Different ISP setting for 2 cameras?
Hi All,
I am using 2 IMX219 Camera, which 1 of them is a normal camera, and the other one is a wide angle camera. While the normal camera work just fine, the wide angle camera have an unusual pink tint.
I follow
https://www.waveshare.com/wiki/IMX219-77_Camera
to fix the pink tint.
But now the normal camera have a green tint. Which both pink and green tint affect the (NN) model performance.
I am looking into a solution where I can apply the isp setting to 1 camera only. I found
https://forums.developer.nvidia.com/t/sensor-processing-engine-one-overrides-isp-file-for-all-inputs/178009/3
and also
https://forums.developer.nvidia.com/t/how-to-use-different-isp-setting-for-2-different-cameras/76681/7
I tired open the the device tree blob in /boot/dtb with dtc and it shows
                        rbpcv2_imx219_a@10 {
                                compatible = "nvidia,imx219";
                                reg = <0x10>;
                                devnode = "video0";
                                physical_w = "3.680";
                                physical_h = "2.760";
                                sensor_model = "imx219";
                                use_sensor_mode_id = "true";
                                reset-gpios = <0x5b 0x97 0x0>;
                                linux,phandle = <0x125>;
                                phandle = <0x125>;
                        rbpcv2_imx219_e@10 {
                                reg = <0x10>;
                                devnode = "video1";
                                reset-gpios = <0x5b 0x98 0x0>;
                                linux,phandle = <0x129>;
                                phandle = <0x129>;
I cannot find any badgefield. Please kindly advice how to apply ISP to only 1 camera (with same chip but different lens).
Many thanks!
The badge info in the tegra_camera_platform{}
for a detail solution:
device tree can be view as file in
/sys/firmware/devicetree/base/
for B01 carrier board:
cam0 badge: porg_front_RBPCV2
cam11badge: porg_front_RBPCV2
To set specific ISP: name the isp with the badge and place inside the setting file in
/var/nvidia/nvcam/settings
sudo mv camera_overrides.isp  porg_front_RBPCV2.isp
