.362805: rtos_queue_peek_from_isr_failed: tstamp:30375524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 951.530830: rtos_queue_peek_from_isr_failed: tstamp:30380524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 951.698808: rtos_queue_peek_from_isr_failed: tstamp:30385524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 951.866832: rtos_queue_peek_from_isr_failed: tstamp:30390524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 951.978825: rtos_queue_peek_from_isr_failed: tstamp:30395524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 952.146838: rtos_queue_peek_from_isr_failed: tstamp:30400524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 952.314883: rtos_queue_peek_from_isr_failed: tstamp:30405524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 952.482854: rtos_queue_peek_from_isr_failed: tstamp:30410524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 952.654840: rtos_queue_peek_from_isr_failed: tstamp:30415524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 952.826821: rtos_queue_peek_from_isr_failed: tstamp:30420524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 952.938829: rtos_queue_peek_from_isr_failed: tstamp:30425524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 953.106813: rtos_queue_peek_from_isr_failed: tstamp:30430524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 953.274843: rtos_queue_peek_from_isr_failed: tstamp:30435524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 953.442814: rtos_queue_peek_from_isr_failed: tstamp:30440524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 953.610845: rtos_queue_peek_from_isr_failed: tstamp:30445524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 953.778813: rtos_queue_peek_from_isr_failed: tstamp:30450524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 953.894874: rtos_queue_peek_from_isr_failed: tstamp:30455524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 954.062827: rtos_queue_peek_from_isr_failed: tstamp:30460524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 954.231259: rtos_queue_peek_from_isr_failed: tstamp:30465524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 954.398865: rtos_queue_peek_from_isr_failed: tstamp:30470524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 954.566853: rtos_queue_peek_from_isr_failed: tstamp:30475524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 954.734856: rtos_queue_peek_from_isr_failed: tstamp:30480524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 954.902852: rtos_queue_peek_from_isr_failed: tstamp:30485524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 955.014827: rtos_queue_peek_from_isr_failed: tstamp:30490524131 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 955.190848: rtos_queue_peek_from_isr_failed: tstamp:30495524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 955.362843: rtos_queue_peek_from_isr_failed: tstamp:30500524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 955.534882: rtos_queue_peek_from_isr_failed: tstamp:30505524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 955.702874: rtos_queue_peek_from_isr_failed: tstamp:30510524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 955.814879: rtos_queue_peek_from_isr_failed: tstamp:30515524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 955.982883: rtos_queue_peek_from_isr_failed: tstamp:30520524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 956.150874: rtos_queue_peek_from_isr_failed: tstamp:30525524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 956.318857: rtos_queue_peek_from_isr_failed: tstamp:30530524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 956.486855: rtos_queue_peek_from_isr_failed: tstamp:30535524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 956.654842: rtos_queue_peek_from_isr_failed: tstamp:30540524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 956.822865: rtos_queue_peek_from_isr_failed: tstamp:30545524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 956.934867: rtos_queue_peek_from_isr_failed: tstamp:30550524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 957.102841: rtos_queue_peek_from_isr_failed: tstamp:30555524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 957.270853: rtos_queue_peek_from_isr_failed: tstamp:30560524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 957.438847: rtos_queue_peek_from_isr_failed: tstamp:30565524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 957.610841: rtos_queue_peek_from_isr_failed: tstamp:30570524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 957.778841: rtos_queue_peek_from_isr_failed: tstamp:30575524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 957.946850: rtos_queue_peek_from_isr_failed: tstamp:30580524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 958.058853: rtos_queue_peek_from_isr_failed: tstamp:30585524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 958.226859: rtos_queue_peek_from_isr_failed: tstamp:30590524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 958.394870: rtos_queue_peek_from_isr_failed: tstamp:30595524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 958.562848: rtos_queue_peek_from_isr_failed: tstamp:30600524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 958.730860: rtos_queue_peek_from_isr_failed: tstamp:30605524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 958.898857: rtos_queue_peek_from_isr_failed: tstamp:30610524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 959.066851: rtos_queue_peek_from_isr_failed: tstamp:30615524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 959.178864: rtos_queue_peek_from_isr_failed: tstamp:30620524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 959.346873: rtos_queue_peek_from_isr_failed: tstamp:30625524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 959.514848: rtos_queue_peek_from_isr_failed: tstamp:30630524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 959.686880: rtos_queue_peek_from_isr_failed: tstamp:30635524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 959.858868: rtos_queue_peek_from_isr_failed: