I’ve noticed a critical issue of TensorRT on inconsistent results from the same input when batch size > 1 using the sample code “samples/sampleMNIST.cpp”. I modified the original code “sampleMNIST.cpp” so that it takes batch size 2 and allocated the input (data) and output buffer (prob) twice the size of the original ones. The input buffer (data) is initialized with two identical images (*.ppm) content. However, the output results from the “prob” buffer has entirely different inference results.
Platform:
Ubuntu 16.04
CUDA device driver version: 410.48
CUDA version: 9.0
TensorRT: 4.0.1.6 and 5.0.0.10
The following are:
my source code to recreate the issue.
a screen shot of the inconsistent results.
code block
//! This sample builds a TensorRT engine by importing a trained MNIST Caffe model.
//! It uses the engine to run inference on an input image of a digit.
#include <algorithm>
#include <assert.h>
#include <cmath>
#include <cuda_runtime_api.h>
#include <fstream>
#include <iostream>
#include <sstream>
#include <sys/stat.h>
#include <time.h>
#include "NvCaffeParser.h"
#include "NvInfer.h"
#include "common.h"
using namespace nvinfer1;
using namespace nvcaffeparser1;
static Logger gLogger;
// Attributes of MNIST Caffe model
static const int BATCH_SIZE = 2;
static const int INPUT_C = 1;
static const int INPUT_H = 28;
static const int INPUT_W = 28;
static const int OUTPUT_SIZE = 10;
const char* INPUT_BLOB_NAME = "data";
const char* OUTPUT_BLOB_NAME = "prob";
const string root = "../"; //"/opt/TensorRT-5.0/"; //"/opt/TensorRT-4.0.1.6/";
const std::vector<std::string> directories{root+"data/samples/mnist/", root+"data/mnist/"};
std::string locateFile(const std::string& input)
return locateFile(input, directories);
// Simple PGM (portable greyscale map) reader
void readPGMFile(const std::string& fileName, uint8_t buffer[INPUT_H * INPUT_W])
readPGMFile(fileName, buffer, INPUT_H, INPUT_W);//, INPUT_C);
void caffeToTRTModel(const std::string& deployFile, // Path of Caffe prototxt file
const std::string& modelFile, // Path of Caffe model file
const std::vector<std::string>& outputs, // Names of network outputs
unsigned int maxBatchSize, // Note: Must be at least as large as the batch we want to run with
IHostMemory*& trtModelStream) // Output buffer for the TRT model
// Create builder
IBuilder* builder = createInferBuilder(gLogger);
// Parse caffe model to populate network, then set the outputs
const std::string deployFpath = locateFile(deployFile, directories);
const std::string modelFpath = locateFile(modelFile, directories);
std::cout << "Reading Caffe prototxt: " << deployFpath << "\n";
std::cout << "Reading Caffe model: " << modelFpath << "\n";
INetworkDefinition* network = builder->createNetwork();
ICaffeParser* parser = createCaffeParser();
const IBlobNameToTensor* blobNameToTensor = parser->parse(deployFpath.c_str(),
modelFpath.c_str(),
*network,
DataType::kFLOAT);
// Specify output tensors of network
for (auto& s : outputs)
network->markOutput(*blobNameToTensor->find(s.c_str()));
builder->setMaxBatchSize(maxBatchSize);
builder->setMaxWorkspaceSize(1 << 20);
// Build engine
ICudaEngine* engine = builder->buildCudaEngine(*network);
assert(engine);
// Destroy parser and network
network->destroy();
parser->destroy();
// Serialize engine and destroy it
trtModelStream = engine->serialize();
engine->destroy();
builder->destroy();
shutdownProtobufLibrary();
void doInference(IExecutionContext& context, float* input, float* output, int batchSize)
const ICudaEngine& engine = context.getEngine();
// Pointers to input and output device buffers to pass to engine.
// Engine requires exactly IEngine::getNbBindings() number of buffers.
assert(engine.getNbBindings() == 2);
void* buffers[2];
// In order to bind the buffers, we need to know the names of the input and output tensors.
