Different value between fuse ECID and board ECID
Hi all,
Is anyone know why the result of
sudo nv_fuse_read.sh ecid
in a live system and the read_ecid ()function in nvautoflash.sh output different values ?
And not even the same size ?
Thanks in advance,
Related:
But for 36.X
hello Alex15000,
it’s tegra flash to have boot rom communication to obtain BR_CID.
for instance,
[   0.5627 ] Boot Rom communication
[   0.5637 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.5646 ] BR_CID: 0x80012344705E35DE2C0000000B018100
BR_CID it’s 128-bit which compose by four 32-bit ECIDs.
it’s looks like following BR_CID = 0x{ECID3}{ECID2}{ECID1}{ECID0}
it’s python script to convert BR_CID into ECID (internally), which used by BR-BCT
Thanks for your answer ! Do you have a pointer to which python script used to convert BR_CID into ECID ?
Thanks again !
hello Alex15000,
sorry, it’s not a public release python script file.
BR_CID it equals to ECID, it’s due to nv_fuse_read.sh it’s defined as 64-bit.
you may running below to obtain BR_CID directly.
for example,
$ sudo ./tegrarcm_v2 --new_session --chip 0x23 --uid
BR_CID: 0x80012344705DD504740000000BFE01C0
you may refer to developer guide, Enabling Debugging Features Through the BCT Configuration File as see-also.
Hi, thanks for the answer! So I have no way to match ecid from a running board to br_cid from a board in recovery mode ?
hi Alex15000,
may I also know the actual use-case for reference?
identify a recovery board already identify by it’s ECID in order to flash the right software automatically…
hello Alex15000,
please give it a try with the attached python script. ecid-to-uid-test.py (1.5 KB)
for instance,
$ echo 0x80012344705DD504740000000BFE01C0 > br_cid
$ python ecid-to-uid-test.py -t t234 -d br_cid
t234
br_cid
uid(10):
9543798871594891271
uid(16):
0x847262822d2ff807
It seems to work, thank you very much !