tstamp:30640524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 960.026855: rtos_queue_peek_from_isr_failed: tstamp:30645524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 960.138913: rtos_queue_peek_from_isr_failed: tstamp:30650524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 960.306877: rtos_queue_peek_from_isr_failed: tstamp:30655524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 960.474870: rtos_queue_peek_from_isr_failed: tstamp:30660524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 960.642862: rtos_queue_peek_from_isr_failed: tstamp:30665524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 960.811000: rtos_queue_peek_from_isr_failed: tstamp:30670524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 960.978953: rtos_queue_peek_from_isr_failed: tstamp:30675524318 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 961.147051: rtos_queue_peek_from_isr_failed: tstamp:30680524319 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 961.258893: rtos_queue_peek_from_isr_failed: tstamp:30685524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 961.426989: rtos_queue_peek_from_isr_failed: tstamp:30690524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 961.594886: rtos_queue_peek_from_isr_failed: tstamp:30695524329 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 961.762898: rtos_queue_peek_from_isr_failed: tstamp:30700524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 961.930873: rtos_queue_peek_from_isr_failed: tstamp:30705524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 962.098885: rtos_queue_peek_from_isr_failed: tstamp:30710524336 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 962.266871: rtos_queue_peek_from_isr_failed: tstamp:30715524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 962.378904: rtos_queue_peek_from_isr_failed: tstamp:30720524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 962.550901: rtos_queue_peek_from_isr_failed: tstamp:30725524139 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 962.718902: rtos_queue_peek_from_isr_failed: tstamp:30730524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 962.886896: rtos_queue_peek_from_isr_failed: tstamp:30735524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 963.054871: rtos_queue_peek_from_isr_failed: tstamp:30740524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 963.222897: rtos_queue_peek_from_isr_failed: tstamp:30745524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 963.338882: rtos_queue_peek_from_isr_failed: tstamp:30750524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 963.510922: rtos_queue_peek_from_isr_failed: tstamp:30755524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 963.678889: rtos_queue_peek_from_isr_failed: tstamp:30760524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 963.846891: rtos_queue_peek_from_isr_failed: tstamp:30765524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 964.018887: rtos_queue_peek_from_isr_failed: tstamp:30770524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 964.186878: rtos_queue_peek_from_isr_failed: tstamp:30775524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 964.298923: rtos_queue_peek_from_isr_failed: tstamp:30780524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 964.466918: rtos_queue_peek_from_isr_failed: tstamp:30785524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 964.634898: rtos_queue_peek_from_isr_failed: tstamp:30790524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 964.802888: rtos_queue_peek_from_isr_failed: tstamp:30795524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 964.970922: rtos_queue_peek_from_isr_failed: tstamp:30800524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 965.138870: rtos_queue_peek_from_isr_failed: tstamp:30805524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 965.254889: rtos_queue_peek_from_isr_failed: tstamp:30810524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 965.422931: rtos_queue_peek_from_isr_failed: tstamp:30815524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .n.. 965.594971: rtos_queue_peek_from_isr_failed: tstamp:30820524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 965.762908: rtos_queue_peek_from_isr_failed: tstamp:30825524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 965.934899: rtos_queue_peek_from_isr_failed: tstamp:30830524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 966.102900: rtos_queue_peek_from_isr_failed: tstamp:30835524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 966.214917: rtos_queue_peek_from_isr_failed: tstamp:30840524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 966.382899: rtos_queue_peek_from_isr_failed: tstamp:30845524131 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 966.550913: rtos_queue_peek_from_isr_failed: tstamp:30850524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 966.722940: rtos_queue_peek_from_isr_failed: tstamp:30855524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 966.895088: rtos_queue_peek_from_isr_failed: tstamp:30860524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 967.062906: rtos_queue_peek_from_isr_failed: tstamp:30865524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 967.182947: rtos_queue_peek_from_isr_failed: tstamp:30870524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 967.350959: rtos_queue_peek_from_isr_failed: tstamp:30875524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 967.518886: rtos_queue_peek_from_isr_failed: tstamp:30880524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 967.686905: rtos_queue_peek_from_isr_failed: tstamp:30885524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 967.854930: rtos_queue_peek_from_isr_failed: tstamp:30890524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 968.022902: rtos_queue_peek_from_isr_failed: tstamp:30895524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 968.134940: rtos_queue_peek_from_isr_failed: tstamp:30900524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 968.302906: rtos_queue_peek_from_isr_failed: tstamp:30905524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 