My code has two functions
A(int[] a, int size)
B(int[][] b, int size, int []c)
I would like to execute each function on a block with 32 different inputs. My thought is to put these varaibles on a struct and declare an array of a struct. This means that the struct has the following
typedef struct{
int[] a;
int size;
int [][] b;
in[] c;
int choice;
In the kernel,
if (data[threadId].choice == 1)
execute function A
else
execute function B
The issue with this approach is that I will have an array b and c that are declared in the memory with no usage. It there a better way to not declaring unused variables for some threads?