// Note that indices are guaranteed to be less than IEngine::getNbBindings()
const int inputIndex = engine.getBindingIndex(INPUT_BLOB_NAME);
const int outputIndex = engine.getBindingIndex(OUTPUT_BLOB_NAME);
// Create GPU buffers on device
CHECK(cudaMalloc(&buffers[inputIndex], batchSize * INPUT_H * INPUT_W * sizeof(float)));
CHECK(cudaMalloc(&buffers[outputIndex], batchSize * OUTPUT_SIZE * sizeof(float)));
// Create stream
cudaStream_t stream;
CHECK(cudaStreamCreate(&stream));
// DMA input batch data to device, infer on the batch asynchronously, and DMA output back to host
CHECK(cudaMemcpyAsync(buffers[inputIndex], input, batchSize * INPUT_H * INPUT_W * sizeof(float), cudaMemcpyHostToDevice, stream));
context.enqueue(batchSize, buffers, stream, nullptr);
CHECK(cudaMemcpyAsync(output, buffers[outputIndex], batchSize * OUTPUT_SIZE * sizeof(float), cudaMemcpyDeviceToHost, stream));
cudaStreamSynchronize(stream);
// Release stream and buffers
cudaStreamDestroy(stream);
CHECK(cudaFree(buffers[inputIndex]));
CHECK(cudaFree(buffers[outputIndex]));
int main(int argc, char** argv)
if (argc > 1)
std::cout << "This sample builds a TensorRT engine by importing a trained MNIST Caffe model.\n";
std::cout << "It uses the engine to run inference on an input image of a digit.\n";
return EXIT_SUCCESS;
// Create TRT model from caffe model and serialize it to a stream
IHostMemory* trtModelStream{nullptr};
caffeToTRTModel("mnist.prototxt", "mnist.caffemodel", std::vector<std::string>{OUTPUT_BLOB_NAME}, BATCH_SIZE, trtModelStream);
assert(trtModelStream != nullptr);
// Read a random digit file
srand(unsigned(time(nullptr)));
uint8_t fileData[INPUT_H * INPUT_W];
const int num = rand() % 10;
readPGMFile(locateFile(std::to_string(num) + ".pgm", directories), fileData);
// Print ASCII representation of digit
std::cout << "\nInput:\n" << std::endl;
for (int i = 0; i < INPUT_H * INPUT_W; i++)
std::cout << (" .:-=+*#%@"[fileData[i] / 26]) << (((i + 1) % INPUT_W) ? "" : "\n");
// Parse mean file
IBinaryProtoBlob* meanBlob = parser->parseBinaryProto(locateFile("mnist_mean.binaryproto", directories).c_str());
parser->destroy();
// Subtract mean from image
const float* meanData = reinterpret_cast<const float*>(meanBlob->getData());
float data[INPUT_H * INPUT_W * BATCH_SIZE];
for (int b = 0; b < BATCH_SIZE; b++){
int offset = b * INPUT_H * INPUT_W;
data[offset+i] = float(fileData[i]) - meanData[i];
meanBlob->destroy();
// Deserialize engine we serialized earlier
IRuntime* runtime = createInferRuntime(gLogger);
assert(runtime != nullptr);
ICudaEngine* engine = runtime->deserializeCudaEngine(trtModelStream->data(), trtModelStream->size(), nullptr);
assert(engine != nullptr);
trtModelStream->destroy();
IExecutionContext* context = engine->createExecutionContext();
assert(context != nullptr);
// Run inference on input data
float prob[OUTPUT_SIZE * BATCH_SIZE];
doInference(*context, data, prob, BATCH_SIZE);
// Destroy the engine
context->destroy();
engine->destroy();
runtime->destroy();
// Print histogram of the output distribution
std::cout << "\nOutput for image"<<b<<":\n\n";
float val =0.0f;
int idx = 0;
for (unsigned int i = 0; i < 10; i++)
val = std::max(val, prob[offset+i]);
if (val == prob[offset+i]) idx = i;
//std::cout << i << ": " << std::string(int(std::floor(prob[offset+i] * 10 + 0.5f)), '*') << "\n";
std::cout << i << ": " << prob[offset+i] << "\n";
std::cout << std::endl;
//return (idx == num && val > 0.9f) ? EXIT_SUCCESS : EXIT_FAILURE;