968.470923: rtos_queue_peek_from_isr_failed: tstamp:30910524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 968.639789: rtos_queue_peek_from_isr_failed: tstamp:30915524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 968.814907: rtos_queue_peek_from_isr_failed: tstamp:30920524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 968.982934: rtos_queue_peek_from_isr_failed: tstamp:30925524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 969.094905: rtos_queue_peek_from_isr_failed: tstamp:30930524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 969.262906: rtos_queue_peek_from_isr_failed: tstamp:30935524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 969.430937: rtos_queue_peek_from_isr_failed: tstamp:30940524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 969.598948: rtos_queue_peek_from_isr_failed: tstamp:30945524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 969.766956: rtos_queue_peek_from_isr_failed: tstamp:30950524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 969.934949: rtos_queue_peek_from_isr_failed: tstamp:30955524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 970.106939: rtos_queue_peek_from_isr_failed: tstamp:30960524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 970.218912: rtos_queue_peek_from_isr_failed: tstamp:30965524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 970.386937: rtos_queue_peek_from_isr_failed: tstamp:30970524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 970.554941: rtos_queue_peek_from_isr_failed: tstamp:30975524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 970.722936: rtos_queue_peek_from_isr_failed: tstamp:30980524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 970.890925: rtos_queue_peek_from_isr_failed: tstamp:30985524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 971.058908: rtos_queue_peek_from_isr_failed: tstamp:30990524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 971.226921: rtos_queue_peek_from_isr_failed: tstamp:30995524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 971.338916: rtos_queue_peek_from_isr_failed: tstamp:31000524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 971.506938: rtos_queue_peek_from_isr_failed: tstamp:31005524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 971.674920: rtos_queue_peek_from_isr_failed: tstamp:31010524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 971.846902: rtos_queue_peek_from_isr_failed: tstamp:31015524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 972.014942: rtos_queue_peek_from_isr_failed: tstamp:31020524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 972.182928: rtos_queue_peek_from_isr_failed: tstamp:31025524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 972.294919: rtos_queue_peek_from_isr_failed: tstamp:31030524137 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 972.462956: rtos_queue_peek_from_isr_failed: tstamp:31035524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 972.638914: rtos_queue_peek_from_isr_failed: tstamp:31040524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 972.806927: rtos_queue_peek_from_isr_failed: tstamp:31045524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 972.974968: rtos_queue_peek_from_isr_failed: tstamp:31050524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 973.146935: rtos_queue_peek_from_isr_failed: tstamp:31055524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 973.258918: rtos_queue_peek_from_isr_failed: tstamp:31060524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 973.426951: rtos_queue_peek_from_isr_failed: tstamp:31065524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 973.598944: rtos_queue_peek_from_isr_failed: tstamp:31070524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 973.766938: rtos_queue_peek_from_isr_failed: tstamp:31075524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 973.934949: rtos_queue_peek_from_isr_failed: tstamp:31080524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 974.106950: rtos_queue_peek_from_isr_failed: tstamp:31085524137 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 974.218942: rtos_queue_peek_from_isr_failed: tstamp:31090524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 974.390941: rtos_queue_peek_from_isr_failed: tstamp:31095524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 974.558975: rtos_queue_peek_from_isr_failed: tstamp:31100524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 974.726949: rtos_queue_peek_from_isr_failed: tstamp:31105524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 974.894952: rtos_queue_peek_from_isr_failed: tstamp:31110524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 975.063148: rtos_queue_peek_from_isr_failed: tstamp:31115524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 975.175128: rtos_queue_peek_from_isr_failed: tstamp:31120524307 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 975.343018: rtos_queue_peek_from_isr_failed: tstamp:31125524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 975.510949: rtos_queue_peek_from_isr_failed: tstamp:31130524137 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 975.678961: rtos_queue_peek_from_isr_failed: tstamp:31135524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 975.850964: rtos_queue_peek_from_isr_failed: tstamp:31140524131 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 976.023394: rtos_queue_peek_from_isr_failed: tstamp:31145524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 976.138967: rtos_queue_peek_from_isr_failed: tstamp:31150524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 976.306934: rtos_queue_peek_from_isr_failed: tstamp:31155524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 976.474967: rtos_queue_peek_from_isr_failed: tstamp:31160524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 976.642948: rtos_queue_peek_from_isr_failed: tstamp:31165524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 976.810962: rtos_queue_peek_from_isr_failed: tstamp:31170524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 