GPU
• DeepStream Version
7.1.0
• TensorRT Version
10.13.3.9
580.126.09
question
we launched 2 very similar pipelines, 1 on our test environment, 1 on the customer, and there’s huge different in the GPU vram consumption, the only thing that changes is the GPU and the cameras resolutions
the batch size is 10
| GPU |
L4 |
L40S |
| .engine file size |
92M |
92M |
| cameras resolutions |
1920x1440 / 1920x1080 / 1920x720 |
2592x1520 |
| VRAM taken by the process |
2264MiB |
3134MiB |
the batch size is the same, the model is the same, the pipeline is the same, the tracker configuration is the same, as well as the deepstream version and the running container
how is possible the same model to grow 100% in ram usage with the same configuration?
thank you, William
Can you tell us your complete pipeline? Is there only one camera for each pipeline?
hi @Fiona.Chen
sure, this is the pipeline
nvmultiurisrcbin latency=2000 select-rtp-protocol=4 rtsp-reconnect-interval=20 rtsp-reconnect-attempts=-1 port=9000 ip-address=localhost sync-inputs=0 live-source=1 attach-sys-ts=TRUE nvbuf-memory-type=3 name=multiurisrcbin drop-pipeline-eos=0 enable-padding=true max-batch-size=2 batched-push-timeout=33333 width=1280 height=720 uri-list=####maskeduri###,####maskeduri## sensor-id-list=0,1 sensor-name-list=mono_0,mono_1
! nvinfer interval=0 name="primary_inference" config-file-path=../config.txt batch-size=2 model-engine-file="../model_b2_gpu0_fp16.engine"
! nvtracker tracker-width=1280 tracker-height=704 gpu-id=0 ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so ll-config-file=../tracker_config.yml
! queue max-size-buffers=0 leaky=2
! nvmultistreamtiler rows=2 columns=1 width=1280 height=1440
! nvvideoconvert name=raw_tiler_probe nvbuf-memory-type=3
! video/x-raw(memory:NVMM),format=RGB ! queue max-size-buffers=0 leaky=2
! nvjpegenc quality=80 ! fakesink async=true name=jpeg_tiler_probe
thank you, William
Hi, is your concern about the GPU memory consumption? If it is so, the hardware decoder and video conversion also need the GPU memory. It is normal that the GPU memory consumption for different video resolutions are different.
