I have a very simple case that shoots just one ray at a single triangle. The results vary ever so slightly depending on the hardware compute capability where the application is run. Both machines have identical Optix 7.0 libraries installed and are running the same executable with compilation limited to just compute_60,sm_60. Here are the results in which the hardware type, 3 triangle vertices, then launch and hit info are printed. There is a slight difference in the hit distance, t:
GeForce RTX 2080 Ti, compute capability = 75
v0 1.99999988e-01 -1.99999988e-01 1.99999988e-01
v1 0.00000000e+00 0.00000000e+00 1.99999988e-01
v2 0.00000000e+00 0.00000000e+00 -1.99999988e-01
origin: 2.09999993e-01 -9.99999940e-02 9.99999940e-02
dir: -1.00000000e+00 0.00000000e+00 0.00000000e+00
t = 1.09999992e-01 <---- DIFFERENCE HERE
u = 2.49999985e-01
v = 2.49999985e-01
GeForce GTX 1060, compute capability = 61
t = 1.09999999e-01 <---- DIFFERENCE HERE
u = 2.49999985e-01
v = 2.49999985e-01
When I shoot a denser set of rays, then there can be slight differences observed in the resulting t, u, and/or v values – or no differences at all. It seems as if there is a variation in the least significant bit of the result.
By any chance, is there a way to make these ray trace results identical? Thanks.