976.983539: rtos_queue_peek_from_isr_failed: tstamp:31175524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 977.094948: rtos_queue_peek_from_isr_failed: tstamp:31180524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 977.262949: rtos_queue_peek_from_isr_failed: tstamp:31185524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 977.434958: rtos_queue_peek_from_isr_failed: tstamp:31190524137 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 977.602957: rtos_queue_peek_from_isr_failed: tstamp:31195524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 977.770995: rtos_queue_peek_from_isr_failed: tstamp:31200524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 977.938954: rtos_queue_peek_from_isr_failed: tstamp:31205524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 978.106957: rtos_queue_peek_from_isr_failed: tstamp:31210524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 978.218958: rtos_queue_peek_from_isr_failed: tstamp:31215524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 978.386973: rtos_queue_peek_from_isr_failed: tstamp:31220524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 978.558946: rtos_queue_peek_from_isr_failed: tstamp:31225524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 978.726955: rtos_queue_peek_from_isr_failed: tstamp:31230524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 978.894961: rtos_queue_peek_from_isr_failed: tstamp:31235524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 979.062987: rtos_queue_peek_from_isr_failed: tstamp:31240524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 979.174962: rtos_queue_peek_from_isr_failed: tstamp:31245524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 979.343249: rtos_queue_peek_from_isr_failed: tstamp:31250524318 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 979.515122: rtos_queue_peek_from_isr_failed: tstamp:31255524319 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 979.683059: rtos_queue_peek_from_isr_failed: tstamp:31260524328 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 979.850993: rtos_queue_peek_from_isr_failed: tstamp:31265524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 980.018959: rtos_queue_peek_from_isr_failed: tstamp:31270524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 980.186975: rtos_queue_peek_from_isr_failed: tstamp:31275524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 980.299012: rtos_queue_peek_from_isr_failed: tstamp:31280524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 980.466982: rtos_queue_peek_from_isr_failed: tstamp:31285524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 980.634971: rtos_queue_peek_from_isr_failed: tstamp:31290524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 980.802967: rtos_queue_peek_from_isr_failed: tstamp:31295524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 980.979007: rtos_queue_peek_from_isr_failed: tstamp:31300524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 981.146979: rtos_queue_peek_from_isr_failed: tstamp:31305524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 981.258961: rtos_queue_peek_from_isr_failed: tstamp:31310524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 981.426996: rtos_queue_peek_from_isr_failed: tstamp:31315524140 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 981.594997: rtos_queue_peek_from_isr_failed: tstamp:31320524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 981.766989: rtos_queue_peek_from_isr_failed: tstamp:31325524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 981.935017: rtos_queue_peek_from_isr_failed: tstamp:31330524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 982.102988: rtos_queue_peek_from_isr_failed: tstamp:31335524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 982.214979: rtos_queue_peek_from_isr_failed: tstamp:31340524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 982.382974: rtos_queue_peek_from_isr_failed: tstamp:31345524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 982.550982: rtos_queue_peek_from_isr_failed: tstamp:31350524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 982.718982: rtos_queue_peek_from_isr_failed: tstamp:31355524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 982.886960: rtos_queue_peek_from_isr_failed: tstamp:31360524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 983.054986: rtos_queue_peek_from_isr_failed: tstamp:31365524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 983.223005: rtos_queue_peek_from_isr_failed: tstamp:31370524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 983.334961: rtos_queue_peek_from_isr_failed: tstamp:31375524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 983.502988: rtos_queue_peek_from_isr_failed: tstamp:31380524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 983.674978: rtos_queue_peek_from_isr_failed: tstamp:31385524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 983.842996: rtos_queue_peek_from_isr_failed: tstamp:31390524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 984.010986: rtos_queue_peek_from_isr_failed: tstamp:31395524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 984.182983: rtos_queue_peek_from_isr_failed: tstamp:31400524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 984.295003: rtos_queue_peek_from_isr_failed: tstamp:31405524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 984.462996: rtos_queue_peek_from_isr_failed: tstamp:31410524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 984.630992: rtos_queue_peek_from_isr_failed: tstamp:31415524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 984.798976: rtos_queue_peek_from_isr_failed: tstamp:31420524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 984.966978: rtos_queue_peek_from_isr_failed: tstamp:31425524131 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 985.139020: rtos_queue_peek_from_isr_failed: tstamp:31430524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 985.254977: rtos_queue_peek_from_isr_failed: tstamp:31435524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 985.423017: rtos_queue_peek_from_isr_failed: