Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
DRIVE OS Linux 5.2.0
[*] other DRIVE OS version
other
Target Operating System
Linux
[*] QNX
other
Hardware Platform
[*] other
SDK Manager Version
1.5.0.7774
[*] other
Host Machine Version
native Ubuntu 18.04
[*] other
I am attempting to extend nvscistream unicast safety sample to use different types of buffer - nvmedia image buffer and raw buffer in a single packet of nvstream. The packet is to be exchanged between 2 qnx processes over a single nvstream in unicast fashion.
When running both producer and consumer in 2 separate terminals on QNX in Nvidia Drive Xavier system using pdk526.
These are the errors I get on producer sample
[ERROR: NvSciBufAttrListAreDataTypeCompatible]: bufTypes 1 and 2 cannot be reconciled
[ERROR: NvSciBufAttrListReconcile]: NvSciBuf datatypes cannot be reconciled
My question is does nvstream not support multiple buffer types in a single packet? If not, what option do I have when I need to make sure that these 2 buffers need to be sent aligned in the same fence/semaphore lock?
Here is the sample code for creating buffAttributes for 2 different buffers:
virtual void createBufAttrList(NvSciBufModule bufModule) {
// Setup NvMedia buffets
setupBuffers(bufModule);
// create attr requirements
for (uint32_t i = 0U; i < 1; i++) {
CHECK_NVSCIERR(NvSciBufAttrListCreate(bufModule, &bufAttrLists[i]));
LOG_DEBUG("Create NvSciBuf attribute list of element " << i << “.”);
NvSciBufAttrList attrList = bufAttrLists[i];
NvSciBufAttrValAccessPerm access_perm = NvSciBufAccessPerm_ReadWrite;
NvSciBufAttrKeyValuePair attrKvp = {NvSciBufGeneralAttrKey_RequiredPerm, &access_perm, sizeof(access_perm)};
NvMediaSurfaceType nvmsurfType;
NVM_SURF_FMT_DEFINE_ATTR(surfFormatAttrs);
NvMediaSurfAllocAttr surfAllocAttrs[NVM_SURF_ALLOC_ATTR_MAX];
uint32_t numSurfAllocAttrs = 0;
// Create YUV 422 PL images with cpu mapping pointer
NVM_SURF_FMT_SET_ATTR_YUV(surfFormatAttrs, YUYV, 422, PACKED, UINT, 8, PL);
nvmsurfType = NvMediaSurfaceFormatGetType(surfFormatAttrs, NVM_SURF_FMT_ATTR_MAX);
surfAllocAttrs[0].type = NVM_SURF_ATTR_WIDTH;
surfAllocAttrs[0].value = WIDTH;
surfAllocAttrs[1].type = NVM_SURF_ATTR_HEIGHT;
surfAllocAttrs[1].value = HEIGHT;
surfAllocAttrs[2].type = NVM_SURF_ATTR_CPU_ACCESS;
surfAllocAttrs[2].value = NVM_SURF_ATTR_CPU_ACCESS_CACHED;
numSurfAllocAttrs = 3;
CHECK_NVSCIERR(NvSciBufAttrListSetAttrs(attrList, &attrKvp, 1));
CHECK_NVMEDIAERR(
NvMediaImageFillNvSciBufAttrs(nvmdevice, nvmsurfType, surfAllocAttrs, numSurfAllocAttrs, 0, attrList));
LOG_DEBUG("Set attribute value of element " << i << ".");
int idx2 = 1;
// 2nd element - metadata
CHECK_NVSCIERR(NvSciBufAttrListCreate(bufModule, &bufAttrLists[idx2]));
LOG_DEBUG(" Create NvSciBuf attribute list of element " << idx2 << “.”);
NvSciBufAttrList attrList = bufAttrLists[idx2];
NvSciRmGpuId gpuId;
CUuuid uuid;
CHECK_CUDAERR(cuDeviceGetUuid(&uuid, m_cudaDeviceId));
memcpy(&gpuId.bytes, &uuid.bytes, sizeof(uuid.bytes));
NvSciBufAttrKeyValuePair genBufAttrs = {
{ NvSciBufGeneralAttrKey_GpuId, &gpuId, sizeof(gpuId) }
genBufAttrs,
sizeof(genBufAttrs)/sizeof(NvSciBufAttrKeyValuePair)));
NvSciBufType bufType = NvSciBufType_RawBuffer;
NvSciBufAttrValAccessPerm perm = NvSciBufAccessPerm_ReadWrite;
bool cpuaccess_flag = true;
uint64_t rawsize = sizeof(Metadata_t);
uint64_t align = 1;
NvSciBufAttrKeyValuePair rawBufAttrs = {
{ NvSciBufGeneralAttrKey_Types, &bufType, sizeof(bufType) },
{ NvSciBufGeneralAttrKey_RequiredPerm, &perm, sizeof(perm) },
{ NvSciBufGeneralAttrKey_NeedCpuAccess, &cpuaccess_flag, sizeof(cpuaccess_flag) },
{ NvSciBufRawBufferAttrKey_Size, &rawsize, sizeof(rawsize) },
{ NvSciBufRawBufferAttrKey_Align, &align, sizeof(align) },
rawBufAttrs,
sizeof(rawBufAttrs) / sizeof(NvSciBufAttrKeyValuePair)));
LOG_DEBUG("Set Attribute value of element " << idx2 << “.”);
