Different results for the same application using nsight compute
I’m encountering a discrepancy in execution times while profiling a vector reduction application across Linux and Windows environments.
In Linux, I run the following command to launch the application and then attach it to Nsight Compute:
bash
Copy code
ncu --mode=launch ./01
In Windows, I use Visual Studio with the Nsight extension to open Nsight Compute directly from the extension. The application code and configuration are identical in both environments.
However, I’ve observed a substantial difference in execution times between the two platforms. For instance, the first kernel reports 69 microseconds on Linux, but 284 microseconds on Windows.
Could anyone help explain why this discrepancy occurs or suggest adjustments to achieve more consistent profiling results across both operating systems?
Thank you!
here is the code
include
include <cuda_runtime.h>
global void reduce_in_place(float* input, int n) {
int tid = threadIdx.x;
int index = blockIdx.x * blockDim.x + threadIdx.x;
// Perform in-place reduction within each block
for (int stride = 1; stride < blockDim.x; stride *= 2) {
    __syncthreads();  // Ensure all threads have completed the previous iteration
    if (tid % (2 * stride) == 0 && index + stride < n) {
        // Perform reduction and store the sum back in place
        input[index] += input[index + stride];
// Store the block's reduced result in the first position of this block's portion
if (tid == 0) {
    input[blockIdx.x] = input[blockIdx.x * blockDim.x];  // Write the reduced sum for this block
float cpu_reduce(float* input, int size) {
float sum = 0.0f;
for (int i = 0; i < size; ++i) {
sum += input[i];
return sum;
int main() {
int n = 1024 * 1024; // Number of elements
size_t bytes = n * sizeof(float);
// Host memory allocation
float* h_input = new float[n];
float* d_input;
// Initialize input array
for (int i = 0; i < n; i++) {
    h_input[i] = static_cast<float>(i + 1);  // Initialize from 1 to n
// Device memory allocation
cudaMalloc(&d_input, bytes);
// Copy data from host to device
cudaMemcpy(d_input, h_input, bytes, cudaMemcpyHostToDevice);
// Launch the reduction kernel multiple times
int blockSize = 256;  // Number of threads per block
int gridSize = (n + blockSize - 1) / blockSize;  // Number of blocks
// Calculate the sum using the CPU function for verification
float total_sum = cpu_reduce(h_input, 1024 * 1024);
std::cout << "Total sum (CPU): " << total_sum << std::endl;
// Perform iterative reduction until we have one block left
reduce_in_place << <gridSize, blockSize >> > (d_input, n);
cudaDeviceSynchronize();  // Ensure kernel execution completes
reduce_in_place << <16, blockSize >> > (d_input, 4096);
// Final reduction when gridSize is 1
reduce_in_place << <1, blockSize >> > (d_input, 16);
// Copy the final result back to the host (the sum should be in h_input[0])
cudaMemcpy(h_input, d_input, sizeof(float), cudaMemcpyDeviceToHost);
// Print the result
std::cout << "Final sum (GPU): " << h_input[0] << std::endl;
// Free memory
cudaFree(d_input);
delete[] h_input;
return 0;
Hi, @user40368
Sorry for the late response.
Given that the driver implementations differ significantly on Windows and Linux, we shouldn’t assume the execution time to be equal.
