Hi, I’m still in the porting phase of a large Fortran code from Gfortran to NVfortran and I have a different behavior that can be illustrated with the small following test code. In my mind, nvfortran 22.2 is wrong but it could be also gfortran (not a large OpenMP experience). Indeed I need to have the same behavior…
Code:
module mod1
implicit none
integer ::nsolver,current_solver
!$OMP THREADPRIVATE(nsolver,current_solver)
end module mod1
program main
use mod1
implicit none
nsolver=3
current_solver=nsolver+1
!$OMP PARALLEL DEFAULT(PRIVATE) &
!$OMP COPYIN(nsolver,current_solver)
print*, 'test ',nsolver,current_solver
!$OMP end PARALLEL
end program main
Using gfortran and 4 threads:
> bash-4.4$ gfortran -fopenmp main.f90
> bash-4.4$ ./a.out
> test 3 4
> test 3 4
> test 3 4
> test 3 4
Using nvfortran and 4 threads:
> bash-4.4$ nvfortran -mp=multicore main.f90
> bash-4.4$ ./a.out
> test 3 4
> test 3 0
> test 3 0
> test 3 0
With nvfortran the second threadprivate variable is not initialized by the copyin clause, only the first one.
Any suggestion ?
Patrick
