Different Tasks on Same Kernel Launch
Hello guys,
I have a short question. Hope to make myself understood. Is it possible to perform different algorithms on the same kernel launch. Here is a quick example:
// Kernel code
int algorithmId = someFunc(threadIdx.x, blockIdx.x)
switch (algorithmId)
case 1:
Do algorithm 1
break;
case 2:
Do algorithm 2
break;
default:
Do something;
break;
Mainly, each algorithm should use data stored inside the global device memory, according to the thread identifiers it resides in.
Thank you,
Valentin
Do you mean:
// Kernel code
device int somFunc(threadIdx.x, blockIdx.x)
global void kernel(…)
case 1:
Do algorithm 1
break;
case 2:
Do algorithm 2
break;
default:
Do something;
break;
As far as I know, you can do it. But you need to take care with divergent branch.
Do you mean:
// Kernel code
case 1:
Do algorithm 1
break;
case 2:
Do algorithm 2
break;
default:
Do something;
break;
Yeah, that’s actually a well known pattern in CUDA programming.
Thanks for the reply.
So I understand that each core has it’s separate instruction FIFO. Is that right ?
However I did not understand what “divergent branch” means.
Cheeers
Valentin
Cheeers
Valentin