tstamp:31440524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 985.590994: rtos_queue_peek_from_isr_failed: tstamp:31445524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 985.759017: rtos_queue_peek_from_isr_failed: tstamp:31450524134 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 985.927021: rtos_queue_peek_from_isr_failed: tstamp:31455524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 986.095143: rtos_queue_peek_from_isr_failed: tstamp:31460524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 986.267167: rtos_queue_peek_from_isr_failed: tstamp:31465524314 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 986.379117: rtos_queue_peek_from_isr_failed: tstamp:31470524320 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 986.547214: rtos_queue_peek_from_isr_failed: tstamp:31475524313 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 986.719224: rtos_queue_peek_from_isr_failed: tstamp:31480524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 986.887162: rtos_queue_peek_from_isr_failed: tstamp:31485524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 987.055293: rtos_queue_peek_from_isr_failed: tstamp:31490524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 987.223102: rtos_queue_peek_from_isr_failed: tstamp:31495524324 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 987.335094: rtos_queue_peek_from_isr_failed: tstamp:31500524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 987.503137: rtos_queue_peek_from_isr_failed: tstamp:31505524319 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 987.679180: rtos_queue_peek_from_isr_failed: tstamp:31510524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 987.847120: rtos_queue_peek_from_isr_failed: tstamp:31515524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 988.015186: rtos_queue_peek_from_isr_failed: tstamp:31520524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 988.187033: rtos_queue_peek_from_isr_failed: tstamp:31525524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 988.299186: rtos_queue_peek_from_isr_failed: tstamp:31530524311 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 988.467130: rtos_queue_peek_from_isr_failed: tstamp:31535524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 988.635101: rtos_queue_peek_from_isr_failed: tstamp:31540524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 988.803080: rtos_queue_peek_from_isr_failed: tstamp:31545524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 988.971092: rtos_queue_peek_from_isr_failed: tstamp:31550524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 989.143006: rtos_queue_peek_from_isr_failed: tstamp:31555524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 989.255100: rtos_queue_peek_from_isr_failed: tstamp:31560524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 989.423159: rtos_queue_peek_from_isr_failed: tstamp:31565524324 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 989.595076: rtos_queue_peek_from_isr_failed: tstamp:31570524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 989.763055: rtos_queue_peek_from_isr_failed: tstamp:31575524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 989.931027: rtos_queue_peek_from_isr_failed: tstamp:31580524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 990.103064: rtos_queue_peek_from_isr_failed: tstamp:31585524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 990.219301: rtos_queue_peek_from_isr_failed: tstamp:31590524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 990.387208: rtos_queue_peek_from_isr_failed: tstamp:31595524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 990.559180: rtos_queue_peek_from_isr_failed: tstamp:31600524319 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 990.727224: rtos_queue_peek_from_isr_failed: tstamp:31605524318 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 990.899129: rtos_queue_peek_from_isr_failed: tstamp:31610524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 991.015270: rtos_queue_peek_from_isr_failed: tstamp:31615524318 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 991.183212: rtos_queue_peek_from_isr_failed: tstamp:31620524316 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 991.351162: rtos_queue_peek_from_isr_failed: tstamp:31625524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 991.519186: rtos_queue_peek_from_isr_failed: tstamp:31630524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 991.687177: rtos_queue_peek_from_isr_failed: tstamp:31635524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 991.855266: rtos_queue_peek_from_isr_failed: tstamp:31640524307 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 992.027234: rtos_queue_peek_from_isr_failed: tstamp:31645524313 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 992.139243: rtos_queue_peek_from_isr_failed: tstamp:31650524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 992.307134: rtos_queue_peek_from_isr_failed: tstamp:31655524313 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 992.475132: rtos_queue_peek_from_isr_failed: tstamp:31660524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 992.643012: rtos_queue_peek_from_isr_failed: tstamp:31665524313 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 992.811285: rtos_queue_peek_from_isr_failed: tstamp:31670524314 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 992.979185: rtos_queue_peek_from_isr_failed: tstamp:31675524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 993.147168: rtos_queue_peek_from_isr_failed: tstamp:31680524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 993.263420: rtos_queue_peek_from_isr_failed: tstamp:31685524314 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 993.431180: rtos_queue_peek_from_isr_failed: tstamp:31690524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 993.599117: rtos_queue_peek_from_isr_failed: tstamp:31695524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 993.767179: rtos_queue_peek_from_isr_failed: tstamp:31700524324 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 993.935174: