I am trying to use the VechicleTypeNet Pruned model to classify the car provided in the image.
The same model was hosted on a triton inference server and was used in a deepstream pipeline with nvinferserver plugin.
config.pbtxt for the model :
platform: "tensorrt_plan"
max_batch_size: 1
input [
data_type: TYPE_FP32
format:FORMAT_NCHW
dims: [3,224,224]
output [
dims: [6,1,1]
The post processing steps followed before inference using the triton infer server :
img = cv2.resize(img,(224,224))
img4 = cv2.cvtColor(img,cv2.COLOR_BGR2RGB)
img4 = img4.astype(np.float32)
img4[:,:,0] -= offset[0]
img4[:,:,1] -= offset[1]
img4[:,:,2] -= offset[2]
img4 = img4*nsf
img4 = np.transpose(img4,(2,0,1))
img4 = np.expand_dims(img4,axis = 0)
offset = [103.939, 116.779, 123.68] and nsf = 1, according the NGC Catalog
The config file attached to the nvinferserver plugin :
infer_config {
unique_id: 5
gpu_ids: [0]
max_batch_size: 1
backend {
trt_is {
model_name: "Vehicle"
version: -1
model_repo {
root: "./"
log_level: 0
preprocess {
network_format: IMAGE_FORMAT_RGB
tensor_order: TENSOR_ORDER_LINEAR
maintain_aspect_ratio: 0
normalize {
scale_factor: 1
channel_offsets: [103.939, 116.779, 123.68]
postprocess {
labelfile_path: "./Vehicle/labels.txt"
other {}
extra {
copy_input_to_host_buffers: false
custom_lib {
path: "/opt/nvidia/deepstream/deepstream/lib/libnvds_infercustomparser.so"
input_control {
process_mode: PROCESS_MODE_FULL_FRAME
interval: 0
output_control {
output_tensor_meta: true
Note: I am using this a primary detector and the input I am giving is only image of a vehicle and it is not part of a Detection Pipeline
Code to get the inference result from the gst-buffer :
detection_layer = layer_finder(output_layer_info, "predictions/Softmax")
if not detection_layer :
sys.stderr.write("ERROR: some layers missing in output tensors\n")
return []
if detection_layer.buffer:
ptr = ctypes.cast(pyds.get_ptr(detection_layer.buffer), ctypes.POINTER(ctypes.c_float))
res = np.ctypeslib.as_array(ptr,shape = (6,1,1))
labels = [ "coupe","largevehicle","sedan","suv","truck","van"]
print('\n\n',"Result Array",res.flatten(),'\n\n')
print('\n\n','Result Index : ',np.argmax(res.flatten()), '\n\n')
print('\n\n','Result Name : ',labels[np.argmax(res.flatten())], '\n\n')
The above code is a modified version of the ssd_parser.py from the deepstream-ssd-parser example.
Can someone please help me identify the issue and reason why I am getting different values after inference.
