jackto
November 6, 2020, 2:48am
1
Hello
i have a jetson xavier NX
and use deepstream v5.0
i have a 3 source and make a batch using streammux plugin
and it infer all the source in the batch when i infer after streammux
but i want to infer only one source in the batch others bypass.
can i make this stream?
Current nvinfer does not support such function.
jackto
November 6, 2020, 4:51am
4
Thanks for reply!!
if so is there any way to make this process personally even nvinfer plugin source edit?
like as below
This sample is hard code way. You can try that.
jackto
November 6, 2020, 7:42am
6
Ok Thanks!
can i get the deepstream plugin source?? for example nvstreammux?
After you install the DeepStreamSDK in your device, you can get the open source deepstream plugin codes under /opt/nvidia/deepstream/deepstream-5.0/sources/gst-plugins/
The other source codes are private.