rtos_queue_peek_from_isr_failed: tstamp:31705524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 994.103149: rtos_queue_peek_from_isr_failed: tstamp:31710524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 994.215373: rtos_queue_peek_from_isr_failed: tstamp:31715524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 994.383241: rtos_queue_peek_from_isr_failed: tstamp:31720524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 994.551239: rtos_queue_peek_from_isr_failed: tstamp:31725524316 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 994.719156: rtos_queue_peek_from_isr_failed: tstamp:31730524323 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 994.887068: rtos_queue_peek_from_isr_failed: tstamp:31735524316 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 995.055165: rtos_queue_peek_from_isr_failed: tstamp:31740524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 995.223124: rtos_queue_peek_from_isr_failed: tstamp:31745524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 995.339128: rtos_queue_peek_from_isr_failed: tstamp:31750524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 995.511118: rtos_queue_peek_from_isr_failed: tstamp:31755524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 995.683163: rtos_queue_peek_from_isr_failed: tstamp:31760524316 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 995.851183: rtos_queue_peek_from_isr_failed: tstamp:31765524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 996.019135: rtos_queue_peek_from_isr_failed: tstamp:31770524316 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 996.187120: rtos_queue_peek_from_isr_failed: tstamp:31775524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 996.299259: rtos_queue_peek_from_isr_failed: tstamp:31780524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 996.471186: rtos_queue_peek_from_isr_failed: tstamp:31785524313 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 996.639172: rtos_queue_peek_from_isr_failed: tstamp:31790524316 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 996.807270: rtos_queue_peek_from_isr_failed: tstamp:31795524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 996.979189: rtos_queue_peek_from_isr_failed: tstamp:31800524311 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 997.147189: rtos_queue_peek_from_isr_failed: tstamp:31805524314 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 997.259190: rtos_queue_peek_from_isr_failed: tstamp:31810524309 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 997.431057: rtos_queue_peek_from_isr_failed: tstamp:31815524313 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 997.599124: rtos_queue_peek_from_isr_failed: tstamp:31820524309 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 997.771115: rtos_queue_peek_from_isr_failed: tstamp:31825524318 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 997.939089: rtos_queue_peek_from_isr_failed: tstamp:31830524313 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 998.107173: rtos_queue_peek_from_isr_failed: tstamp:31835524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 998.219169: rtos_queue_peek_from_isr_failed: tstamp:31840524310 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 998.391075: rtos_queue_peek_from_isr_failed: tstamp:31845524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 998.559205: rtos_queue_peek_from_isr_failed: tstamp:31850524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 998.727217: rtos_queue_peek_from_isr_failed: tstamp:31855524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 998.895206: rtos_queue_peek_from_isr_failed: tstamp:31860524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 999.063231: rtos_queue_peek_from_isr_failed: tstamp:31865524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 999.175243: rtos_queue_peek_from_isr_failed: tstamp:31870524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 999.343399: rtos_queue_peek_from_isr_failed: tstamp:31875524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 999.515208: rtos_queue_peek_from_isr_failed: tstamp:31880524320 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 999.683279: rtos_queue_peek_from_isr_failed: tstamp:31885524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 999.851142: rtos_queue_peek_from_isr_failed: tstamp:31890524314 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 1000.023350: rtos_queue_peek_from_isr_failed: tstamp:31895524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 1000.135208: rtos_queue_peek_from_isr_failed: tstamp:31900524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 1000.307304: rtos_queue_peek_from_isr_failed: tstamp:31905524136 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 1000.483317: rtos_queue_peek_from_isr_failed: tstamp:31910524135 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 1000.655127: rtos_queue_peek_from_isr_failed: tstamp:31915524313 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 1000.823160: rtos_queue_peek_from_isr_failed: tstamp:31920524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 1000.935134: rtos_queue_peek_from_isr_failed: tstamp:31925524315 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 1001.103281: rtos_queue_peek_from_isr_failed: tstamp:31930524141 queue:0x0bcbbbb8
kworker/0:3-1901 [000] .... 1001.271156: rtos_queue_peek_from_isr_failed: tstamp:31935524315 queue:0x0bcbbbb8
From the above, I can see that there is no communication with MIPI bus.
However, I don’t know how to solve the problem from here.
Where do I need to fix this?
Consult with vendor to confirm the sensor REG configure also probe the MIPI bus to check the signal to confirm it sensor have output data.
I’m sorry for the late reply.
Does this mean you want to make sure the camera is working?
Yes, the log tell didn’t receive any validate data from MIPI bus.
Camera worked on my jetson nano, so I know it’s not a camera problem.
Is there something wrong with the device tree in this case?
You need to review the DTS depend on your HW connection to confirm it first.
system
closed
March 23, 2022, 4:25am
#13
