I am trying to estimate the FLOP of a inverted residual block of MobileNet-v3-large architecture and find the following observation which I am not able to understand.
The first Conv2d having filter dimension (960, 160, 1, 1) for an input feature map of dimension (160, 7, 7), NCU reports that the kernel sm80_xmma_fprop_implicit_gemm_tf32f32_tf32f32_f32_nhwckrsc_nchw_tilesize128x128x16_stage4_warpsize2x2x1_g1_tensor16x8x8_alignc4_execute_kernel__5x_cudnn is being used, where as in the last Conv2d layer of the module having filter dimension (160, 960, 1, 1) for an input feature map of dimension (160, 7, 7), NCU reports that the kernel ..cutlass_80_tensorop_s1688gemm_64x64_16x6_nn_align1...
Where as in another module of the same architecture, the first and last Conv layers having similar dimensions with input and output channels swapped, we observe the use of same kernel.
Can someone explain the non-uniformity here?
